Question about Amana SXD524VW Side by Side Refrigerator
The refrigerator appears to be running but it is not getting cool. I am not sure if the fan is running on the refrigerator. We had problems with it freezing up twice and had to defrost. But it has not done that for a couple of months or more now.
  • Amana Master
  • 1,711 Answers
Condenser fan problem on Kitchenaide Refrigerator - kscs23inss01
What you are going to find is this... Your COILS under the Plastic are Condensating and FREEZING and then this is what is causing the On /Off of the Temp. You have to DEFROST the COILS (Under the Plastic) and remove ALL the ice and Moisture. Once you get this problem resolved, it will work perfectly. This problem was caused by the Condenser Coils being Dirty and and the Switch on Top, Under the Plastic from being unable to work properly. This is a time consuming issue but easy to do. DO NOT SCRAP or BREAK the ICE after you take the Plastic off, use a hair dryer or Hot Water and make sure the Drain Tube is completely cleaned...
Mar 03, 2014 | KitchenAid Refrigerators
Evaparator fan motor not working what can be the problem.
The problem could be the defrost timer/control board or a bad fan motor....
Check for power at the motor... if there is power then the motor is bad...
if no power then the controlboard or the defrost timer control is bad...
make sure there is no ice stopping the fan...
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | KitchenAid Refrigerators
Poor cooling on frezer and almost no cooling on refrigirator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Amana Side-by_Side SXD26VL is not cooling. The
clean cond coil at back of unit.
check amp draw on the compressor wires.
Sep 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Our Kenmore Refigerator was purchased July 1992. Model # 363-9524720 Serial # L220-16905. Problem: Refigerator runs but freezer section does not freeze and ice cubes are not forming. Food storage area does...
As a start, try cleaning the coils and fan under the refrigerator.
You would not believe how many refrigerators and freezers I've worked on which required nothing but a good coil cleaning. The dirtier these coils get, the less efficient the unit becomes until it reaches a point that it almost appears as if the refrigerant unit is not working at all when all it really needs is a good cleaning.
While you're under there, be sure the fan is running to pull air over the coils to cool and condense the freon inside them.
Sep 11, 2009 | Refrigerators
GE GDS18LBP bottom Freezer - Refrigerator not cooling
heatman101
dl;
Feb 17, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Amana SXD524VW Side by Side Refrigerator Logo
536 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
