Question about Teac EQA-220 Home Equalizer
I want to know how to connect it to my amplifier
Ok, i interested in the technics se a900s amplifier, just for vu meter use, not amplifier,and...
Pre-amp only needed for phono. Otherwise, line in is just fine.
10 to 20 ohm load resisters to substitute for speakers. get 50 watt rated ones at least, they can get hot....
May 12, 2016 | RCA Car Audio & Video
How do hook up an amplifier and subwoofer to my car stereo?
If your stereo has preamp outputs, I would recommend connecting those to the input RCA connections on the amplifier. The connection from the amplifier to the subs is dependent on the capability of the amp and the impedance/power level of the sub.
Aug 31, 2014 | Car Audio & Video
How to daisy-chain my Pyle amplifier with my KLH amplifier
as u do not state models here goes:
one or both amplifiers could have a stereo rca output, connect the output of the amplifier that gets signal from the head unit to the input of the other amplifier.
DO NOT share ground cables or power from one to the other (these cables should both run separate from a distribution block AND not from one amp to the other,
........do not connect both amplifiers to only one driver.........
hope this helps, let me know if you need more assistance.
....andy...
Jan 06, 2014 | Pyle Car Audio & Video
I need to know how to hook up my pyle pla4278 4 ch 2000watt bridgeable mosfet amplifier
Hi, I assume you are powering regular speakers in the car, right?
The amp needs a power cable from the fuse box or battery.
This cable should be about 6 gage and should have a fuse of about 150 amps.
You will need a ground cable, also 6 gage and connect it tightly to the chassis under the dash.
Disconnect all speaker wires from the head unit, and use a pair of RCA cables to connect the head unit preamp outputs to the amplifier.
Also from the head unit, connect the blue wire to the "turn on" terminal of the amplifier.
Finally, connect your speaker wires to the amplifier.
Your speakers should be rated for at least 500 Watts, or you will blow them with this amp.
Please let me know if you have questions and thanks for using FixYa.
Jan 12, 2011 | Pyle PLA4278 Car Amp
I have been given an old Sharp music center but dont know how to connect the speakers to the amplifier sockets on back of amplifier look like this L I I R but I dont know how to put...
l means left r means right connect speaker wires by phono sockets or if no phono sockets then the wires go direct into the colour sockets red to red etc
Jun 08, 2010 | Sharp SX9860 2-Channel Amplifier
Don't know to conneect my amplifier connecting firdt a soundstream ecualizer
What are you running in to your amp? If it's a CD player or radio, find the wires from them, disconnect them from the amp and connect them to the equalizer, then connect the equalizer to the amp.
May 08, 2009 | Car Audio & Video
How do I connect a subwoofer to an amplifier marantz pm-68
double up the speaker and then use the two extra screw to hook sub and center
Feb 10, 2009 | Marantz PM-68 Amplifier
Kole kx2-1440 wiring da amp up right
It is correct to connect the amp turn on wire to the amplifier remote. 5V is sufficient to turn most amplifiers on... It should be 12V optimally.
If the amplifier is not turning on with the ant. remote, the problem is with the amplifier.
Dec 30, 2008 | Kole audio QX1-2400D Car Audio Amplifier
How do i conect equalizer
first connect pre-amp out to equalizer in and equalizer out to amplifier in-and amplifier to loudspeaker.
second-mixer out to equalizer in and equalizer out to amplifier in and amplifier out to speaker.
Jun 15, 2008 | Audio Players & Recorders
Bose 901 v1 adding a amplifier
You may connect an additional amplifier to the Rec Out or Line Out from your existing receiver.
Please note the Bose 901 equalizer can be used to connect to one amplifier only.
Do let me know if you have any further questions.
Nov 28, 2007 | Bose 901 VI Main / Stereo Speaker
Teac EQA-220 Home Equalizer Logo
42 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
