Question about Malibu Intermatic Inc. ML121RT Low Voltage 121-Watt Power Pack with Timer
The bulbs burn out after a short time - Malibu Intermatic Inc. ML121RT Low Voltage 121-Watt Power Pack with Timer
  • 56 Answers
If you have a meter you can check the voltage coming off the timer it should read 12 to 13 volts also check to make sure your connections are all tight
Posted on Sep 30, 2010
No taillights but turn signal and break lights work.
These use a dual element bulb. It's 2 bulbs in one. The brighter element inside the bulb is used for the BRAKE light & turn signals. The second, dimmer element in the bulb is for tail lighting during night driving. Because they're on the whole time you drive at night they tend to wear & burn out sooner then the BRAKE light element. Assuming they're both the same age, they would burn out close to around the same time. Replace the bulbs. However, the tail lighting/running lights are also on separate wiring too. So check for damaged, rotted, or shorted wiring or bulb sockets, & also check the running lights fuse. If the fuse is blown, it's a good sign you have shorted/bare wiring, or damaged socket.
Apr 23, 2016 | Dodge 1997 Ram 1500
I have a short in the elm wiring on a 348 Pete can you help?
Make a replacement fuse From the one that blows.
Use a blown fuse and connect(Solder) an extension pair of wires with light bulb on the end. The light bulb will remain Bright until the short is removed then it will Go Dim.
This will give you time to trace the wiring until you find the short. Meanwhile The Bulb will prevent anything from burning.... as in a dead short!
Mar 03, 2015 | Cars & Trucks
How wiring diagram for christmas lights work
All the bulbs in a section of lights are connected in series, meaning one after the other, like links in a chain. If one bulb goes out the chain is broken and that section goes out. All modern light sets have bulbs which have a built-in feature called a shunt. The shunt in the bulb is supposed to short out if the bulb filament burns out. The advertising wording would be something like 'if one bulb burns out, the others stay lit'. It usually works, but there are limits. Sometimes the shunt in the burned-out bulb fails to work and the chain remains broken. You have to find the bad bulb and replace it. Also, every time a bulb burns out, if the shunt is working and the other bulbs stay on, the power to each remaining lit bulb increases. This puts a strain on the remaining bulbs, which is why you should always replace burned out bulbs as soon as you discover them. If you don't and more bulbs in the same section burn out, you can reach a point where there's too much power for the remaining bulbs to handle, and all (or at least many) of the remaining bulbs will burn out, necessitating a replacement of the string.
Dec 15, 2011 | Christmas Lights Etc Santa's Toy Truck
On our Panasonic the genius sensor 1200w microwave the bulb burned out so replaced. After replaced turned light switch on both bulbs turned on and right away one bulb burned out and now the switch will not...
Mine burned out within a month. Probably due to the poor design of the machine which forces you to slam the door to get it to shut.
My biggest concern is the under counter lightbulbs it has burned out in my kitchen over the last year. I wonder how much leaking this thing really gives off. Moving in a few weeks and will be throwing this cancer machine out.
Sep 09, 2011 | Panasonic NN-H764 Microwave Oven
Hello, I got this Model in 2006 and my picture has got dimmer and dimmer. Is their just one bulb that needs to be replaced, and is it the bulb? Thank You!
there is more than one bulb, you need to call samsung to find out just how many. the bulb can be the primary fault , however all plasma tv's will dim more and more over time. It has more to do with the plasma panel though. replacing the bulbs may brighten the picture some however if it were only the bulbs you would have no picture at all. my personal opinion in this case would be to not replace the bulbs, i doubt that will solve your problem even if it does brighten the picture some i doubt it will produce the solution you are seeking. plasma tv's are great but they do have drawbacks, like the bulbs needing to be replaced and the fact that the panels get burn in . the problem you have is more to do with burn in than it does the bulbs. even thought there is no static image in one place ( what people think burn in is only ) the entire panel has " burn in " slightly which dulls the screen. i suggest buying a new tv, lcd or lcd/led to avoid this in the future. you can try to use the same thing they do to fix actual burn in of a static image, that may brighten the screen a little, however in some instances that is the culprit. to truely explain all this it would take a very long time , look up burn in on the internet and read about all the causes and solutions, you will then understand in a rather short period of time.
Jan 09, 2011 | Samsung HL-S6187W 61 in. HDTV
My head light bulb burns each time i replace it
If youre bulb is burning out each time you're replacing it with the correct bulb you've got a short somewhere in your wiring from your headlight switch to your connection to bulb. Check for any damage to your wires and burnt or corroded looking points on all terminal contact points which can indicate arcing or a poor contact point that has caused excessive heat and normally damaged surrounding contacs or wires.
Dec 10, 2010 | 1997 Honda Accord
Front headlight continues to burn out. Changed 3
check wiring to see if is shorting out agaist anything.
Also if you are buying cheep bulbs try buying one from the dealer.
Some vehicles can be finicky with aftermarket bulbs
Jan 15, 2010 | 2000 Buick LeSabre
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
40 watt night light bulbs constantly burn out short out.
Is they are left on all the time, this can reduce their life, and they are more susceptible to vibration.
Have you checked at home center or home improvement centers like Lowe's, Builder's Square or Home Depot?
You can order quality parts such as lamps by entering your full model number or part number WB36X10003 here.
Always be sure the microwave is unplugged or the breaker is off when installing or removing bulbs, and be sure the bulbs and and your hands are clean when installing them.
Feb 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Malibu Intermatic Inc. ML121RT  Low Voltage 121-Watt Power Pack with Timer Logo
74 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
