Question about HP DVD1040i 20x Super Multiformat Dvd Writer, Internal Burner
I have a HP dvd/cd rom rw 1040d disc drive. The disc tray doesn't open when empty. It tries to open but doesn't manage to open. If I manage to get it open, (Usually manually when shut off, it will open with a disc in it but seems to still take a couple seconds. How do I fix this? Thank you. Tamra
Premature failure of this drive appears to be a widespread issue. I have joined in a support thread at HP and encourage you to do the same:
http://h30434.www3.hp.com/t5/CD-DVD/Hp-dvd-1040i-Disk-tray-doesn-t-open-half-the-time/m-p/347544#M1980
Posted on Oct 20, 2010
L305D-S5930 dvd wont burn documents to a dvd disc
You need a program, like nero.
if that doesn't work then put a DVD in the drive & see if the computer picks it up in the my computer.
the first thing that goes in a CD/DVD-RW drive is the DVD heads, thats if your drive is a CD/DVD-RW.
Have a look on the front of the drive tray, if it say CD-RW DVD ROM then it doesn't burn DVD's it only plays them.
Jan 30, 2012 | Toshiba Computers & Internet
Toshiba cd-rw/dvd-rom drive...power on but disc door will not actvate and open
There are quite a few reasons the DVD tray in your laptop might fail to open when you hit the eject button. About the worst thing it can be is if the motor or gear train failed, which would mean replacing the drive. If the disc in the drive plays OK, you know that the power and the connector are fine. If not, you should try reseating the drive in the bay. It's also possible for the drive to be locked in software by the operating system, or for a power management scheme to have cut power to the drive. Check these by right clicking the drive icon and checking properties, or looking at you power management settings. But, when all else fails and you can't get the disc out of the drive, there's always, THE MIGHTY PAPERCLIP.
Follow the bellow link,
http://www.fonerbooks.com/laptop12.htm
Hope this helps,
Jan 11, 2011 | Toshiba (PA3352U2CD2) CD-RW/DVD-ROM...
My DVD-ROM tray opens only after many tries.
As per your information you done all the basic work. Hope you use little bit of oil drop in the side of the tray. If not then try that .If no success then there is a small spring available for tray in and out function. You have to change that spring from a service center or if possible then at home.
Thanks and waiting for your reply.
Feb 04, 2010 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My cd rom tray does not open
hit it on top of it or the casing and it will open. but this is not the good way but i have the same problem i use this
May 20, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
DVD-Rom drive doesn't work.
right click my computer .. manage.. storage.. disk management. unalocated. its totaly empty . create partition then format it ntfs and name the volume uhhhh USB160GB for easier to recognize
May 17, 2008 | Maxtor Hard Drive
Dvd rom drive does not read dvd+rw discs
you might have bought a blank dvd that is not compatible with your dvdrw.
try to clean your dvdrw first and then try to insert that blank dvd again.
Mar 23, 2008 | IBM ThinkPad (22P9163OB) (22P9163-OB)...
Tray not opening
try a safety pin push it in the tiny hole just by the led light door will pop open.
Jan 06, 2008 | Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW...
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Dvd-r/cd-rom automatically ejects
    My Dvd-r/cd-rom automatically ejects. Please help!
    Justis
    Feb 07, 2007 | Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
    HP DVD1040i 20x Super Multiformat Dvd Writer, Internal Burner Logo
    300 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
