Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Lg bottom freezer is always unpredictable!!?!? many times its on a defrost cycle that we cannot figure out WHY??!!! we are upset opening the freezer to again see all of our frozen foods not so frozen! whats going on??? Help??? rob duffin 480-244-8242
  • robdogg May 25, 2008
    lg bottom freezer is always unpredictable!!?!? many times its on a defrost cycle that we cannot figure out WHY??!!! we are upset opening the freezer to again see all of our frozen foods not so frozen! whats going on??? Help??? rob duffin 480-244-8242
  • kari
    kari Oct 14, 2013
    We seel to be having the same issue. Just noticed today that the ice cream is soft!! The refridg/freezer is only 4 years old!
    Champion:
  • 210 Answers
The LG fridges are all controlled by the board. Depending on the year of your unit, the unit will go into defrost once every 12 hours on the older boards, and once every 24 hours on the new ones. The older boards, were 12 hours, these were also the ones that had the problem. On the back of your unit, open the panel that covers the board, if it is 6871JB1375A it is old and could be the cause for the problem. You will need the xxxx1375D this is the modified board that should solve the issues.
Sgt 48
Posted on May 31, 2008
  • 828 Answers
Your problem of intermittent defrosting in the freezer may be related to a moisture problem in the refrigerating system. System have a refrigerant filter dryer installed which removed the moisture through chemically bonding it. In areas where high ambient temperatures are moisture will be released under hot conditions. A dirty condenser can cause moisture to be released when the system overheats. This moisture will circulate through the system and become as a block in the refrigerant feed. Once it reaches the freezer section it will become solid and hold at that point until it is again freed to circulate such as a normal defrost cycle.
This same condition can be caused if the compressor becomes overheated and cycles off on the thermal overload protector. This problem can be caused by a faulty condenser fan motor, dirty condenser coil, or a fault in the compressor itself.
Posted on May 25, 2008
Bottom freezer iced, what cause?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 29, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Why is there heavy ice buildup in our 2 year old LG bottom freezer refrigerator model LFX25970
heatman101
Oct 24, 2010 | LG LFX25960 Bottom Freezer French Door...
Is bowing of floor between refrigerator and freezer in LG model LFX25960SB fixable?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101...
Oct 06, 2010 | LG LFX25960 Bottom Freezer French Door...
I have LG Bottom Freezer Refrigerator for 5 years. I noticed that yesterday that a funny motor sound came from the back of the refrigerator. When I open the refrigerator or freezer door, the sound would...
The problem could be a bad bearing in the condenser or evaporator fans...more likely though is that the evaporator fan is hitting an ice build up on the coils...this can be caused by a bad defrost timer...
more closely check on the sound... you will find it....
a few drops of oil on the fan shafts just ahead of the motor will not hurt either...
heatman101
Sep 17, 2010 | LG LRDC22744 Bottom Freezer Refrigerator
Its starting to make an whrling nosie but stops when i open the door.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 27, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
LG bottom freezer refrigerator. Cold freezer, Refrig is warm. Working yesterday just fine.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Feb 03, 2010 | LG LRBN22514ST Bottom Freezer Refrigerator
LG fridge/freezer rumbling/vibrating sound
Check your defrost components. The fan is hitting the frost buildup and will shut off when the door is opened so as to not circulate the warm air. The heater or the timer is not doing a proper defrost cycle.
Eric
Jun 24, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
I have a LRFC 22750 SW   LG bottom freezer with french doors.   I have been getting an error message on the digital read out ER on the refrigerator side and I think DH on the freezer side.   I  unplug...
You will get this error code if a sensor does not reach a certain temperature (+8 C, to be precise)within 2 hours of going into a defrost cycle. Increased frequency probably means the defrost build up is causing your refrigerator to run more, which will bring on the defrost cycle sooner, and the error code to repeat sooner. So, it really looks like your refrigerator is not defrosting. Soon, you will have inadequate cooling. A temporary fix to the poor cooling problem would be to unplug the refrig and open the freezer for a day or so to let it defrost on it's own, but the frost will then begin to build up again, resulting in poor cooling, depending on climate and door openings, possible in less than two weeks. Better look for service soon. If you are in the US, you can try http://us.lgservice.com/index_b2c.jsp to find service using your zip code, or call LG at 800-243-0000.
Feb 01, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
318 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
