Question about Sony Walkman NWZ-B142 MP3 Player
Cannot access the equalizer.It displays "cannot execute" when selected
  • 34 Answers
Turn the bass off first.
Posted on Oct 28, 2010
How do I change the font size
Hello,To change the font size, do the following: 1. Press the “Function” key 2. Press the “Left Arrow” or the “Right Arrow” key until the display shows “SIZE”. 3. Press the “Function” or the “Return” key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display. 4. Press the “Left Arrow” or the “Right Arrow” key until the desired Size is displayed. * SIZE1 equals Standard Size. * SIZE2 equals Double Width. * SIZE3 equals Double Height. * SIZE4 equals Double Width & Double Height. * SIZE5 equals 4 x Width & Double Height. * AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine. Press the “Function” key or the “Return” key to select the characters size. I hope this helps.
Jan 04, 2016 | Brother P-Touch Brother Pt90 Label Maker...
How to change langeuage of Sharp VL-Z5 Mini DV Digital Camcorder
turn camera on, (on record side.) then press display button, go to menu, then select execute, press execute, that will bring you to settings 1 scroll down, the menu will get longer. you will find language selection there. .
Oct 17, 2011 | Sharp VL-Z5 Mini DV Digital Camcorder
My KM-2035 appeared error call service C6000 on my copier.
on the nunber keys, key in 10871087 the display should blink then enter 163 then;
1. Press the start key. The screen for executing is displayed.
2. Select the EXECUTE using the up/down cursor keys. The selected item is displayed in reverse.
3. Press the start key. The fixing problem data is initialized.
Jan 16, 2011 | Kyocera Mita Office Equipment & Supplies
Brother p-touch model 1880 label maker- how do you change the font size
1. Press the "Function" key
2. Press the "Left Arrow" or the "Right Arrow" key until the display shows "SIZE".
3. Press the "Function" or the "Return" key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display.
4. Press the "Left Arrow" or the "Right Arrow" key until the desired Size is displayed.
Press the "Function" key or the "Return" key to select the characters size.
I hope this helps.
Aug 09, 2010 | Brother P-Touch 1180 Label Printer
I HAVE A SIMPLE SONY IC RECORDER, IT TELLS ME THE MEMORY IS FULL, I DO NOT HAVE A FUNCTION BUTTON ON MY MENU OPTIONS, HOW DO I FIX THE PROBLEM.
2 Press ^/V to select "Format" and press >[]. The window for selecting the memory to be formatted is dysplayed. ^/V Select Built-in or MemoryStick and press >[] the window for executing format is displayed ^/V Select execute and then press >[] The confimation window is displayed ^/V Select "YES" and press >[] After you done press [] STOP to return to normal Display
Dec 10, 2009 | Sony ICD-MX20 Digital Voice Recorder
Hi.I've a canon mp110. on display there's written ''bottom ink absorber is almost full''. I cleaned and changed colours but there's no solution. please help me, thanks
  1. You will include printer.
  2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service mode.
  3. select NVRAM ACCESS and further BY OK.
  4. select SET Abs- m level and advance value equal to zero.
  5. select SET Abs- r level (if there is) and also you will establish into zero.
  6. you will turn off printer by button POWER.
Oct 27, 2009 | Canon Office Equipment & Supplies
Change Radian to Degree on HP 41CX
First of all there is three modes on HP41
You can change between them by executing the functions DEG, RAD or GRAD
To do this press XEC then ALPHA then type in the function name, then ALPHA again. A small sign will turn on on the display in case of RAD and GRAD. After this all trigonometric function will work in the selected mode.
Sep 22, 2009 | Office Equipment & Supplies
When i click on equalizer it says cannot execute. Any suggestions
I think you are having the same problem I had.
I found that if the Bass was turned on then you couldn't access the equalizer.
Once I had turned it off, no probs. To turn it off simply press the bass button on the top of the player.
Hope this helps.
Aug 17, 2009 | Sony Walkman NWZ-B135 MP3 Player
I just bought a sony mp3 walkman nwz-b142f and when i go to the Equalizer it says ''cannot execute'' can you guys help me??
hello i am also using this player only
in order to execute equilizer pls off bass and then try to use equalizer
i am sure now u can find the option
i have read the softcopy of manuall which is available in player.....
its working enjoy!!!!!!!!!!!!!!!!!!!!! hearing songssssssssssssssss.......
Aug 05, 2009 | Sony Audio Players & Recorders
Sony Walkman NWZ-B142  MP3 Player Logo
206 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
