Question about Porter Cable Portable Generator BSV750
I have a 7500 Watt Porter Cable Electric Generator that isn't producing any electricity. We are able to turn it on and it sounds great while running but it doesn't power anything we plug into it. Any help or advice as to how I can fix it will be greatly appreciated. Thank you!
    Problem Solver:
  • 10 Answers
Have you checked to ensure the GFI outlet is not tripped?
Posted on Sep 30, 2010
  • 1 more comment
  • justinofserv Sep 30, 2010
    Yeah we have checked the GFI outlet and we plugged the generator into a spider box too hoping that we could get something out of that but its not giving us any power.
  • ajcaminitijr Sep 30, 2010
    The generator likely uses a self-exciter circuit to make it start generating some power to get the field winding energized enough to start the flow of power. Some gens use brushesin the ciruits and might be bound or worn. Look for specific maintenance instruction in the manual . Brushless types use small magnetized cores to start the power generation and then are self sustained when the the generator output starts to rise.. Worth a look see if you have done all the easy stuff and checked for any blown control fuses(as opposed to output breakers)
  • mrfixit96 Nov 18, 2010
    Hi' I just repaired one with the same problem. The one I did had a bad capaciter in it . I replaced the capaciter and I had full voltage.
    I hope this is a help.
What type fuel does a 5250 porter cable generator take
From p.10 of the manual
"Check fuel level, fill as required. Make sure generator is turned off and has been allowed time to cool down. Use clean, fresh, regular unleaded gasoline with a minimum of 87 octane. Do not mix oil with gasoline".
(taken from bottom of this webpage
http://www.cpoworkshop.com/porter-cable-bsi525-w-5-250-watt-electric-generator/pcbnbsi525-w,default,pd.html?cgid=porter-cable-delta-discontinued )
(Is this your exact model ?)
14.April.2014
Apr 14, 2014 | Electrical Supplies
Porter Cable BSI550 W 5,500 Watt Generator With 10 Hp Engine No AC output
Sounds like the generator unit (sometimes called the generator head) has overheated and melted the insulation in the windings. This is the same as an electric motor "burning out", and if this is the case, then the generator is toast. If you happened to notice that the lights or fans were getting dim or slowing down before the breaker tripped (without the gas engine slowing down) then this is most likely the case and you generator is toast. But if the output just suddenly quit, then it is possible that some smaller electrical component has failed. In any case, it's not something external that you can easily reset or replace. Sorry for the bad news.
Jun 13, 2012 | Porter Cable BSI550 W 5,500 Watt Generator...
Will not start
That is either valve timing or a failed ignition stator. The stator will send the fire signal to the spark plug at the wrong time and hence the backfire.
Dec 06, 2011 | Porter Cable BSV750W 7500 Watt Electric...
Throttle on generator question
The idle control switch allows the generator to go into idle when there is no demand form the appliances connected. This saves gas and increases the life of the generator. Damage can occur for some appliances like a refrigerator/freezer because the voltage and frequency are not prepared for the load resulting in a low voltage bad startup that will damage the appliance. Suggest that you leave the idle control switch off while any motor/electronic devices are connected.
The throttle control is likely a choke function for starting. These generators are designed for only one running speed to produce the necessary 60 cycles per second and voltage.
The following link is to a Canadian web site that later in the detail report describes the concern of idle control. In addition it provides good insight to the operation and use of portable generators
Hope this helps?
Understanding Portable Generators
The user manual see pages:
http://www.mikestools.com/download/Porter-Cable-Manuals/Porter-Cable-CTE300.pdf
May 06, 2017 | Porter Cable Portable Generator BSV750
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Porter Cable Portable Generator BSV750 Logo
238 people viewed this question
Top Porter Cable Welding Tools Experts
Bill Boyd
Are you a Porter Cable Welding Tool Expert? Answer questions, earn points and help others
