Question about Kenmore Refrigerators
Ice sticks & jams ice maker. - Kenmore Refrigerators
  • dahnkel Sep 29, 2010
    It's always only 1 cube that sticks
  • 11,896 Answers
The reason this happens is because if the ice sits there too long it starts to merge together into one big clump. Also there can be a drip right along the back of the cube holder, so that there would always be an icicle there. Try reducing the flow of water into the icemaker and that should help. You can also try moving the box out a bit.
Posted on Sep 29, 2010
  • Nate Stansfield
    Nate Stansfield Sep 29, 2010
  • Turn the ice maker off. The ON/OFF switch is located either on the top right side of the freezer interior, or on the ice maker behind the cover door, depending which model Whirlpool you have.
  • 2
    Remove a jammed ice cube from the ejector arm on models with
    an interior ice bin by using a plastic utensil, such as a plastic spoon
    or spatula. Do not use metal; it may damage the ice maker.
  • 3
    Lift the ice maker service door while depressing the ice bin
    sensor (located on the upper left side of the freezer) on models that
    have an ice bucket. Remove the jammed ice from the ejector with a
    plastic utensil, as described in Step 2.
  • 4
    Turn the ice maker on again. Allow 24 hours for the ice bin to replenish.
  • 5
    Remove the ice maker cover and adjust the screw that controls
    the amount of water that flows into the ice maker if the problem
    continues. Turn the screw to the minus position one notch at a time, to
    decrease the amount of water flowing into the ice maker, until the
    jamming stops.
We have a U-Line mini fridge with ice maker. 1 month old and 1 week ago it started making "working too hard" noises. 1 week ago we had paused the ice making function. Related ?
ICE CUBES IN ICE MAKER HAVE LIKLEY SHRUNK
AND ARE NOW JAMMED IN ICE MAKER INSTEAD OF FALLING OUT
CHECK THE ICE MAKER FOR JAMMED CUBE
Jul 20, 2017 | U-Line Refrigerators
Coating on maytag ice maker mold peeling & flaking
In this case you have to replace the entire ice maker since the mold section is not sold separately. If you shop carefully you can get the entire shebang for about 40 bucks on ebay.
Feb 21, 2016 | Maytag Refrigerators
Ice maker ice jam
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
Here are some basic ways to slow the buildup
How to Avoid Freezer Frost
Feb 10, 2016 | Samsung Refrigerators
What causes my ice maker to drip water?
HI,
This could be either the ice maker is old and the finish inside has depleted, the water valve is going bad or you had a jammed ice cube and now it overfilled. Many different reason this could happen. Does the ice cubes stick together with a bridge? Is the drip coming from the ice maker head unit? How is the ice in the pan its stored in, stuck together? In the pan, has the ice glaciered together? Need more information please. Thanks
Aug 09, 2014 | Kenmore Top Freezer Refrigerator
Kenmore 106.55242400 ice maker knocking noise
most likely you need a new ice maker,one thing that could do this is the white arms that spin around when dumping the ice,sometimes one of the arms bend and jam the ice maker and you'll hear that knocking soundthe arm gets bent,the ice cube gets stuck because the arm can't push it out,,it stops the motor from spinning through it's full cycle and damages it but this is just a guess from something i've seen happen but most likely you need a new ice maker,one other i've seen is the metal arm that you can lift up to shut off the ice maker gets knocked out of the hole it slides into.if you pop off the white cover and get a jumper wire and stick it into the h and t holes you can jump start the ice maker.http://appliantology.org/gallery/image/659-manual-harvest-on-a-whirlpool-modular-ice-maker/
Jan 02, 2014 | Whirlpool Refrigerators
ICE MAKER BLINKING ON/OFF. TURN IT OFF & BACK
Icemaker is jamming. Stripper may be bent where the ejector hangs up advise replacing icemaker
Feb 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice cube sticks and jams arm won't go round
You have a bad mold heater, located on bottom of ice maker.
May 07, 2009 | Kenmore 64802 Top Freezer Refrigerator
Ice maker does not consistently make ice...
try turning off ice maker for a day. remove the bucket that holds the ice. look all around bucket and into ice maker to determin if there is a jam, or if there is a cube stuck there preventing operation. Check that the ice arm can move freely and it is properly inserted on both ends. Make sure there is nothing in your freezer that could be getting in the way of the ice maker operation, either above or below the unit. One hint-wear disposable gloves when working with the ice maker-if you have any moisture on your hands, you tend to stick to the unit.
Jan 17, 2009 | KitchenAid KSCS25FKSS Side by Side...
LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice.  If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
May 16, 2008 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
