Question about Pride Jazzy Select 6 Indoor Power Wheelchair
Turn chair on. It flashes 7 times and turns off. Is it the battery or the control in the arm?
  • 692 Answers
Joe you have a joystick problem. Check to make sure that the joystick is centered before you turn it on if it still gives that error then you will have to get another joystick. If Medicare paid for your chair then they will pay for most of the repair costs. Contact your provider or a service company to get it fixed. Hope this helps you
Posted on Sep 29, 2010
Hello! I have a M51 Invacare Pronto that is not working. When I turn it on, the service light flashes eight times, one red battery light flashes as well, but nothing happens when I move the joystick.
If it flashes 7 green and one red for the 8 total then it's a joystick error. If it's 8 green and one red then it is a control/brain error code. Measure voltage on batteries when turn chair on. Both batteries need to stay above 11.5 volts each.
Jan 21, 2018 | Invacare Health & Beauty
My M41 invacare controller keeps flashing and it flashes 5 times. I don't understand what the fix for this.
If your M41 has the mark V controller that is seen pictured in the stock photo you provided, the 5 flash code is a left park brake fault.
1. Turn off the chair.
2.Disengage the left motor (levers are located in front under the seat) roll the chair back and forth and re-engage the left motor.
3. Engage the left motor.
4. Turn on chair.
If you happen to have the older Mark IV controller (has a toggle switch to turn on/off and three battery lights), the 5 flash code means the chair is receiving high or low voltage from the batteries. I would recommend having the batteries checked.
If the chair stops flashing, you are good to go. If the chair is still flashing, you will need to contact a technician to possibly replace the left brake. I recommend Repair Xpress FixMyPWC com Nationwide service and delivery solution for power...
Jul 15, 2014 | Electric Mobility Invacare Pronto M41...
Light flashes 7 times
7 Flashes indicates a joystick trip. Turn off your chair, ensure the joystick is in center position without anything touching it and turn on chair. This should clear the 7 flash code.
This problem is quite common amongst power chair users. It typically occurs when something is pressing against the joystick as you are turning the chair on.
Feb 14, 2014 | Select Jazzy Used Electric Wheelchair
How to reset controller on jazzy power chair
yellow light is flashing and i can't turn chair off. still operates.
Jun 20, 2012 | Pride Jazzy 1103 Ultra Standard Power...
Our church has 2 Jazzy's one is blinking the code all lights flash 7 times the other 9 times all lights flash can not find what I need to do in our book. Can you help is there a web site I can get a...
mtp see the below list
The listed Flash codes are pretty standard and are applicable to powerchairs only not scooters:
1 flash User Fault (do not touch joystick) and turn back on
2 flashes Battery Fault Recharge batteries or replace
3 Left motor fault check connections or replace
4 Right motor fault check connections or replace
5 Left park brake fault check freewheel lever or brake connections
6 Right park brake fault check freewheel lever or brake connections
7 Remote fault check connections and wiring replace remote(joystick) (Check cable to the joystick unplug connector at rear of chair and plug back in then try turning on to see if you are getting same code)
8 Controller fault Check connections and wiring replace controller
9 Communication fault check cable replace (almost same problem as 7) try same fix if doesn't work joystick will have to be replaced
10 and 11 are unusual and will not be seen if at all Hope this helps you
Apr 04, 2011 | Pride Mobility Products Health & Beauty
This jazzy Select 6 chair battery light keeps flashing 7 times and will not function.
alaker the 7 flashes indicate a joystick problem. Make sure that the joystick is centered before you turn the chair on. If it is centered and you still get the flashes then there is a problem that can only be fixed by a new joystick. Sorry for the bad news. Did Medicare pay for your chair? If they did then they will pay most of the replacement costs. Check with the provider that sold you the chair or with Roadrunner Mobility (On the web) to get it repaired Hope this helps
Nov 16, 2010 | Health & Beauty
My question is related to an Invacare-Nutron R51.Production date 1-7-03,joystick[MKIV R11] flashes red 1 time, than green 5 times repeatedly? Can you please tell me what this means.?
Ranch well the red flash indicates a low battery and the 5 flashes indicate a bad left brake. Now try charging the batteries until you get a green light on your charger then turn on the chair it shouldn't flash the red if the batteries are accepting the charge. If your batteries are 2-3 years old it could be time to change them. If Medicare paid for your chair then they will pay most of the repair costs. You can contact your provider for help or a service company like Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733. If Medicare did buy the chair then you are eligible for a new chair every 5 years and yours is almost 8 years old. Contact a local provider that you trust to check into getting you a new chair. Hope this helps you
Sep 29, 2010 | Invacare Pronto M51 Power Wheelchair
WHEN I TURN THE POWER ON FOR MY JT3 ULTRA POWER CHAIR, THE LIGHTS THAT INDICATE THE STATUS OF BATTERY BLINK ON AND OFF (REGARDLESS OF BEING FULLY CHARGED OR NOT) AND THE CHAIR WILL NOT MOVE. SOMETIMES,...
I would replace the batteries with new ones anyway to make sure that you are getting full power and if the problem stops great if it continues then you have eliminated one possible problem. A low battery will cause the problem and these chairs diagnose themselves with the controller giving you flash codes to indicate a problem. I would just check for a loose connection in the wiring when you have the seat off changing the batteries and give the base a good cleaning( without water) (Use those cleaning wipes from dollar store) Hope this helps you
Sep 08, 2010 | Jet 3 Ultra Power Chair
I have a quicky power chair, i think its an F-35 b...
I think you have locked your controller, or put it in "sleep mode". Turn on the chair again and push the joystick forward, then to reverse, then forward again and release. It should fire up. Let us know if that worked.
May 21, 2010 | Quickie Wheelchairs Quickie Aspire Power...
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
154 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
