Question about Sony MEX-1GP CD Player
I need the wiring color codes for a sony xplod cd player model MEX-1GP the codes for the plug coming out of the back of the head unit thank you
  • 10,594 Answers
Click Sony Support to download required connection manual copy.
Thanks.
Posted on Sep 29, 2010
Need help installing xplod mex bt39uw
You have to invest in separate cables to the booster amplifier. Be careful that you have the proper relays and fuse for these or you might end up losing your car because of fire.
Mar 17, 2014 | Sony Xplod Mex-bt39uw In Car Audio...
How do i connect my blackberry curve to the sony mex 2500. Bought of ebay,no operators manuel. Regards
Easy!
1.) Turn off Stereo with the upper left button.
2.) Press and hold the EQ button just below it. the BT symbol will turn off, keep holding it, it will turn on, and then flash. when it flashes it is in pairing mode.
3.) go to connections/ Bluetooth on your phone and search for it. it will show up as XPLOD.
4.) the pairing code is "0000" enter and it will tell you connected xplod
to listen to music make sure it is in BT Audio, Also call quality is not that great, but it is an awesome unit to listen to some slacker/pandora over Bluetooth!!
Jan 05, 2010 | Sony MEX-BT2500 CD Player
How do I install the Sony MEX-BT2500 wires?
http://www.docs.sony.com/release/MEXBT2500_install_EN_ES_FR.pdf
Here is a link to Sony installation wiring for your MEX-BT2500. You didn't say what car that you're installing in.
Oct 17, 2009 | Sony MEX-BT2500 CD Player
I recently formated my sony mex 1 gp head unit, and right now it is not able to read files copied onto it.
When you formatted it you also removed the default embedded players software. In the manual look up which player was incorporated into this player. All you should have formatted is the memory, now you will have reload the software for this equipmentand only an authorized Sony Service Center will be able to do that because that software is a patented one and you will not get it enywhere, even from the net.........sodeep
May 24, 2009 | Sony MEX-1GP CD Player
I need a color code for a Sony Xplod CDX-GT23W.
Guessing that you don't still have the owners/install manual.
On the back of the head unit there should be a group of unused/unconnected wires (with any luck they will be marked), one or more might be an amp turn-on or power antenna lead, so I suggest (with the unit turned on) testing each wire with a DC voltage tester so as to identify and separate any leads supplying 12+ volts. the remaining group will consist of speaker leads. Trial and error testing will determine the proper L & R rear speaker leads.
Good luck
Aduz
Mar 30, 2009 | Sony XPLOD CDX-GT200 CD Player
Wiring color meaning
did you buy a factory radio connector to connect the old harness to the new radio wiring if not you can get one at wall mart for 20 dollars and it will be color coded
Mar 08, 2009 | Sony XPLOD CDX-GT200 CD Player
WIRING
This is the complete installation manual for a Sony MEX-5DI which includes the wiring and color codes.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 09, 2008 | Sony MEX-5DI CD Player
Sony mex 2600.
The red wire needs to be conneted to an ekectrical system that is only on when the car is on. Try running a wire from the head unit into the fuse of a system that only works when the ignition is on. like the horn, turn signals, or cigarette lighter.
Apr 02, 2008 | Sony MEX-BT2500 CD Player
Sony MEX-1GP getting warm
It's common for head units to run extremely hot when driving all 4 channels from the internal amplifier. If you can get some air flowing over the heatsink, it will help greatly. The smallest fan you can find will move enough air to reduce the temperature significantly (assuming it's placed where it can be effective).
A better option would be to use an external amplifier.
Dec 09, 2007 | Car Audio & Video
Sony MEX-1GP CD Player Logo
472 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
