Question about EliteGroup K7VMM Motherboard
BAD ROM BIOS FLASHING
PC NO LONGER BOOT UP.
Buy an AK-47 assualt rifle then carefully mount *********** board on top a table with a clamp then move back for about 8ft away **** that AK-47 with a banana type magazine load in it like a damn guerilla terrorist that you are and fire away like a mad man... then buy a new pc wala your problem is solve hehehe BWAHIHIHIH NYAK NYAK NYAK
Posted on Oct 23, 2008
Tşk
Posted on Sep 04, 2008
  • 105 Answers
1 Your BIOS is gone. You have to get the MB repaired through reliable source.
2. Check SMPS for working. if SMPS is faulty then system doesnot boot. Check the Mother board for any LED is glowing then you S<MPS is serviceable else first check SMPS.
NB: Disconnect all the cables other than Power cable.
Posted on May 25, 2008
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
BAD BIOS CHECKSUM, STARTING BIOS RECOVERY...
I have seen this be a CMOS battery many times. Also, you can try flashing the BIOS if you continue to have troubles after replacing the battery. You should be able to find that information on the motherboard manufacturer's website.
May 05, 2011 | Computers & Internet
I have a dell gx520 running xp home . I want to dual boot ubuntu but the cd rom will not read from ubuntu disk. It readsxp and music cd's ok so it is not the rom at fault
Make sure you set the BIOS to boot on the CD rom first. You can set it via the BIOS utility. Usually you press the F5 key and then go to boot options. And then place your CD ROM drive on the 1st boot priority.
Make sure also that your CD installer is working and not from a bad ISO download.
May 25, 2010 | Dell OptiPlex GX520n PC Desktop
Dell Dimension 2400 won't recognize DVD-ROM drive as Boot Device.
Enter the Bios and under System Components find the Boot priority in the Bios and move the drive to the top of the list, also you can press F12 at Start up to select it as well. :)
Apr 14, 2010 | Dell Dimension 2400 PC Desktop
Monitor went flashing. Won't boot. Says missing
You need to repair your windows system files.
for that insert windows disk or recovery disk into cd /dvd rom then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then you can see bios configuration page then go to boot menu and set first boot device as cd/dvd rom then save settings and exit from bios .
then it boot with disk follow the procedure on screen then first choose recovery console then type in console "chkdsk /r" it fix and recovers error on harddrive.
Then restart computer then again boot and this time choose R for "Repair previous windows" then it repair it then you can use your windows again.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 02, 2010 | E-Machines W3107 (RBW3107) PC Desktop
Was installing hp starter disk 6500 into dell4550 dell was terned off my mistake and now wont re-boot just blank screen with small light flashing were fast upper left corner of screen
Enter the system bios and set the boot order to boot from CD ROM. If this order is correct and you are still experiencing the same issue. Re-enter the bios and set it to default setup. However, enter the boot order and ensure the CD-ROM is the first boot device and Hard Drive is the second.
Enjoy the power of a PC
Mar 13, 2010 | Dell Dimension 4550 PC Desktop
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
DVD/CD ROM problem (Dimension 5150)
you cleared the bios settings by removing the battery.
Go into the dell bios at startup F2
make sure it sees the cd rom drive
then save and exit
should fix the issue
Jan 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
EliteGroup K7VMM Motherboard Logo
174 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
