Question about Pyle PLD51MUBT Car DVD Player
Hey i have PYLE PLD51MUBT it was working fine i took of the faceplate and next day when i put it on there was no screen all black but if sun shines right on the screen you can see its working fine the functions and everything but the screen has no light or anywhere on the plate there is no light as well also the lock for the faceplate to clipped and locked to the system is broken where can i find that or if there is any alternative on it? Thank you
3 Suggested Answers
SOURCE: i have a pyle pld5mu and the screen is dark
Hey honestly what you need to do is send the unit back to pyle and they will repair it. I have the same issue 2 times. What they say is the players power supply went out and that 80% of issues with the pyle products are improper installation. I am selling mine and you should do the same after you get the player back. I hope I could help
Shawn Contreras
Posted on Feb 03, 2009
gopakumarg43
  • 75417 Answers
SOURCE: my Pyle PLD51MUBT will not
Hello
If the temperature inside the car is high, the disc won't eject.
If it is OK, enter to 'Preference page" select 'Default" and press enter to reset the device. Type the old password, the factory passord code is [1379], and key in 4 charecters password now you want to use, and retype again to confirm key in correctly Now press Eject button. If this does not help you, the loading mechanism of the device is faulty, and need service. Disassembleing and reassembling this mechanism is really a skilled work, and should be done by expereienced service techinician. OK
Posted on Sep 04, 2011
TV Problem: No Video but Audio works
Here are some basic treatment for a dark display.
  1. On LCD TV, Some time missing or lose LCD strip from PCB connector. Solution- Clean strip and connector.
  2. Some time missing LAMP, burning lamp is a major cause for dark display in LCD TV. If lamp problem with any display, Display show in sun lights. Solution- Check Lamp connection/connector. Clean connector or change Lamp.
  3. In CRT TV, Fly back is faulted. There are no high voltages. Solution- Change or check fly back, Check out put transistor.
  4. Some OLED Tv Use OLED lights for display shining and brightness. IF LED's or lamps are faulted there is no display in sun shine.
  5. Before starting Troubleshoot display problem you need to conform and trace faulted stage of TV.
  6. Don't Apply any miss use trick at home. Contact the professional repairing lab.
  7. If you are full fault to understand your TV problem. Tip more condition of your problem.
Jul 02, 2015 | Element Televison & Video
My Pioneer DEH-P9800 BT faceplate won't close
The clip that locks the plate into place probably broke.
Mar 20, 2013 | Pioneer DEH-P9800BT - In-Dash CD/MP3/WMA...
Screen is blank... still have sound and controls. too back to store and the screen worked on the store display model.
Your problem is the wires in the unit that hooks to the connection plate to the face plate there is a wire that burned up and not making the connection, youll see the wires when you put faceplate on and tilt your screen its like a orangish yellow wires that is hooked into the slot that your faceplate connects to a wire has burnt up probably caused by the brake wire that wasnt hooked up or from pulling off the faceplate to many times HAD TWO OF THESE DO THE SAME THING neither one I had ,had brake wire hooked up and probably caused it to short out.
Mar 14, 2011 | Pyle PLD51MUBT Car DVD Player
I was on the phone and when I hung up, my screen was black
Sounds like your display has developed a failure.
It's cheaper to buy a new one verses repair it.
Dec 30, 2017 | LG Shine KE970 Cellular Phone
I just installed an Pyle PLD70BT. Can't get any sound from speakers. Even tried an external speaker, still doesn't work. I installed this myself and have installed many stereo systems in the past, never...
May not be a problem with the installation, sometimes ya just get a bad one. If you have hooked it up to power, and ground, and attempted to use a speaker outside of the cars wiring, then odds are you just got a bad radio out of the box.. This sort of thing just happens man, but hey that's what warranties are for right?
Aug 08, 2009 | Car Audio & Video
I have a pyle pld5mu and the screen is dark
Shawn Contreras
Jan 08, 2009 | Jensen VM9510 Car DVD Player
Black screen
mine is almost the sameproblem. if i shoot, thre is just black screen, and the pictures taken were also black. but i could still see the old pictures that i took if i look at therm at the screen, i brought it to a tech and they replaced the whole lens assembly. and now everyhing works fine.
Jul 13, 2008 | Olympus FE-210 Digital Camera
Delonghi Rotofryer filters
Just had the same problem myself and eventually found the answer.
The white filter must rest on the metal part and the coloured area must face upwards (or towards the black filter)
You can download the user manuals at the following
http://www.delonghi.co.uk/pdf_files/F18_series.pdf
Hope that helps
Apr 05, 2008 | Kitchen Appliances - Others
Black LCD
Sounds like you have a bad backlight, the backlight shines light through the translucent LCD layers to give you your picture in the same way you hold slides up to the light
Oct 08, 2007 | Averatec 3200 Notebook
Pyle PLD51MUBT Car DVD Player Logo
53 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
