Question about Microwave Ovens
I have RGB745BEA7WH model of hot point oven. its the older model and the manual online is for the newer one. curios how to put it on shabbos mode = overriding the auto turn off thanks
How do you remove the child lock?
It sounds like your membrane keypad may be shorted.
If you'll contact me with the full model number from your tag, I'll give you all the information you would need. In many cases, this is a do-it-yourself repair.
http://www.microwavecontrol.com
Oct 08, 2016 | Sharp R-303Cw Microwave Ovens
How do I disable the child lock on a Sharp R-891 Microwave?
It looks like from the "Home" Screem press "Information Desk" then "Useful Information" then "Child Lock" then "Set The Lock"
If you don't have a owner manual you can view online or download one here. Just put your model number in the search box
ManualsLib Makes it easy to find manuals online
Good Luck,
John
Sep 10, 2016 | Sharp Microwave Ovens
WHEN I SUBMITTED MY PLEA FOR HELP TO GET A MICROWAVE USER/OPERATOR MANUAL, I WAS ASKED: WHAT MAKE IS IT?
that model is from the uk,you need to search over there for it,i just searched for an hour and come up with this, Accumetrics Inc Announces United Kingdom Distribution Agreement With...
22l is how much it holds,not the model number,Elitech commercial grade steam oven/combi grill - in VGC - not used a great deal, but a very handy addition to any kitchen at busy times!
Voltage - 220-240 V input 1650 watt when on steam mode, 1250 oven/grill mode.
Dimensions 220x315x312 mm
Manual available online to download - (Ref Elitech EA053747)
Capacity 22L Instruction Manual Copy ELITECH Steam Oven Combination Grill Model Ref...
May 11, 2015 | Microwave Ovens
Fuse keeps blowing
If the microwave oven is the newer type [7years or less], the problem is most likely the magnetron or the inverter board, but if model is older check for a shorted high voltage capacitor.
Aug 31, 2012 | Whirlpool MH1170XS Microwave Oven
Model KCMS1555RSS appears to be in demo mode. How do you turn that off?
Here is what I found. You can click HERE for the owners manual online, but here is the skinny
To Turn On/Off Demo Mode: Touch and hold TIMER for 5 seconds until 1 tone sounds, and "DEMO ON" appears in the display. Repeat to turn off Demo Mode
Happy to help anytime, please rate service :)
Joe
Sep 01, 2011 | KitchenAid KCMS1555RSS Stainless Steel...
Hotpoint bd35 electric oven instruction manual
Here is a link for you to download a PDF instructional manual for your Hotpoint cooker or Hotpoint oven.
how to use this service
1 click on Link,
2 click manufacturer (Hotpoint)
3 enter your model number and download the PDF file .
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Jan 28, 2011 | Microwave Ovens
Jenn-air microwave dead
I'm afraid since Jenn Air has become a division of Whirlpool (along with numerous others) the quality has suffered.
I was going to suggest that you purchase a service manual for your unit so you could 'reset' it yourself. Service manuals can cost from $12-$40 US and in many cases obviate the need for 'professional' service calls. However, I couldn't find one offered for your model number so your only choices are to continue to pay for 'service' or examine the guts visually to see if you can locate any reset feature. This is what I would do.
When microwaves fail, older ones generally need a diode, a big capacitor or the magnetron replaced. Newer units are suffering power supply failures as many have moved from the reliable but less efficient 'linear' power supplies to 'switched mode' types that are more efficient but more complex and prone to failure. These later types usually have the word 'inverter' in the model description.
Jan 04, 2009 | Jenn-Air JMC8130DD Microwave Oven
Microwave oven door removal
First you have to tell why you want to remove the door. The door seal is important to keeping the radiation from excaping and is not recommended to fool with it.
Dec 28, 2007 | Whirlpool MH7135XE Microwave Oven
Hot point counter saver
If you don't still have the installation instructions, please visit:
http://www.geappliances.com/service_and_support/literature/
We appreciate your thoughtful rating of our answer.
Oct 25, 2007 | Microwave Ovens
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
