I own a Whirpool Aquasteam 6 Sense Washing machine and it is showing the error code F06 - When I start the cycle it appears that the drum is filling up with water but the drum does not spin and a small red spanner sign shows up on the display along with the error code 'F06'. Does anyone know what this error code means and how to rectify it?
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
TheMobilian
  • 8220 Answers
SOURCE: hi, my whirlpool aquasteam 6th
Might be wrong soap, too much soap, soap in wrong tray, heater or thermistor broken, hoses backwards, no water being sensed going into the machine, no water going out, and me fave: leak detected. More HERE
Get a free service manual HERE
Posted on Dec 11, 2010
emissionwiz
  • 79186 Answers
SOURCE: whats a f05 error on a aquasteam 6 sense washing
F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Information coutesy of expert jsrock516
Posted on Jan 11, 2011
blueextc3221
  • 15935 Answers
SOURCE: whirlpool aquasteam 6 sense model
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa
Posted on Mar 04, 2011
KevinWhite
  • 1902 Answers
SOURCE: when the drum rotates it
Hello & Welcome to FixYa
The belt is either loose or broken and needs replacement. Please get back to me with the model# if you have any other questions.
Kevin
Posted on Jun 19, 2011
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
My maytag washer model MFW9600SQ0 has an F06 error code. It was previously vibrating during the spin cycle then the error code showed up. I took the back off and found one of the springs that the drum...
The F06 is a drive motor tachometer failure which means the motor control is not able to see the motor is running. This can be a difficult problem to pin down, but there are some things you can do yourself if you like. Check the connections between the motor control and motor. Also check connections on the central control are all tight. Push on all of the connections and see if there is any improvement. The images below will help with access on some Maytag front load washers.
Image 1
Image 2
Sep 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet whirpool washing machine stop and DLF sign appear
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Apr 03, 2011 | Washing Machines
Whirlpool aquasteam 6 sense model number 859297015700 error code f26
DOOR SWITCH ERROR
Mar 04, 2011 | Whirlpool Washing Machines
Flashing code F-6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the MCU
Replace failed component.
Apr 12, 2009 | Whirlpool GHW9300 Duet Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Code lr appears on washer
use normal cycle instead of clean just follow say instructions ..lr is code for remove clothes from tub for clean cycle problem even with no clothes they still show code ..it's a program problem that whirpool is aware of last i heard they were working on solution but instructing cust to just use normal cycle instead
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
Error code
Copy and paste link for list of error codes and solutions. Is machine drum turning at all during cycle , or any problems draining water? Please reply on FIXYA with better description of your machines fault in order to pinpint problem. Regards.
http://www.repair-help.com/kb/index.php?article=544
Jun 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
