Question about Epson Office Equipment & Supplies
How can I reset maintenance tank-counter for Epson 3880. I was able to do this from the controls of my Pro 4000. Anything similar for the 3880? The purpose is to re-use the tank over and over again Thanks
Amardeep46
  • 129 Answers
SOURCE: I want to reset the
Hi James,
You need to change the Waste ink tank to reset the counter. There is no other way to do it.
-Amar
Posted on Feb 01, 2009
SOURCE: EPSON STYLUS 4000 MAINTENANCE REQUIRED
While powering up the printer, hold down the three leftmost
arrow buttons:
[left-arrow] [down-arrow] [up-arrow]
You will get a whole different set of menus.
Use the up/down arrow buttons to select the "Clear Counters" menu, then press the [right-arrow] button.
Use the up/down arrows to get to the maintenance tank entry... where you can clear its counter.
Then turn the power off, wait, then turn it on.
You can use this diagnostic startup to clear most of the counters (and their related maintenance codes).
Posted on Mar 23, 2010
exil0r
  • 118 Answers
SOURCE: clear the Carriage Motor Counter epson stylus pro 4800
look for that here
Posted on Mar 26, 2009
SOURCE: I need to replace the Maintenance Tank in my Epson
just order one I kept mine for 3 yrs before I replaced it resetting it twice. it cost about $35 and its located on the right side of your cartriages, just pull it out and pop the other one in. have a trash handy and some glove cause its messy
Posted on Sep 17, 2010
  • 963 Answers
SOURCE: I need a User's
If you type your product description into the Product Finder box on this page, you will find that there are 4 versions of the Stylus Pro 3880:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes&expansion=1000000#prin (cut and paste it into your browser's search pane)
Therefore I will leave it up to you to determine which one that you have. At any rate, it will take you to a page giving you another link to the download file for the "manual", so you're most of the way home.
If the file that you choose doesn't display it's because they are .PDF files, which require that you have Adobe Reader installed on your computer, and use Adobe to open the file for display.
You can get the free download for Adobe Reader here:
http://get.adobe.com/reader/
Posted on Aug 05, 2011
Tip
Epson Stylus Pro 3880
ERROR CODES CAUSES AND SOLUTION
1101
CR life error The CR scan path counter has reached a predetermined level.
(The end of life of the Ink Supply Tube)
Replace the Ink Supply Tube (INK, SYSTEM, ASSY) and reset the counter using the Adjustment Program. In addition, check the statuses of the CR motor (MOTOR ASSY.,
CR), the driven pulley, the Carriage Unit, and the Head FFC, if any abnormal noise or wear is found, replace the corresponding part(s) along with the Ink Supply Tube.1120
CR lock error The CR encoder failed to read the CR scale during a predetermined time period. Replace the CR encoder (BOARD ASSY., ENCODER, CR).
Replace the CR scale (SCALE, CR).The carriage unit does not operate due to a CR motor failure or some reasons. Move the carriage unit manually to check if it moves smoothly, and fix any abnormality.
Replace the CR motor (MOTOR ASSY., CR).1121
CR reverse error An abnormal operation (reveres movement) of the carriage was detected a predetermined number of times. Check the CR scale (SCALE, CR) for incorrect attachment, scratch, dirt, and fix any abnormality. Replace the CR scale (SCALE, CR).Replace the CR encoder (BOARD ASSY., ENCODER, CR).
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Feb 23, 2016 | Epson Stylus Pro 3880 InkJet Plotter...
Maintenance request error code 4000 for Epson stylist pro 4900
HI,
MAINTENANCE REQ - 4000 - It detects twice in a row that all the nozzles are clogging.
Check the video to know how to clean the nozzle to get ride of error 4000
How to clear nozzle clog on your Epson wide format printer from PRO...
www.electro-medical.blogspot.com
Mar 04, 2013 | Epson Office Equipment & Supplies
I have the Epson Stylus Pro 3880. Up till a few weeks ago all was well, the today, it decided not to print out the black areas of my shots. I've check the inks, the heads all is well. HELP
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 02, 2012 | Epson Stylus Pro 3880 InkJet Plotter...
I need to replace the Maintenance Tank in my Epson Pro 4000 and can't seem to find instructions
Apr 16, 2010 | Epson Stylus Pro 4000 InkJet Printer
EPSON STYLUS 4000 MAINTENANCE REQUIRED 0040 ERROR CAN ON. HOW DO I RESET THE COUNTER?
arrow buttons:
Sep 15, 2009 | Epson Stylus Pro 4000 InkJet Printer
Reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
May 12, 2009 | Epson Stylus Photo 1400 Printer
Epson stylus d92 printer
I think that this "error"is due to an internal copy counter.
I have a Epson Stylus D68PE, and had the same problem.
I performed a research for a file to reset the internal counter, and I found a file "C67C68D68" that is an "EPSON ADJUSTEMENT PROGRAM", with different softwares for each type of printer.
after launch the program, and reset the counter, the printe work OK.
This counter is as similar as the counter of the laser copiers.
As you reset the chip on ink tank, after a specific numbers of print, you must reset the internal counter. By yourself, of by MAINTENANCE (very expensive) Good luck.
Sep 11, 2008 | Office Equipment & Supplies
Maintenance tank almost full
I opened up my tank under some water flushed everything out of it, put in some sponge, then get a chip re-setter (off ebay for less than £5.00) reset the chip so your back to 100%, done and saved 20 pound each for both tacks each time.
Apr 12, 2007 | Epson Stylus Pro 9800 InkJet Printer
2,359 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
