Question about Konica Minolta DiALTA Di200 Copier
I have a minolta ep3000 copier, it has a c0500 error code. I can not find the reset button. can you help? Yeah it's old!
4 Suggested Answers
  • 18 Answers
SOURCE: help
your heat lamp is not turning on, did you change it? generelly some copiers that old may have to disapate charge in the electronics after being worked on. if the copier did not initiate after rebuilding or doing work on the fuser, you may need to actually unplug it from the wall, like a reboot. the electronics are dated 8 to 10 years old. make sure, if it has a power relay or fuse, because of its age , they are good. generally older units will fire back up at off and on. if nothing works, let us kow.
Posted on Dec 08, 2007
  • 990 Answers
SOURCE: minolta coppier 3000 has an error code c0500 and
Hello sir; There are two way to reset, please do it again; remove back panel,find the master board ( PWB-A) press S 1 ( that's a micro switch)on the main board, the another way to reset is jump PJ29 ( that's a pair of pins) need to jump together, turn on power, about 5 seconds later unjumper, the screen will rewd " initialize complete" then press OK. machine will go back to normal.
Posted on Feb 03, 2010
  • 1294 Answers
SOURCE: MINOLTA CS PRO EP3000 COPIER. The copy is too dark
Clean the optical parts:mirrors,lens and the charge and transfer/sepaRATOR CORONAS.
Posted on May 22, 2010
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
C0500
May 01, 2014 | Minolta Di3510f Bizhub Copier
ERORR C0500
Sep 26, 2013 | Konica Minolta Office Equipment & Supplies
Error co500 cspro ep3000
open front door to your left a small access cover remove the screw press the trouble reset button. if the code comes back have a konicaminolta tech look at it, continue reset may start a fire you are resetting code for the fuser the hot part of the copier
Oct 13, 2011 | Minolta EP4000/5000 CS/PRO Copier
The machine di251f is saying contact your technician with code error c0500 please help
C0500: Warming-up Failure
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
Jun 17, 2011 | Minolta Di251 All-In-One Printer
Konica Minolta Di2510 error code C0500,can not reset error code
check the fusing unit parts heaterlamp,thermistor & thermoswitch i'm sure one of them is the cause of error c0500
Nov 22, 2010 | Konica Minolta DiALTA Di183F Copier
I have a problem whith minolta dualta di200,the problem is "error code c0500,can somebody help me?
C0500
The temperature of the Fusing Rollers does not reach
the required level even after the lapse of a given
period of time during a warm-up cycle.
There should be a small opening or hole on the right of the operation panel, use a paper clip to press the button inside. This will reset the machine. If the error code was a glitch or a false code the machine should operate. If the code comes back you will need to have a technician replace the fuser assembly
May 14, 2010 | Konica Minolta DiALTA Di200 Copier
EP3000 error code c0500 will not clear
Sir,
To clear this code requires you to gain access to the System reset. Open front door locate a small panel with one screw to release it in side will find two small black buttons find service and let machine reset if the code persists then your fusers is gone, the EP3000 is a legacy equipment may find a problem in locating spare parts if the thermistor, thermosat or fuser lamp is shot. Ensure machine is on when you attempt above.
Feb 02, 2010 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Help
Dec 07, 2007 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
101 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
