Question about Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522
What setting must the top and lower temperature comtrol on the tank must be set
  • 56 Answers
They will normally set these at 120 but according to your needs you could go a little more or less but be careful if you go higher of the temp coming out of the faucet with just the hot on. Good luck!
Posted on Oct 02, 2010
Electric water heater. water not hot enough
Check if tank is hot.
Open drain valve at bottom of tank, and then raise TP lever at top of tank.
If water is about same temperature both top and bottom, and water temp at tap is cooler, then turn up temperature, and check for crossover and broken dip tube.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
If water in lower part of tank is very cool compared with top, then you want to test elements, replace thermostats, and clean sediment out of tank.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Add a comment as needed while you work on tank.
Sep 22, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Lower thetermostatv temprature to 66. it's set to 77 right now and doesn't go lower
Question is not clear.
Add a comment and say what you want to do.
You have 240Volt electric water heater.
Lower thermostat is set as low as it can go at 77.
But you want water temperature set to 66?
First thing to remember is that water heater thermostat settings are approximate since they read temperatures through the steel tank wall.
Second thing is that thermostats for electric water heater are generic, and are not made for lower temperature range settings. This is probably since most people complain that water is not hot enough.
I'm looking at a generic lower thermostat from Lowes right now. The low temperature setting is 90 degrees F.
Looking at some older thermostats from a drawer right now: one does not have a lower temperature mark, the other is a Reliance with low temp of 95, the old craftmaster goes down to 80.
So I don't even have a thermostat that goes as low as the one you have, except for gas water heater thermostats that traditionally can be set to 50 degrees for vacation mode to prevent freezing.
More thermostats can be seen on following link:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Jul 12, 2011 | White Rodgers 0754-1 Electric Water Heater...
How do I turn up the water temperature on a Marathon 85 gallon electric water heater? I don't see any visible temperature control settings.
The temperature is controlled on the thermostats in the tank. They are under the two covers you see on the outside of the tank. There is an upper and lower thermostat. Make sure you shut off the power before you begin. Remove the cover and peel back the insulation covering the thermostat. Use a flat head screwdriver to adjust temp. There should be a pointer showing the temp its on now. They are probably set at 120 degrees. WARNING--turning your hot water temp above this point can cause scalding and burning in less than 3 seconds. You may have a burnt out lower element. This link below should help you
http://globalimageserver.com/fetchDocument.aspx?id=574f6c2f-32c1-4c28-824c-172bbbfe5578
This is the manual to your tank. Good luck.
Apr 23, 2011 | Rheem MSR50245 Marathon Electric Water...
Replaced both elements and tstats now there is 240 at both elements at once and only the top one is heating the bottom is coldreplaced bottom sgain thinking maybe bad from factory but still cold will i...
Electric water heaters never power BOTH the upper and lower elements at the same time.
If the water in the tank is cold, either the top OR bottom element will be powered through the upper thermostat (t-stat), never both at the same time. The upper t-stat will send power to the upper element until the temperature of the water in the top of the tank reaches the set point of the t-stat say 140 degrees. When the water temperature in the top of the tank reaches 140 degrees, the t-stat is "satisfied" and disconnects the power from the top element and sends it to the lower t-stat.
IF the temperature of the water in the lower half of the tank is lower than the set point of the lower t-stat, the t-stat closes to send power to the lower element. The lower element REMAINS powered by the t-stat until EITHER the water in the lower part of the tank reaches the set point temperature of the lower t-stat again, say 140 degrees; OR the temperature of the water in the upper part of the tank drops, at which point the upper t-stat "calls" and switches the power away from the lower t-stat and sends it to the upper heating element instead. When the top t-stat is satisfied, it switches power back to the lower t-stat. The process will continue back and forth for as long as needed to bring the temperature of the water in both halves of the tank to 140 degrees.
You must wait until the top of the tank is heated - before the lower element will be powered to heat the water.
I hope this helps you understand how the switching happens in these water heaters. Good luck! Please rate my reply. Thank you.
Mar 24, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hi...I have a Whirlpool water heater and the water only stays hot for a few minutes. How do I adjust the temperature or settings so that I can have hot water all the way through the shower instead of...
I am guessing this is an ele water heater and the temp setting are not the problem.
