Question about Samsung YP-U3 MP3 Player
Won't turn on.
Sometimes my mp3 player won't turn on. I can press the power switch, but it only flashes blue at the side and doesn't turn on. I can also plug it into the computer, it does the same. I don't want to have to return it if there is a solution available but I will if that's what it takes. :[
  • Cat McKeown
    Cat McKeown May 11, 2010
    is this all the time? cuz your post says sometimes.
  • 8,596 Answers
Firmware upgrade:
Posted on Jul 06, 2008
Marclla, Check the attached links,instruction and guides to get IPOD up and running, Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
My iPod Touch 5th generation won turn on
If your iPhone iPad or iPod touch doesn respond or won turn on
Fix iPod won turn on problem Quick Fix
Apr 01, 2016 | Apple iPod touch
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
My sansa SanDisk 4gb player locked up and won't do anything
Slide the power switch up all the way and hold it there for fifteen seconds or so. This will reset the player.
If this doesn't, please reply to this post and we can go from there.
Dec 02, 2011 | SanDisk Sansa Fuse MP3 Player
Don't start
If you mean it won't start up, to the left of the screen there is one slide button, briefly press it down, and it will start. :D My apologies if this doesn't help..
Aug 22, 2011 | Philips GOGEAR SA6045 MP3 Player
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
My mp3 from time to time would shut off or the screen would go black and won't shut off.
Same problem I had awhile back, make sure you don't have a memory card inside the player when you turn it on. It boots up in an incorrect order and doesn't start. To turn it off when it's stuck in that position I believe I held the sliding power button to "On" for 15 seconds.
May 10, 2011 | SanDisk Fuze MP3 Player
If your iPod nano won’t turn on or respond
1) Make sure the Hold switch is off.
2) If that doesn’t work, connect iPod nano to your computer’s USB or FireWire port. Your
iPod nano battery might need to be recharged.
3) If that doesn’t work, your iPod nano might need to be reset.
a) Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
b)Press and hold the Center and Menu buttons for at least 6 seconds, until the Apple logo appears.
4) If that doesn’t work, you might need to restore iPod nano software.
Mar 12, 2008 | Apple iPod nano
Samsung YP-U3 MP3 Player Logo
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
