Question about Samsung HLP5674W 56" Rear Projection HDTV-Ready Television
The top left speaker in my samsun HL-P5685W DLP TV has blown, I need to find the specification for the speaker in order to be able to order it
  • 4,234 Answers
I have not been able to get a part number from my normal suppliers as it is not listed. I would suggest that you call Encompass parts directly at 866.779.7421. They should be able to provide you with the part number and cost.
Dan
Posted on Sep 29, 2010
Samsung hlr6167wx A noise like fan winding down started occuring , like spinning whurring sound then the picture went out. I replaced the bulb 3 years ago. Can this be a bad fan and a bad bulb too. All...
if this "whirring" sound was making a vibration on the TV, there is a good chance that the one that needs to be replaced is the color wheel. When the color wheel fails it also triggers the signal for replacing the lamp. This is another common issue with Samsung DLP's.
In order to replace the wheel follow this picture guide:
http://www.fixyourdlp.com/guides/samsun ... 01579a.php
You can purchase the wheel for your TV here:
http://www.discount-merchant.com/Samsun ... 1&CartID=0
Jun 26, 2011 | Samsung HL-R6167W 61" HDTV
Screen on my HL-R5667W DLP is fading from the left
Ur tv have a convergence problems.The 2 STK convergence ICS are defective and dying.The shop will fix this for u about $300-350 for parts and labors.
May 08, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
HL R5087W DLP
try reseating the dvi cable inside the set
Jun 13, 2009 | Samsung HL-S5087W DLP TV
TV has low sound output through right speaker of stereo receiver
try the balence. if no joy. try the cable if you have a meter also see if the cable and see if the cable has been reversed???????
Mar 27, 2009 | Samsung HL-S5087W DLP TV
Samsung dlp tv model # hl-p5685w
check manual for lamp life reset.
sumtimes its listed in the menu option and sum times it is done by the remote with users manual
Direct line to samsung is 1-201-229-4000
hope this helps
regards,
daniel
Jan 12, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R4667 DLP There are about 6 vertical bands (usually all the same color) running top-to-bottom and within these vertical bands is a picture trying to come in. The screen behind the bands is...
needs a DM Board, prity easy to change yourself, if you order one, make sure you give them the version number off the Right side of the TV, will be somthing like SP01, To change - when you take the back off the tv, it will be on the left hand side, have to unplug 3 or 4 connectors, then take the plastic covering off, and it will slide out.
Jan 08, 2009 | Samsung HL-R4667W Rear Projection...
Samsung DLP HL-R6167W 61"
try removing the lamp again ,inspect it for hair and blow some air into the lamp housing,if this is new to you after replacing the lamp,its possible its been created .
Jun 14, 2008 | Samsung DLP HL-P5663W 56" TV
Bulk Life
Identifying the correct lamp code
Before placing an order online, you must identify which lamp code you need. The lamp code is located usually on the left side of the TV
http://fixyourdlp.com/blog/?cat=4
Jan 16, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLP5674W 56" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Henry  Thomas
Henry Thomas
