Just bought your hi speed usb 2.0 desktop there was no disc or instructions do i just plug in and go
  • 36 Answers
If you have USB 2.0 card, you dont need any special CD or software to install it. Its plug and play device. Just insert it in motherboard slot and you are done!!
Take care
Posted on May 25, 2008
Where can i download hi speed usb hosts for my dell computer
if your computer only has usb 1 you cant you will have to buy usb 2 (hi speed) from computer vendor.
hope this helps.
Apr 25, 2010 | Dell OptiPlex 170L PC Desktop
Ctrl keys dont work, bought new key board and have same problem, have windows XP
First rule out drivers
- remove the keyboard driver and instruct windows to reinstall the driver
Next check for hardware issues
1. Plug this keyboard into another PC to see if the same problem persists
2. If the problem does occur it is the keyboard (get a new one if that is the case)
3. If the problem does occur then it is not the keyboard it is the port that u are plugging it into.
4. If it is a USB Keyboard, plug it into another USB port
5. If the problem persists on all USB ports on the system board, then the problem is the USB ports only IFF the keyboard works fine on another system in other USB ports
Is it PS/2?
If it is not a USB keyboard and it is a PS/2 board, again, and it works fine on another PC, then you have a defective PS/2 port on the system board.
Get a PCI card with USB ports and install it. Plug ur keyboard into that.
Mar 14, 2010 | Dell Dimension E310 PC Desktop
HI-SPEED USB host controller
Download Drivers from the below location and install them....This will solve your problem..
Jun 15, 2009 | Acer Veriton M460 Micro Tower Core 2 DUO...
Printer not printing
Uninstall everything. Reboot. Unplug the printer. Install the software. Reboot. When everyting is up. Plug in the printer. Have the driver disc ready, install the printer. Reboot, go to settings, printers and see if the printer is listed. If it is, make it the default printer.Good luck
Dec 20, 2008 | Computers & Internet
Hi, I have added a USB 2.0 4 port PCI card to my PC, when I run the support disc to add the driver it says no hardware found. All the instructions say are plug in the card and run the disc, is there...
Dear Friend,
If you have windows xp, generally when you add new hardware. Windows does show found new hardware window, where you can select the driver for your new hardware.
Go to control panel=> Add new hardware & then select the appropriate drivers for your card.
Hope this solves your problem.
Jul 28, 2008 | Computers & Internet
My modem with dial up but not high speed
You might need a new NIC card, thats high speed capable. What kind of hi speed are you trying to use ex.DSL,FiOS,Cable?
May 16, 2008 | Computers & Internet
Software Installation Problem
I had this problem just a few minutes ago. The way to get through this is to plug in the USB cable *before* you begin the installation. When Windows detects a device and ask for drivers you need to click cancel for each device (printer, fax, scanner, etc) that it prompts for.
Run the installation disc or file as normal with the USB cable plugged in and it should work. It worked for me.
Windows Vista SP1
Feb 19, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Zippy USB external hard disk case (2.5
I know this is an old thread, however if it helps any one try this:
Zippys power supply failed for me also. The problem here is your case support USB 2.0 ("A high speed USB device") and your port is only USB 1.1 ("plugged into a non-HI-SPEED usb hub"). This will not give adequate power to the drive. So use a y-cable ( and connect one end to your casing and the two pins at the other end should be connected to two USB ports. (get it at
Another costlier way is to upgrade to USB 2.0 by a card like this
or even better a USB 3.0 card :
Jan 28, 2008 | Computers & Internet
USB Drive controller
you need to install sisoft sandra search google for a free download and find out if you have any USB2 ports on your pc as the hard drive will only transfer at the higher speed as apposed to the usb pen which can transfer at either speeds. It may also be that your usb port cannot supply enough voltage to run the hard drive, so a mains powered usb hub may be the answer.
Sep 04, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
