Question about Miller Welding Tools
Error code 24 on dynasty 350 - Miller Welding Tools
Plugged in Miller Dynasty 350 and it said REL RMT. Wouldn't let me change the settings, all I could do is turn it on and off. I checked the owners manual inside and out and couldn't find...
Hi:
Legend REL RMT means release remote, this happens when your torch's trigger is depressed and you need to release the trigger to continue.
Check the owner's manual on section 7-4 troubleshooting, it's there.
Sep 08, 2011 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
I have a help 12 code on my little dynasty machine, and no manual to tell me what it means, is this a major problem with my machine
On this page enter your serial number and you will be able to download your manual http://www.millerwelds.com/service/ownersmanuals.php In the Dynasty 350 manual I see no "Help 12", there is a 32 and 22. If the Help 12 is only displayed when you push a button, it is saying the combination you have selected is not valid.
Dec 22, 2010 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Help code 24 ?
On this page enter your serial number and you will be able to download your manualhttp://www.millerwelds.com/service/ownersmanuals.php In the Dynasty 350 manual On Page 76, section 7-4 it says: Help 24 Display Indicates a power supply to the control and interface board PC6 failure. Possible cause is a short in Pin A or Pin B of the remote control. Unplug the remote control and see if it goes away.
Dec 05, 2010 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Error code 350 error code 990 error code 540
Error code 990 indicates software problems yuo can check in SP7-403 for information.
Error code 540 will proberly indicate some heating trouble in the fix, you have to reset the machine with service code SP5-810.
Code 350 will disappear if you restart the copier.
Oct 09, 2009 | Ricoh Aficio 1035 Copier
Bizhub 350 error code c2557, how can i fix this?
This code happens if you replace drum without replacing developer. Both must be replaced at same time.
Sep 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I NEED TO AIR ARC CAN THIS MACHINE DO THIS AND HOW
hook up to the stick position on the machine - to work + to the stinger hook stinger to the air arc hook up air to the air arc turn welder up to top {350}turn air on at the push button on the air arc & get busy
Apr 09, 2009 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
I have a miller dynasty inverter tig welder   It has a help code that comes on when I turn it on the code is p-2
From the user manual for a generic dynasty model welder:
2 Help 2 Display
Indicates an open in the thermal protection
circuitry located on the left side of the unit.
Contact a Factory Authorized Service
Agent if this display is shown.
So you could have anything from a broken or disconnected wire to a bad thermal switch.
You can get user manuals specific to your welder at www.millerwelds.com
Rank this answer please,
Carl
Nov 26, 2008 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
Welding Tools Logo
87 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
