Question about Gateway PGA370 E139761 DIMM Motherboard (4000700)
Has pc100 128mb and tried to go to Pc133 and wouldn't accept, what is the max memory i can put on this board
    Genius:
  • 1,066 Answers
The details of that board are sorta sketchy, it could be an intel 810 series or 815 series. theres really no way to tell except by opening it up and looking for the largest exposed ic chip with intel stamped on it, and look for an 810 or 815 designation on that chip.
if its an 810, it may not support pc133 ram, depending on the exact 810 model. if its an 810, it also will not support more than 256 total ram.
if its an 815, it will accept 512 total ram, if not more; however, you will have to go with no more than 4 ram sides- meaning, if you have 2 double-sided ram sticks, you will not be able to add anymore. if you have 2 single sided sticks, and a 3rd ram slot open, you may be able to add a double sided stick in the empty slot for 1+1+2=4 ram sides.
Posted on Sep 30, 2010
Hi can I add 2G ram for this mother board
Yes. When the manual was created 1GB pc133 sdram modules weren't available yet, but they said when they did come out that the bios would support them so the max ram you can have is 3GB.
Here is an excerpt from the manual:
System Memory Type/Speed SDRAM DIMM - PC133 Only
Current Maximum Memory 1.5-GB
Maximum Memory 3-GB (when 1-GB PC133 SDRAM
are available)
Memory Parity Not Supported
ECC Memory Supported (Intel 845 chipset does not support
mixing of Non-ECC and ECC PC133 memory)
Here is the manual:
http://h18000.www1.hp.com/products/quickspecs/10946_div/10946_div.HTML
Aug 15, 2012 | Compaq (252608-001) Motherboard
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
My QDI advance 9 doesnt accept 256 mb pc133, i have single and duo sidded 256 mb pc133 and the maximum it gives to me is 128 mb per slot.
Go to this link http://www.epinions.com/S0478496-Advance_9/display_~full_specs
It shows that the Max Memory that it supports is 768mb, It is possible that the memory doesn't want to work together.
Try putting them in, leaving a slot open in the middle. Duo module in slot 0 and single in slot 1.
If doesn't work try the opposite way around.
your timely rating of this soloution is much appreciated.
Thanks
Nov 01, 2010 | QDI Group QDI Advance 9 Motherboard
How to install 2gb RAM ? I currently have 512.
Your board has three 164 pin DIMM slots and will accept 1 GB modules (at the largest) in each slot (Max 3 GB).
Look for PC133 164 pin DIMM modules and consult your manual for correct configuration. A 1 GB module in the first and second slot would give you 2 GB of RAM.
Jan 26, 2010 | MSI 845 PRO Motherboard
Can't upgrade memory
According to the user manual for your laptop, it can only support pc-100 memory. If your going to upgrade your memory just make sure you use pc-100 and also the max amount of memory is 256mb in each slot so you would be maxed out at 512MB.
You can verify the info from this link from Dell:
http://support.dell.com/support/edocs/systems/latc600/en/ug/features.htm
May 23, 2009 | Dell Computers & Internet
ASUS MOTHERBOARD P4X-X CAN USE ddr 400
pls see ur specs here
http://www.baber.com/motherboards/asus/asus_p4xp-x.htm
ur board only support following RAM specs u cannot use DDR400
Memory
  • 2 x 168-pin SDR DIMM Sockets support max. 2GB PC133/PC100 non-ECC SDRAM memory
  • 2 x 184-pin DDR DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM
pls rate me FIXYA for this help if u like
Mar 13, 2009 | ASUS P4XP-X Motherboard
Acer Travelmate 529atxv states max memory as 512mb
512mb is the max memory amount this computer will accept.
Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot. Two slots total. Hope this helps.
Mar 07, 2009 | Acer TravelMate 529ATX Notebook
How much memory the motherboard ASUS INTEL 815E CUSL2-M SUPPORT?
no you couldnt, the max supported ram on the board you have is 512
Maximum 512MB PC133/PC100 non-ECC SDRAM
http://www.motherboard.cz/mb/asus/CUSL2-M.htm
Dec 10, 2008 | ASUS Intel 815E Chipset CUSL2-M...
Max ram for SY-K7VEM PRO
Two SDRAM DIMM sockets support up to 512MB
168-pin PC133/PC100 non-ECC, unbufferred SDRAM memory
This is what your M/board can use in memory
Aug 20, 2008 | Soyo Sy-K7Vem-Pro Motherboard
Computers & Internet Logo
118 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
