Question about Kenmore Dryers
I cannot afford a service tech right now to come to the house. I hope you can help me through this service. I have a kenmore elite clothes dryer model # 110.63012101 Dryer was not making any heat. Opened up the lower front and removed all lint from inner tubes. Totally cleaned out exhaust. I replaced the heating element. No heat. I am looking at the wiring diagram and there seems to be two possible culprits. On the bulkhead diagram there is part number 47 which is a non-resettable cutoff-tml for $29.54. Also from the wiring diagram there is a non-resettable thermal fuse which on the bulkhead diagram appears to be part # 59 Thermal Fuse for $18.27. I checked the terminals of the Thermal Fuse for continuity which there is. On the cutoff though there was no continuity. I do not know what the state of continuity should be or if that is even a way to check the part. But I would like advise on how to proceed as both parts are expensive. Thank you for you help Charlesmatthes@yahoo.com
  • Kenmore Master
  • 2,128 Answers
You're doing the right thing except for changing out the element without reading it out first.when you check the parts make sure the dryer is unpluged and that you pull at least one of the wires off the part you're checking. check the thermostats on the heater box part
279769 which is part 47,also remove the duct that the lint filter slides into and clean it,if you have a long vent line remove it from the back of the dryer and blow it out with a leaf blower and if you have a shop vac put it on blow and blow off the motor and blow all the lint from the back inside of dryer so it blows to the front and vac it up so you don't have to pull the drum if you don't want to.the thermal cutoff pops when it gets to hot in the dryer most likely from a back up in the vent line or the duct,also go outside and make sure the vent is clear,you should be fine
Posted on Sep 30, 2010
Testimonial: "Thank You for helping guide my efforts to fix this baby! I Will follow your advice and get back to you."
  • 2 more comments
  • Charles Horsehoof Oct 04, 2010
    Thank you again and I will try your suggestion in the manner you describe.
    Thanks,
    Chuck
  • Charles Horsehoof Mar 03, 2013
    You are a gem Sal-Thanks for the help!
  • Sal DeAngelo Mar 03, 2013
    glad i could help and thanks for writing back so hopefully someone else can read this and help them too.whenever you're checking a part you can set your meter on say 20k ohms,you'll see a 1 on the meter,touch the leads and you should see anything but 1,always remove at least one of the wires,touch the leads to the part,if you see 1 the part is bad,any other reading it's good.it's that simple,check it a few times,sometimes the leads might not be on the part so it's a good idea to check it again.good luck and good job,glad i could help.
  • Charles Horsehoof Mar 04, 2013
    Awesome to talk shop with a guy named Sal!
I have a kenmore elite dryer that is only 4 yrs old. It stops about 5 minutes into the cycle and puts up 2 codes. CLL and Sru what do these codes mean and can I continue using the dryer ?
Clean the entire exhaust duct from the back of the machine all the way out of the house, if the codes don't change. Call a service tech... CLL SRV = call for service
Apr 26, 2016 | Kenmore Elite HE4 Electric Dryer
Why won't it start?
Free Kenmore Clothes Dryer User Manuals ' ManualsOnline ...
laundry.manualsonline.com > ... > Laundry Appliance Kenmore
Products 1 - 50 of 65 - Kenmore ELITE HE3 Gas Dryer User's Guide 110.9787 9789. Pages: 0 ... Kenmore 27-Inch Wide Electric Dryer Owners Manual. Pages: 0 ...
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...? 7:29https://www.youtube.com/watch?v=SPRqKVE8JfYOct 21, 2011 - Uploaded by canyonman1963... and repair a Whirlpool or Kenmore electric dryer that will not start or run. ..... I have a Kenmore Elite Oasis ST Dryer, model number 110.78082701. During ... Dryer Troubleshooting - NotDrying or Taking a Long Time to Dry ...How to take apart Kenmore Elite Dryer - YouTube? 6:28https://www.youtube.com/watch?v=QNa6zfzrm5kOct 16, 2012 - Uploaded by RenewApplianceI have a kenmore elite 79661423410 electric dryer stoppedworking manual says has no thermal fuse and I can't take it apart help thank you.
Dec 12, 2015 | Kenmore HE5 Electric Dryer
No heat-Kenmore (Whirlpool) Elite He5 Steam 110.8775
Check that there is 240 volt at the plug as sometimes a breaker will be weak on one side and only produce 120 volts which will let the drum spin but produce no heat
Mar 20, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite H3E Washer Drain/Spin Problem
hi
it is the belt problem
check it///thank u
please rate it
Jul 04, 2009 | Washing Machines
Kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
kenmore elite won't start, Solve kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on... (More) kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
Jul 03, 2009 | Kenmore 63942 Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Black stains on white table cloth
Hi! topjdog
I hope you have been running the monthly cleaning cycle. This includes cleaning the front gasket.
InMrFixIt
Aug 16, 2008 | Kenmore Elite HE4 Electric Dryer
Electric kenmore dryer
replace the motor it is stuck in the start winding and can cnot get up to the run winding as long as you are holding in the start button the start winding is working in a second it should through the motor switch shift the voltage to the run winding
bad motor switch
replace switch if available or change motor
Apr 29, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis Dryer with Airflow problem
same problem removed back cover cleaned lint found pulley had unscrewed and belt was off.installed pulley rev threded and put belt back on.
Mar 02, 2008 | Kenmore Elite HE4 Electric Dryer
Electric Dryer overheating
sounds to me like you have a venting problem or the vent is plugged check the vent clean it out. make it as short as you can , also if you can use rigid metal vent...if all is clean then the blower wheel must be broken.. or loose. check for air flow out the vent ...let me know what you find..
Aug 26, 2007 | Kenmore Elite 20972
Dryers Logo
173 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
