Question about Casablanca Fan W-52 Remote Control
CUSTOMER HAS OLD CASABLANCA FAN THAT UTILIZES THE "W52 REMOTE. THE FIRST NUMBER ON THE TRANSMITTER IS "W52-O6O" THE SECOND PART NUMBER ON THE TRANSMITTER IS #7854030. LOOKING FOR COMPLETE REPLACEMENT UNIT. BOTH THE TRANSMITTER AND RECIEVER. ARE THESE NUMBERS ANY GOOD? CAN YOU CROSS TO A NEWER UNIT? THE RECIEVER MUST BE OF THE APPROPRIATE SIZE TO FIT IN THE CANOPY. EXACTLY LIKE THE ORIGINAL
4 Suggested Answers
MN_Jack76
  • 45 Answers
SOURCE: fan won't go on
Possibly a bad receiver, contact Fan Man Lighting at 1-866-600-3267 and ask for Jason, he has 21 years experience with Casablanca
Posted on Oct 17, 2009
  • 57 Answers
SOURCE: I have a casablanca ceiling fan 35G11R( old model) lost remote,
I see you have an R on the end of your model# R designates Comfort Touch. I would be interested in buying the remote control from you.
As for ordering the parts, refer to www.casablancafanrepair.com
Posted on Apr 01, 2010
caroldon
  • 17130 Answers
SOURCE: Casablanca Fan/Light Remote (Versa Touch #W-42)
Possible that the drive to the IR LED is low and it can be due to poor output from the driver or a weak IR LED.
Please check this link below for some tips.
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Point your remote to your camera in the phone and see if there discharge is good enough . If not check the voltage at the IR, check if there is break in the printed circuit board or a possible open circuit from a SMD resistor...use a multimeter to check continuity.
Look on the PCB using a good magnifying lens to confirm.
Posted on Feb 22, 2011
I need to change the receiver and transmitter of Casablanca Scandia Ceiling Fan 88u33m. How to open the fan / dome and is there a newer replacement for the receiver and transmitter.
remove fan from ceiling [ safer way to work on it ] and receiver is in wire cover and any place that sells fan usually have a remote system
Jul 14, 2017 | Dryers
Remote works but fan, lights dont
You need a new receiver. The light on the remote transmitter is only a battery indicator light. Call 1-8--715-0393 for part.
Jun 29, 2014 | Casablanca Fan (88U33M) Ceiling
I have an existing Casablanca Lanai Fan Model 79669D installed in ceiling. Is it possible to install remote control after the fact?
yes they have a kit at all hardware stores, you will need to take down the fan to put it up it is easy just use two people works out alot better, good luck ps dont forget to turn the power off before starting
Aug 07, 2011 | Casablanca Fan CAS 79669D Lanai Ceiling...
Remote control have become sticky -- cleaning seems to make it worse.
I have the same problem; the remote has become quite disgusting to touch. I recently sent a complaint to the company via the customer service page on the Casablanca Fan web site. They are sending a replacement, no questions asked, so clearly the problem is known to them and they have no solution other than replacement.
Feb 05, 2011 | Casablanca Fan Televison & Video
How do you program a casablanca fan remote control to work for the fan?
Howdy,
Casablanca control systems are specific, for instance Inteli-Touch (4 button wall control with power fan light and reverse buttons) uses power line signals to a computer board inside the fan's motor housing and a remote control using RF will not work. However, you do not state what control you have, or what specific control you wish to attempt to use with the fan. Some will work some, will not.
Thanks and Reply so I can better help you!
Sep 14, 2010 | Casablanca Fan (3845T) Brushed Nickel...
Receiver 85112-04 need a replacement for hunter fan remote receiver which is housed in the based of the fan in ceiling.
I realize that this is an old post. However, the best solution is to replace the receiver with 3 or 4 speed wire harness, which includes the capacitor, fan speed switch, forward/reverse switch and female plug for $15 as of today's writing. While you may be able to find a 85112-04 replacement receiver, I found them to be an expensive solution at $80. In addition, there is no telling how long the replacement receiver would last. To purchase a 4 speed wire harness for this Hunter fan, they can be ordered from
Casablanca. Casablanca you say? Yes! Casablanca is a subsidiary of Hunter Fans. This 4 speed wire harness, part number K016501H01, is standard in many Hunter and Casablanca fans. Hopefully this will help someone looking for a low-cost solution to replacing the fan. Link below:
http://www.casablancafanco.com/Parts-Manuals/Part-Manual-Detail?ModelNumber=54019
Apr 11, 2010 | Hunter Ceiling Fan Remote Receiver...
