King Solomons Lost Mine level 100 has 2 chain locks no room for 3 item to break chains cannot move on to next level ??
  • bandgmartin Sep 29, 2010
    two chain lock item are ajacent
    there is only one item to the right of one item
    there is only one item to the left of the other
    no other items can be entered to make up three necessary to break chains
    there is only one item available above each chain lock
    there are no places for items below the chain locks
    there are only eight places available and a minimum of ten places are necessary
    twenty places would be ideal
    President:
  • 2,777 Answers
I see, so wait what do you mean 2 chain locks, no room for 3 item to break chains? it sounds like you need to discard or use some of your items so you can hold all three?
Let me know, I will continue to research this,
Tim
Posted on Sep 29, 2010
  • Tim Grayson
    Tim Grayson Sep 30, 2010
    As far as I can tell this is a glitch in the game, I have read of many people stuck at the point you are and noone can get past it :(. I am so sorry, I don't think there is a way, but I am still checking for you. Just wanted to give you an update.
    Tim
  • rawilli8589 Dec 12, 2010
    I got it...it took a while though. The only way this can be done is if your last save was on level 99. I always save right before I make the last move to advance. Then just keep going into level 100 until you get both of the locks with the same jewel. Good Luck!
How to tighten chain on 4620avx poulan pro
First, RTFM- read the manual. Lost it? No problem, download it from Poulan PRO website page for PP4620avx. Pick a version you like, save and read it. Google is your friend.
Chain Adjustment Part cut and pasted as follows:
Adjusting the tension:
Chain tension is very important. Chain stretches during use. This is especially true during the first few times you use your saw. Always check chain tension each time you use and refuel your saw.
1. Lift lever on bar knob and turn counter-clockwise 1.5-2 turns to loosen clutch cover.
2. Turn adjusting wheel (downward direction) to tension chain until chain solidly contacts bottom of guide bar rail. Lift tip of guide bar while adjusting tension. Tighten chain Adjusting Wheel
3. Use a screwdriver to move chain around guide bar to ensure all links are in bar groove.
4. While lifting tip of guide bar, tighten bar knob securely (clockwise).
Hand tighten only.
Be careful not to destroy the adjustment mechanism. When it breaks, go for a clutch cover with the simple adjuster that needs a "scrench". Longer term, learn how to search this info. Saves time. Now you can work on sharpening chains- very important.
Manual page:
http://www.poulanpro.com/ddoc/PPOO/PPOO2006_USen/PPOO2006_USen_PP4620AVX_952802146.pdf
Jul 21, 2014 | Poulan Pro Chain Saw 46cc 20"
Bajaj Discover 135cc 2009 model Drive Chain Making Obstructing sound
Hi, Vinod you may need a new chain and sprockets with that many Kilometers for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Easy Motorcycle Chain Stretch Test
Is Your Sprocket Worn Out
Bajaj Discover Technical Specifications Bajaj Discover 135 DTS Bikes in...
Owner Manual Bajaj Auto
Bajaj Discover DTS 135 2009
Mar 22, 2017 | 2008 Bajaj Discover DTSi
Mine got dropped it will start but the chain want move . How do i fix it .
pull back on the chain bar lock , its the knuckle guard in front of the top handle.
Hope thats all it is?
Mar 06, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How doe the band on my chain break attach to my chainsaw mine is broken and i do not know how to install it. or how to get the clutch off so i can replace it
It can be a little tricky!
If you are referring to chain break band
Tools you will need:
1/2 Socket (to remove bar nuts)
T25(torq) or you can use a Flathead screw driver but is a little harder.
Remove 2 bar nuts,Clutch cover,bar,chain, 2 screws on black bar handle right behind clutch cover(this is needed because there is a hidden screw there for the chain break) You will need a new chain brake (my guess is that it is part # 530071893 aprox $15) but you will want to verify that with your model number.
You should see the chain break assembly, 3 - T25 screws are visible after the clutch cover is removed(note sometimes you have to clean saw dust to make screw head visible) the other T25 screw is hidden under the black bar handle. Once you remove all 4 screws on the chain brake you will be able to pull it off.
Installing the new one is the tricky part because if it is set(or break is on) you will have a hard time putting it on.One of the easiest ways is to focus on it near the muffler you will see that a metal 3 pronged gear fits into the plastic part of the chain break handle.and if the band is too tight to fit over the clutch drum you will have to carefully reset it by applying pressure onto the area that has the 3 pronged gear and chain break handle make sure that the handle is pushed forward all the way while you apply pressure then slowly pull chain break handle back till you hear a "snap" this resets the chain brake spring and the band should now fit over the clutch drum.Now, proceed with putting back together 4 chain brake assembly screws,2 handle screws,and bar,chain,clutch cover,and 2 bar nuts.
