Question about Compaq Presario Notebook
Hi, I have a compaq CQ50 and it shuts down when the screen is moved. NO clue how to fix this. It is out of warranty by 8 months. Sometimes if the screen is moved it will just go to sleep other times it shuts down completely but I don't have to push the power button to turn it on I just have to wiggle the screen
  • Compaq Master
  • 11,800 Answers
The wires to the screen are frayed and short when moved. You should fix that ASAP, or you will end up with a fried laptop.
Posted on Sep 29, 2010
Cq50 flicker
Disconnect the power cord and battery. Hold down the power button for a minute and then connect only power cord.
If not fixed:
Please scan your computer with free version of superantispyware:
http://www.superantispyware.com/
IF not fixed: It is a screen hardware issue.
Jul 09, 2013 | Compaq Presario CQ50-215NR Notebook
Hp cq50 reboots
1.)Do the Hard Reset (Shut down the laptop and remove battery and unplug the adapter for 30 minutes)
2.)Did the BIOS Default and restart the laptop.
3.)Disable the Windows Updates.
4.)Perform the System Restore
hope this will fix the issue.
Do respond asap....
Feb 27, 2012 | HP Compaq Presario CQ50-130US Notebook
Mouse stopped working on Compaq Presario CQ57
The Touch pads the Mouse Pointer uses is pressure sensitive and sometimes without warning WILL fail to work I own a CQ50 And Have a On Off Option for the mouse pad Yours does not Apparently it Is a bad sensor If you have a warranty send it in If not best suggestion for you is buy a USB mouse and use it Otherwise trying to have it replaced without a warranty can be costly.
Feb 03, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
My Compaq Presario CQ50-103NR Notebook PC keeps shutting down. Sometimes right away sometimes after a few minutes. The left side of laptop seems to get hot while the right side stays cool. Can You please...
Hi:
You most likely have a heat problem, as you have realized. To fix the problem, your heatsink/fan assembly needs cleaned, and then reinstalled with new heat sink compound. Some disassembly is required, so this isn't an easy job. If you go to a reputable shop, and tell them what you want them to do, rather than just tell them your laptop is shutting down, you should get it done for a fair price!
Apr 23, 2010 | HP Compaq Presario CQ50-103NR Notebook PC
I have a compaq cq50-107nr that randomly just shuts off what can be the cause
Check the temperature when it shuts down. Are the airflow oppenings clear?
Stelios.
Feb 23, 2010 | HP Compaq Presario CQ50-107NR Notebook
My compute will not turn on
The laptop might be overheating, sometimes when the laptop cant get any ventilation it shuts down and will not properly power up till the temperature issues are delt with.
But you usually get at least a few seconds of power before it shuts down again, so it may not be that, sounds a bit more like the CPU is dead and will need replaced.
Jan 03, 2010 | HP Compaq Presario CQ50-110US Laptop
2 Lines on my Gateway laptop when I turn on my computer
To be honest, I would have Compaq repair it. If it's only 6 months old it is under warranty, USE the warranty. It sounds like the screen has a short or the cable does. Make Compaq fix it.
Sep 08, 2009 | Compaq Presario M2000 Notebook
Broken fan on compaq
don't keep running it until you replace the fan. Look for one on ebay or around the web. It is shutting down because of heat. A $20 fan could cost you your whole laptop if you keep running it.
Jun 03, 2009 | HP Compaq Presario CQ50-110US Laptop
Compaq presario laptop screen flickering
Hi there.
It sounds like you may have a loose inverter cable or the ribbon cable behind the screen is loose.
Is the machine in warranty? I
May 29, 2009 | Compaq Presario CQ50-215NR Notebook
Compaq Presario CQ50 Labtop, makes awful constant beeps
If you shut it down when WinFlash was running, then bad news - BIOS corrupted. This means faulty motherboard. Solution - replace motherboard.
Mar 11, 2009 | Acer TravelMate 2480 Notebook
Compaq Presario Notebook Logo
85 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