Problem: Not enough hot water or water temperature too low. When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
The dip tub is located under the fitting where the hot water comes out.
Feb 03, 2011 | Whirlpool Water Heaters
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
Dec 19, 2010 | Rheem Water Heater Pressure Relief Valve
What is the energy factor for the mod.82V80-2? I have two seperate 30amp circuits, one for the top element and one for the bottom element, if that changes anything.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
http://globalimageserver.com/fetchDocument.aspx?id=052c9e32-ce37-48d7-8990-9e430f23fef3
82V80-2 Energy factor is .86 according to water heater industry self-regulated standards.
Rheem pdf says these water heaters are wired for non-simultaneous operation.
Except special order water heaters.
Non-simultaneous operation uses single 240V circuit as described below.
If your water heater is wired for simultaneous operation, and each element is on a separate circuit, that makes your water heater special order. I would guess the reason is for higher first-hour delivery, which implies rapid heating and would likely affect energy factor.
You might want to get serial number off model and call Rheem for specs on that special order.
Your water heater energy factor may be the same because 'energy efficiency is based on the amount of hot water produced per unit of fuel consumed over a typical day.' This means an aircraft carrier can be considered highly efficient despite overall cost. And naturally the guys making the aircraft carrier are also doing the rating.
http://www.energysavers.gov/your_home/water_heating/index.cfm/mytopic=13000
Non simultaneous operation means the upper thermostat controls heating functions.
240V goes to upper thermostat first.
When water inside tank is cold, thermostat reads temperature through tank wall.
Upper thermostat turns on upper element until top 2/3 of tank reaches thermostat set point.
Once set point is reached, upper thermostat turns off upper element and sends power to lower thermostat and lower element.
Lower thermostat reads temperature through tank wall, and turns on lower element until bottom 1/3 of tank reaches thermostat set point.
As water cools inside tank, lower thermostat is first to respond since hot water rises.
Lower thermostat turns on lower element until tank again reaches set point.
When hot water faucet is turned on, hot water exits top of tank.
At same time, cold water enters bottom of tank through the dip tube.
The heating cycle repeats.
At all times, the electricity flows through upper thermostat. And upper thermostat is powered by one 240V circuit.
With simultaneous operation, the upper and lower thermostats work in same manner.
Except thermostats are wired separately.
Lower thermostat does not wait for upper part of tank to be heated first.
Lower thermostat turns on whenever lower part of tank cools.
The advantage is more hot water available rapidly when demand is high. This is called first hour recovery.
One method for reducing electric consumption is to set lower thermostat so it only turns on during certain times of day. For example Whirlpool Energy Smart operates in this manner and shaves a few bucks off the bill each month. This says that simultaneous operation is not an energy saver, unless that circuit controlling lower thermostat is set on a timer.
Dec 06, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Energy smart hot water heater not giving ample amount of hot water both elements ohm at 12.5
For images and product information
For manual
You checked ohms, did you check for 240V across lower element when lower element is turned on?
Energy smart electric water heater
has a control box on top of unit. Water heater does not have typical thermostats that can be tested and replaced. Temperature sensors located above each element send information to control box through small black and red wires. Temperature sensor sells for about $40, but there is no test listed that shows how to determine when sensors fail.
Potential problems:
-Temperature sensor is not reading correct temp
-Control box not processing correct temperature information
-Selector on control box set to 2, 3 or 4
-Thermostat temp on control box set lower than 120 degrees F
-Sediment build-up starting to surround lower element so water doesn't circulate (see if drain valve runs full-open
Oct 08, 2010 | Water Heaters
Top element only working
How they work. First you need to know that cold water goes into the tank near the bottom (because of the "dip tube" inside the tank) and hot water is taken out at the top. Also hot water naturally rises.
so... when the tank is full of cold water the top element will come on and heat up the top 1/3 of the water then the bottom element will come on and finish heating the rest of the tank.
so... set them both at the temperature you want the water to be... about 120^F.
Apr 02, 2009 | Water Heaters
Temp keeps fluctuating
sounds as though it could be a cental heating thermistor prob, you dont say wheather its the boiler unit or the remore programmer?
Dec 02, 2008 | Water Heaters
Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522 Logo
50 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
