What is error 9 on linotype hardware rip 50 - Computers & Internet
I cannot find Habitat Linotype complete skateboard anywhere! Every single site is sold out. When is the next shipment?
You'll have to ask the manufacturer. FixYa has no access to another company's manufacturing/shipping records.
Oct 17, 2013 | Habitat Linotype Skateboard Complete
50 inch panasonic viera blinks 9 times no power
That's a error code but its different for various models. I will need the model number of the set in order to let you know what the 9 blink error indicates for your model Panasonic.
Jan 10, 2013 | Televison & Video
Erro code 900.00 service RIP soft ware. What is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dell 5310n: error message is 900.00 service RIP software A few of my users were having trouble with a Dell 5310n printer. The error message on the display was error message is 900.00 service RIP software. When printing large data files, such as a PowerPoint presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the print jobs and send them directly to the printer. This seems to have corrected the issue so far.
Since I have HP printers on the same print server and none of them have had any kind of issue printing the same large files, I starting to think that the problem is due to either bad printer hardware or print drivers from Dell.
http://itadmindev.blogspot.com/2008/07/dell-5310n-error-message-is-90000.html
Feb 03, 2010 | Dell 5310n Laser Printer
Erro code "900.00 service RIP Soft ware. What is this?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what I foudn working on the same problem....
Lexmark C510 not printing - message 900 service RIP software
Hi, This error could be due to several things, the most common one is that whatever is being sent from the computer is not being recognized by the printer causing the 900 Rip Soft Error. You can try to reset the printer and try sending the print job again. If the error persisted. Then the problem could be a hardware problem with the System Board.
Jan 13, 2010 | Lexmark C510 Laser Printer
Will a Linotype Hell Ultra 2 Saphir run on a pC?
Yes. Just got mine running on Windows ME. Problem is getting the SCSI set up. Once you get that done, I used Vuescan (http://www.hamrick.com/) and it works. Slow, but functional. I have yet to get scans of the full scanner screen (10 x 14 inches). But 8 x 10 is working fine.
Sep 10, 2009 | Heidelberg Linocolor Saphir Ultra2 Flatbed...
Why does it say error when i put on song onto my gpx mp3 player?
sEVERAL POSSIBILITIES:
* You downloaded protected music on your Windows 98/98SE, Windows 2000, Windows XP computer using Windows Media Player 9. Music was purchased online or the music was ripped form your own audio CD with Copyright Protection turned ON.
o You must use Windows XP and Windows Media Player 10 for online purchased songs.
o You must turn OFF Copy Protection on your Windows Media Player 9 before ripping your audio CDs into WMA files
* You downloaded protected music to your MP3 player using your Windows XP computer and Windows Media Player 10 with your player in USB mode. Music was downloaded from the internet, purchased or subscribed, or it was ripped from your own audio CD with Copyright protection turned ON.
o You have to use your MW3836 in MTP mode.
-Tha Mp3 Doctor
Nov 27, 2008 | GPX MW3836 MP3 Player
Disney mix max problem
Connect your player to the USB port on your computer using the USB connector on the Mix Max. A 'MIX-MAX' window will appear in your My Computer folder which is the player's internal memory. To add more files and songs to your player simply drag and drop MP3 or WMA files from anywhere on your computer into the 'MIX-MAX' window.
For Windows XP, you can utilize Windows Media Player 10 software to convert music on an audio CD into MP3 or WMA format as follows:
Open the Windows Media Player 10 Browser, then click on the 'Rip' icon on the top tool bar. Insert a Music CD into the CD-ROM drive of your computer.
Click on the 'Tools' menu option at the top menu bar, then click on 'Options'; the Option setting menu will appear. Click on Rip Music and set the Rip music to the desired location on the newly ripped music (MP3 format or Windows Media Audio format). Adjust the audio quality as desired. When finished, click 'OK' to confirm the settings.
Click on the 'Rip Music' icon to start ripping the music to your computer.
When the music tracks are ripped; connect the player to your computer. Open the 'MIX-MAX' window and open the ripped music location window.
To add the transferred/ripped music file/songs to your player simply drag and drop the MP3 and/or WMA files into the 'MIX-MAX' window.
When the files are finished loading into the player, follow the 'Safely Remove Hardware' procedure as shown below.
Note: For Windows 98SE, Windows ME, and Windows 2000, please use the Windows Media Player 9 to convert music on an audio CD into MP3 or WMA format.
Downloading WMA files with DRM using Windows Media Player 10 (for Windows XP)
To download WMA files with DRM, follow the procedure described below using the previously installed Windows Media Player 10. Before beginning the procedure please turn the unit on and connect the unit to the computer as previously described.
Open the 'Windows Media Player Browser 10' and click on 'Sync'.
Click on the 'Sync List' pull-down menu to locate the music files you wish to download. Then make sure to click the box next to the files.
Select the Portable Device that you want to copy to from the right side drop-down menu. Click 'Start Sync' to start downloading the WMA file(s) with DRM to the Portable Device.
After finished downloading all the desired files to your unit, follow the 'Safely Remove Hardware' procedure as shown below.
Note: For Windows 98SE, Windows ME, and Windows 2000, please use the Windows Media Player 9 to download WMA files with DRM to your player.
Jun 16, 2008 | Disney Mix Max Digital Media Player
Unable to print 50
The MFC has a mechanical problem, or a foreign object, such as a clip or ripped paper, is in the MFC.
Turn off the MFC's power switch, and then on again. If the error message continues, leave the MFC for several minutes and try it again.
Apr 12, 2008 | Brother DCP 7010 Multifunction Laser...
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
