Question about Campbell Hausfeld 26 - Gallon Air Compressor
Need air tank 26 gal tank rusted through - Campbell Hausfeld 26 - Gallon Air Compressor
    President:
  • Campbell Hau... Master
  • 1,388 Answers
Contact local repair shops for used tank. May be different size or configeration but a little creativity will save lots of money. Usually motor or pump will fail so there are many good tanks around. Or order new from www.chpower.com or www.toolpartsdirect.com ,good luck
Posted on Sep 30, 2010
Air releases from the bleader valve as soon as i turn the unit on and continues to releaseis this normal?
No you need to simple tighten the bleeder valve on the bottom of the tank. Its there to release moisture and manual says to drain after each use. I drain mine weekly if I've been using it. It prolongs tank life by preventing rust.
Feb 25, 2014 | Husky Portable Air Compressor: 20-Gal....
I need to replace the belt on my 5 HP 120 volt 27 gal tank Model WL660001AJ Air compressor. I don't know the part number on the belt, or where to purchase. Can you help?
Hi, my name is John. Welcome to FixYa. Take the belt with you to most any auto parts store and they will match one up for you. Thanks for choosing FixYa...John
Nov 19, 2010 | Campbell Hausfeld 26 - Gallon Air...
Filled truck up with fuel and fuel guage stoped working
There is a TSB for this issue ( TSB 08-2-9 ).
The problem is high sulfur content fuel will cause a problem with the fuel level sending unit, and cause it to read incorrectly.
The 2 times I had this happen, I was not at my normal brand fuel ( had it happen with Shell fuel both times ).
I fueled at 1/2 tank with my normal brand, and then after another 1/2 tank fueled again, and the problem went away.
If you want, the TSB lists new revision fuel level senders, that you can drop the fuel tank, and replace your exiting one with to cure the problem.
The correct P/N depends on your truck cab & bed config, and options
PART NUMBER PART NAME
8L3Z-9A213-E Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-26 Gal Tank - 126/132 WB
8L3Z-9A213-F Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-30 Gal Tank - 139 WB
8L3Z-9A213-G Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-27 Gal Tank - 145/151/163 WB
8L3Z-9A213-H Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-36 Gal Tank - 145/151/163 WB
8L3Z-9A213-A Kit - Fuel Sender 2004 through 2008 - Gas-26 Gal Tank - 126/132 WB
8L3Z-9A213-B Kit - Fuel Sender 2004 through 2008 - Gas-30 Gal Tank - 139 WB
8L3Z-9A213-C Kit - Fuel Sender 2004 through 2008 - Gas-27 Gal Tank - 145/151/163 WB
8L3Z-9A213-D Kit - Fuel Sender 2004 through 2008 - Gas-36 Gal Tank - 145/151/163WB
Aug 20, 2010 | 2004 Ford F150
What size of gas tank does a 2000 chev silverado have
SHORT BED TANK SIZE 26 GALLONS LONG BED TANK SIZE 34 GALLONS.
May 15, 2010 | 2000 Chevrolet Silverado
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
I have a 5hp 26 gal upright cast iron.Moved lying on side
clean fuel tank, and lines. just do a standard tune up. check every componet for wear or rust.
Oct 26, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
On my last fill up i pumped 33 gallons, when previous fill ups were less than 26 gallons. I have a 1999 expedition Eddie Bauer. I thought I had a 26gal tank, since with the warning light on and saying 10...
The 99 expedition comes with a 26 gal tank as standard equip. and there is an optional 30 gal available. I suspect the gas pump you used is not accurate, and needs to be recalibrated. I think it's just a coincidence that the gauge is acting up now. Hopefully I'm wrong, and by some miracle you actually are now getting 300 miles on a half tank of gas! You may have a bad sending unit, this would result in inaccurate fuel tank readings.
Jun 23, 2009 | 2001 Ford Expedition
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
64 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