Jan 26, 2010 | Casablanca Fan Advan?Touch W-62 Remote...
Casablanca Vary Quiet PC Board for Series 4000
First, the resistor you are looking for is a 39K ohm +/- 5% tolerance (GOLD tolerance band). Second, FAN MAN still has a couple of new boards in stock, even though his website says he is sold out (I just spoke with him today). VERY nice guy, and VERY reasonable prices. Phone # is (866) 600-FANS (3267). I had the same problem a few years ago (burnt resistor and fried pot) and replaced the resistor and pot. Everything worked again with very little time to fix, and almost no cost. Got the resistor at Radio Shack, but had to order the pot from a Casablanca dealer - read on.......
Now for the pot......
Part #1954150 *IS* a 5K ohm linear taper. I'm looking at the meter and a new pot as I write this. You had me wondering if I misread the meter or something, so I went back and double/triple checked. This pot is installed in my recently rebuilt Vari-Quiet Victorian, and it works fine.
However, I want to tell everyone that I had purchased a replacement pot many years ago from a Casablanca dealer because, as I said above, my old one had fried, along with the resistor (just like your situation). The pot the dealer sent me was a Casablanca part 0001040 (I still have the receipt), and it fit perfectly, so I didn't pay much attention to it. This pot worked for over a decade. But the replacement pot was NOT stamped with the 1954150 part number, and I have long ago thrown out the original - so I don't know at this point what was originally in the fan. BUT, the replacement pot that I put in so many years ago *IS STAMPED* "25K Ohm", and I measured what is left of it and it definitely is a 25K ohm linear taper pot. It worked for over a decade (since 1998).
Now, I have once again rebuilt my fan this summer because the pot again failed (I can't complain, I got almost 11 years out of it). New bearings, new pot, new flywheel, new PCB assembly, new heat sink/transistor, new brass hardware and a a coat of paint/laquer (brass). The new pot was purchased from Plaza Lighting (978) 774-7801, Don Guerette - another VERY nice guy with EXCELLENT prices. However, I got his last pot - sorry. The pot Don sent me is the 1954150/5K Ohm linear taper - the same one that came out of your Vari-Quiet. It also works very well - better than my old 25K Ohm pot because it slows the fan to a full stop at almost a full deflection of the knob (my old 25K ohm slowed the fan to a full stop at partial deflection).
Hence, my conclusion is that the part that belongs in MY fan is the 1954150 pot, and the 25K Ohm pot was the wrong one, even though it worked for many years (no reason it wouldn't, scaling was off, that's all). If you've never done anything with your fan since new (like replace the pot), then the correct pot is the 1954150 since that is what you are taking out of it, and that is definitely a 5K ohm linear taper. You can pick these up almost anywhere. The 25K ohm wa a wire wound. I don't know about the 5K ohm as I'm not about to take mine apart - smiles.
P.S. I was able to acquire a W52 remote control module and install it on my rebuilt Vari-Quiet. It works GREAT (Casablanca sasys you must convert it to a 3-speed before you can use the W52 - LOL)!!!!!
Sep 11, 2009 | Dryers
Dip switch settings
I've had the same problem w/ light turning on/off. Called customer support and 3x waited 6 minutes to leave message and get no call back. Finally got a human and she told me to change code in receiver and transmitter. This was no easy task as the fan is very high up and the stupid thing needs to come down to adjust the receiver. Changed the setting and it worked for two days until it started back with the lights turning on at all hours. I noticed there's a toggle switch in the remote that is not explained in the manual. It says CFL on one side and INC on the other. The light will NOT dim if it's in CFL and tonight is the first time I've switched it to that setting. I'm hoping this is some kind of lockout for random signals going out of the remote...It would be nice to have a proper explanation in the manual. I should have gone with another Casablanca fan--Hunter products are lame.
Feb 03, 2008 | Hunter 27185 Remote Control
Casablanca Fan W-52 Remote Control Logo
96 people viewed this question
Top Casablanca Fan Televison & Video Experts
deton8 von Splosion
Are you a Casablanca Fan Televison and Video Expert? Answer questions, earn points and help others
