Question about Neff U1461 Double circotherm plus Electric Oven
Neff model U1461
When the oven is operated in covection mode the fan runs ,but the oven will not heat. However when the stove operates in the conventional oven mode the oven heats.
Where can I find a wiring schematic fro this stove
Your convection element has blown by one online and replace it yourself
Posted on Jun 01, 2008
Smell has started in our 8 month old Neff oven. No obvious reason for it - pretty clean and no unusual food cooked. Any ideas ?
There may be a problem with the cooling or extraction fan on the oven. All Neff appliances come with a two year manufacturers warranty, so I would advise you call them out on 0844 892 8999. If you attempt a repair yourself, you could invalidate the warranty.
All the best.
Sep 01, 2010 | Neff U1461 Double circotherm plus Electric...
My U1461 oven is taking a long time to heat up, what could this be?
check oven fan is starting and maintaing a steady speed these seize up with carbon very soon after useage.
May 11, 2010 | Neff U1461 Double circotherm plus Electric...
OVEN DOES NOT HEAT IN FAN ASSISTED MODE but the fan works ok
I would suggest that the oven element is faulty
This is located at the rear of the innner oven compartment behind a removeable cover.
Mar 10, 2010 | Neff U1461 Double circotherm plus Electric...
NEFF oven U1461 - The bottom oven door hinges do not have enough strength to hold the door fully closed. Can these be adjusted and is this something I could do myself?
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Please rate my solution.
Thanks.
Nov 05, 2009 | Neff U1461 Double circotherm plus Electric...
Light on fan on no heat
Hi.
You need to fit a new oven element, as this is the reason you are getting no heat.
Thanks.
Jul 29, 2009 | Neff U1461 Double circotherm plus Electric...
No heat on bottom oven. fan running but not heating up
Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
For all Free appliance repair videos visit our VIDEO TUTORIALS
Jul 19, 2009 | Neff U1421 Double circotherm Electric Oven
Manual for my oven
Go to the Neff site and dowload a manual
Feb 10, 2008 | Neff U1461 Double circotherm plus Electric...
Neff U1461 Double circotherm plus Electric Oven Logo
551 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
