Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
How do I get the drive pulley on top of the transaxle off?
  • 11,896 Answers
  • Position the pipe wrench tightly above the drive belt pulley to prevent the crankshaft from rotating when you unscrew the drive belt pulley.
  • Fit the proper-sized socket onto the bolt that holds the drive belt pulley to the base of the engine's crankshaft.
  • Hold the pipe wrench with one hand, and with your other hand unscrew the bolt using the socket wrench.
  • Pull down on the pulley until it slides off the crankshaft. Slip the drive belt off the pulley.
  • Posted on Sep 29, 2010
    My mower Cub Cadet GT 1554 stopped moving. I found a plastic thing that looks like abfan on the ground
    The transaxle (transmission) has a fan fastened to the drive pulley. It is possible that you belt has jumped off of the pulley on the transaxle and this broke the fan.
    Jul 05, 2017 | Cub Cadet Garden
    Aliens 936056 46" hydro tractor i release the clutch and drive won't engage. It makes a grinding noise.Like its not engaging all the way. any idea what is wrong?
    Did you have to remove the pulley on the top of the transaxle ? If so is it possible the shaft key that locks the pulley to the shaft fell out. Did you replace the drive belt because it broke or was it not pulling before you changed it? There is also a square shaft key on each wheel that locks the wheel to the axle shaft.
    Apr 10, 2016 | Garden
    Tractor won't move
    drive belt broke if transaxle is not turning does clutch pedal feel loose ?
    Nov 12, 2013 | John Deere 420,1020,2010,2020,2510,2520...
    Automatic transsmission does not work
    with your eyes only ck that pulley on top of rear transaxle is turning with engine at idle , if not your drive belt is stretched or broken
    Nov 11, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
    I cannot get my Poulan riding lawn mower to go into gear. What am I doing wrong?
    Check your drive belt underneath the engine (on a crankshaft pulley) and make sure it is connected to the drive pulley on the transaxle (this area is under and probably just behind the seat. Don't confuse this drive belt with the belt that runs the blade mandrells on top of the cutting deck.
    Apr 13, 2011 | Poulan Garden
    I'm having trouble replaceing the motion drive belt on my LT1000 lawn tractor. The mowing deck is off, the old drive belt is off. I can't get the belt around the transaxle pully. Any suggestions?
    Often there is a keeper on the back of the pulley, and the belt must go inside the keeper. Get an inspection mirror up in there to look if necessary. Start by putting the belt on the transaxle pulley, then on the PTO pulley, then on the idler, last have someone sit on the mower and depress the clutch pedal while you put the belt over that pulley.
    Sep 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
    2008 Husqvarna YTH 2348 is loosing power...
    it has a leak from the head gasket,ive done many with the same problem.pop the head off and change the gasket,also check the rings ect while apart
    Dec 30, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
    Craftsman model 917.271814 will not go forward or reverse. Heard a "click" and mower stopped moving; engine and blade still running.
    Check the drive belt that runs back to the transaxle,it sounds like it broke.If the belt is in the pulley check to see if the transaxle pulley is turning when the clutch is out.Also make sure both wheel axle keys are in the rear wheels.If all this checks out the transaxle may have broke,look underneath to see if it is broken there.
    Aug 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Loss on drive on Poulan Lawn Tractor
    Check to make sure the belt is not broken or did not come off the transaxle pulley, you can check by removing battery from under seat and pulling battery box out to examine top of transaxle,Pay close attention to the wire belt guide on the rh side of the transaxle pulley it should be close to the backside of the belt after it is reinstalled.If you recently may have removed the rear tire make sure the square key on the axle didn't drop out.Is the tractor a hydrostat drive? If so make sure brake is not stuck on,if it was it would make a grinding noise.
    Jun 28, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
    Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
    65 people viewed this question
    Top Craftsman Garden Experts
    Dean Gruber
    Roland W VanLue
    Roland W VanLue
    Dennis Key
    Dennis Key
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