Please note it is important that you apply quite a bit of pressure onto chain break area where metal (3 pronged) gear fits into handle while resetting or when you reset it the metal part can cut into and damage the plastic piece in the chain break handle.
You can see a breakdown here: http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Chainsaw-Parts/Model-P4018WT/1324/1503220/P0506041/00002?blt=06&prst=0&shdMod=P4018WT
Hope this helps!
Feb 20, 2011 | Poulan 18" Wild Thing Chainsaw
I need to remove chain on a 26" mans speed bike Is there a king link or a removable link?
No, to install or remove a chain on a bike with derailleurs (gears) you need a special chain tool to "break" the link. goto your local bike shop and they will have a few different ones to choose from depending on how often you will want to do this procedure.
Different chains require different tools and price varies from $10- to over $100. Also you should get a little instruction on how to reinstall properly, if you don't do it right the chain will break when you go riding and could cause injury.
Jan 05, 2011 | Huffy Cycling
How to adjust primary chain and clutch on 04 1200c thanks
First, let's adjust the primary chain first. Remove the upper inspection hole cover. Stick your finger in the hole, find the chain, and raise and lower it. With the engine cold, the chain should have 3/8" to 1/2" up and down movement. To adjust this, look underneath the primary. You'll see a bolt and a lock nut. under the primary. Loosen the lock nut and turn the adjuster to adjust the tension in the chain. Adjusting the bolt upwards tightens the chain, lowering it loosens the chain. If you get the chain too tight, lower the chain until you get too much movement in it and then raise the adjuster again.
On the clutch, remove the clutch release mechanism cover. Remove the spring and the lock nut. Find the cable adjuster in the middle of the clutch cable. Move the cover up or down, break the lock nut, and adjust the cable adjuster inwards until you get a lot of slack in the cable. Turn the adjuster bolt at the relaese mechanism counterclockwise until it stops. Then turn it back clockwise 1/2 turn. Install the locknut and spring and cover. Go back and adjust the cable adjuster outwards until you have about an 1/8" freeplay. Lock the lock nut and replace the cover.
Good Luck
Steve
Dec 19, 2010 | 2004 Harley Davidson XL 1200 C Sportster...
Timing Chain Broke on CX-7 2007
The timing chain should of been changed at 30,000 or 60,000 miles it's in the owwners manual.
Aug 20, 2009 | 2007 Mazda CX-7 Grand Touring
2001 H-D Road King engine knock
For valve train noise try these:
1. Low oil pressure caused by oil feed pump not functioning
properly or oil passages obstructed.
2. Faulty hydraulic lifter(s).
3. Bent push rod(s).
4. Incorrect push rod length.
5. Rocker arm binding on shaft.
6. Valve sticking in guide.
7. Chain tensioning spring or shoe worn.
8. Cam(s), cam gear(s) or cam bushing(s) worn.
9. Cam timing incorrect.
If it is a bottom end knock, an engine tear down may be in order.
May 30, 2009 | 2000 Harley Davidson FLHR-FLHRI Road king
I can't get the clutch cover back on my Husqvarna 235 e because the chain break is engaged. Spring is too tight to disengage it.
The chain brake is engaged when the brake handle is moved forward.....to ensure it is actually the chain brake...with the clutch cover off and in your hand, pull the chain brake back...if it will not move, attempt to move it forward to see if it was not engaged...if it moves forward, it is now engaged...pull back to disengage it...a lot of times the problem is not the brake, but rather the bar adjuster....if the brake is not the problem,...loosen the bar adjuster and reassemble the unit...once assembled, then adjust the bar as per the user manual.
let me know what you find.
clarkco
Apr 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
King Solomon's lost mines 1001 treasures. I'm on level 100 and there doesn't seem to be any way to solve this.
I finally made it past level 100. I saved level 99 towards the last, then played level 100 over and over. The ones with the same locked gems I would delete and go back to 99 and play level 100 again until there were different locked gems and finally made it. I am on 307 and cannot get by it. When I work on a level, the last couple of moves, I save it so if I come across a difficult level. I don't lose what I have went through. I saved 306 but I have worked on level 307 over and over for several weeks now. Does anyone have a solution it level 307?
Feb 26, 2009 | MPS Multimedia King Solomon's Lost Mines -...
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
