Question about Golden Technologies Buzz Around 3 Wheel Scooter
Has power when switch is on. no forward or reverse and electric seat height adjuster is not working.
  • 692 Answers
John sounds like a cable problem from the tiller to the rear of your scooter. Power iis getting to the tiller but not back to the controller when you engage the throttle also the seat height is not getting power. I'm afraid you will have to get it checked by a qualified Tech to find out exactly what is wrong. If Medicare paid for the scooter then they will pay for most of the cost of repair. Hope this helps you
Posted on Sep 29, 2010
2006 crown Victoria all electric functions on seat work except backwards!
Is it possible that switch has been installed upside down?
Apr 08, 2015 | Seat Cars & Trucks
Driver seat not working
Beings it's probably a electric adjusted seat (you didn't state if so), it might be a fuse.
Apr 08, 2014 | 2007 Lincoln Navigator Luxury
2001 toyota camry drivers seat wont go up nd down
probably the switch-spray with wd40 or electric spray cleaner and wiggle it-if not gotta remove seat completely to check motor,etc
Mar 20, 2013 | 2001 Toyota Camry
Power seat will not reverse - electric switch will drive seat forward but reverse setting will not do anything. Are there seperate motors for forward and reverse and is there a way to move the seat...
There are three motors. The one motor moves the seat forward and reverse, one for up and down and one for the tilt. So you may have a problem with the switch. It's possible the switch contacts inside have worn out.
May 15, 2010 | 1998 Dodge Ram 1500 4WD
Subaru outback all wheel drive electric seat switch stuck
I just went through and determined it was the switch. My wife had accidentally moved the seat almost all of the way forward - and the reverse did not work at all - she was very cramped. After going thru fuses and seeing that none were blown I looked for loose wiring under the seat and found none. I was about to pull the seat when I stopped and decide to pull the side cover first. Item 5 in the photo below. Once that was off access to the switch was easy - item 3. The box actually contains a set of 3 switch housings each with 2 switches on it - total of 6 for each direction. I unplugged the large connector to this switch. Then I cut some wire off of a roll of wire i had in the garage and stripped both ends. I put one wire into the power contact (red) and the other into ground (black) and then took the other end of both wires and connected them across the other contacts in the connector. Pretty quickly I could determine which pair of contacts controlled which motor. I got the right combination that allowed me to operate the seat-reverse motor and get the seat back into the right position... problem solved. I still need to find a replacement switch box at a junk yard but no hurry now that the seat is back to a comfortable position.
Feb 05, 2010 | 2001 Subaru Outback
Won't go forward, only in reverse
You need a forward/reverse switch, most likely.
http://www.rungreen.com/john_deere_peg_perego.html
You can replace the whole shifter for $28, but the switch may work fine.
Jul 11, 2009 | Peg Perego John Deere Gator HPX
Power front seats
Before you start beating up thing's , test the electrical circuits. Do you know anything about automotive electrical systems ? How to use a volt meter an a wiring diagram to test for B+ power to the switch an testing the ground .
Does your envoy have memory seats ? Your vehicle has four or more electric motors to control back an foward , up an down etc.. the odds of more then one motor being bad at one time are highly unlikely .
Look under the seat any trash under there keeping it from moving ?
If you have memory seats there is a control module involved in making the seats work . If it has memory seats it could have DTC'S - diagnostic trouble codes .
DTC B1735, B1740, B1745, B1750, B1755, B1760, B1815, or B1820
The seat adjuster switches are inputs to the driver and passenger seat modules. The seat modules supply the adjuster switch assemblies with a battery positive switch supply circuit and monitor the switch signal circuits. In an inactive state the switch signal circuits are floating and when a switch is pressed the signal circuit is closed to the switch power circuit within the adjuster switch assembly. When battery voltage is present on the switch signal circuit the seat module determines the switch status to be active.
DIY Blazer GMC Jimmy Power Seat Control Diagnostics and Repair Electric...
Jun 26, 2017 | 2002 GMC Envoy
Electric seat motor switch...no move back
the problem is the switch, replace it.
Apr 21, 2009 | Ford F-250 Cars & Trucks
Golden Technologies Buzz Around 3 Wheel Scooter Logo
137 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
