Question about Jenn-Air Ovens
Jenn-Air model JJW9527: The illumination for the clock, temp, timer, etc., is not functioning. munro@merricksoffice.com
  • munro149 Oct 04, 2010
    How do you even get to the clock?
  • munro149 Oct 06, 2010
    Assuming you can review what I was previously advised, there areno screws on the top. There are screws on the underside. I am not convinced he was familiar with this model.
  • 3,083 Answers
The display is a chip on the control board. Make sure the connector to the control board is tight, and if it's dirty, clean it with electrical contact cleaner. If you're handy with a voltmeter, you might be able to figure out a bad component on the board, cracked solder traces, etc., but otherwise, you will have to replace it.
Here's a site with diagrams and parts lists for your model. Pick your model out (they have many variations- probably color, etc.):
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JJW9527
On the diagram I looked at, it was part number 3 on the control panel.
Good luck, and hope this helps.
Posted on Oct 06, 2010
  • Jenn-Air Master
  • 1,711 Answers
First you need to check the wire multi plug on the display of the clock is well secure not loose or else. If everything is ok then the complete display clock control since they are all one unit need to be replaced.
Here in this link you can see all the parts layout bu also you can find the code of the clock and you can also order it if you like.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46557&diagram_id=656817#d656817
Posted on Sep 29, 2010
  • espressonist
    espressonist Oct 04, 2010
    First we would advice to proceed to replace the control-clock if you have at least some background in similar procedures. We mention this since we believe by the parts layout diagrams are very helpful to do this kind of jobs.
    Now get to the point. Just have a closer look to the link we have send you in the previous note. In this you will see how the electronic control is and you need to remove the panel control assembly - on the top, by removing the screws on the top, after you remove the panel control assembly.
    Now before proceeding, we advice to take a photo how the wires and the electronic control is located just for reference if you forget anything later.
    This is the time to remove the secure screw of the control and the wire plugs. Fit the new control and follow the reverse order for assemble back all wires and parts.
I get an F5 code. I have replaced the ERC, what next?
it seems like you have a bad control board. we can help you with that if you want to send it to us.
Dec 20, 2015 | Jenn-Air Ovens
Oven, clock, timers all work, but grill & cooktop do not function Jenn Air Model SVE87600
Check the back and make sure the wiring to the grill cooktop is not unplugged from the main oven.
Nov 04, 2013 | Ovens
MY JENN-AIR MODEL #WW2460B WALL OVEN DOES NOT DISPLAY THE CLOCK/TIMER. IT STOPPED WORKING DURING A SELF CLEAN CYCLE. IS THERE A WAY I CAN ORDER THE PART TO REPLACE IT MYSELF AND ARE THERE WIRING SKEMATICS...
There is a high limit thermostat that will cut all the power to the upper oven elements. Their is a wiring diagram in this link http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Wall-oven-Parts/Model-WW2460B/1266/0125300?pathTaken=&prst=0&shdMod=WW2460B
when clicking on it,it will say not avaliable. A trick i have found is to open that link and then using your computer tools select the maximum zoom i use IE set to 400% and its pretty ledegable.
Gene
Aug 11, 2011 | Jenn-Air Ovens
The center clock-oven module no longer lights up and the oven doesn't work, but the burners on top work. model rf341bxk. The oven light still works. Is there a fuse blown that I can replace?
Hello, welcome to fixya.
Unfortunately many modern ranges do not incorporate fuses into the control panels, other than the 15amp outlets used for plugging in external devices, they are typically the resettable type fuse.
Many manufactures have gone away from the typically glass fuse style circuit interrupters of previous ranges of say 15-20yrs ago and older.
If the clock display is not illuminated nor functioning, but the surface element functions appear fine, it is likely a fault within the clock ( also referred to as a timer or erc ) itself. Check for possible burnt or loose wires going into the timer such as L1 or L2 etc.
**Please unplug the range or turn off the 40amp breaker at your homes service panel before attempting any service to the range**
The part for the timer/clock is # 3196967 and retails for between $167 to $233 at "searspartsdirect.com" and "repairclinic.com" respectively as I type this on June 6/2010.
Hope this info was helpful to you...even if it isn't great news. Please take a moment and rate the info I provided and thanks for visiting "fixya".
macmarkus :)
Jun 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Clock readability
The problem is very likely a bad capacitor on the clock module. See this link for more info:
http://www.badcaps.net/forum/showthread.php?t=7902
May 03, 2009 | Jenn-Air JJW8230D Electric Double Oven
My jenn air dual oven timer, temp lights are going out
Sounds like another control board failure, common on this type oven. It appears that a capacitor (#C3 on board) overheats and goes bad. Replacement of cap is a simple soldering job but the caps can be hard to find, try electronics parts houses and explain you need a high temp replacement. Should cost you about a buck. See post by Briangem back in may of 2008, who turned me on to the target cap. Its a 35Volt 86mF.
Apr 29, 2009 | Jenn-Air JJW9830D Electric Double Oven
Jenn Air Oven Repair
HI thanks for the question. you can by pass the clock so the oven will work without the timer. call a tech near you, and ask them to by pass the timer. if i could get the wiring diagram, i could tell you how . its a simple thing to do. thanks the appliance doc. please rate my answer.thanks
Oct 08, 2008 | Jenn-Air Ovens
Need help unlock oven after self cleaning jenn air jjw9527
The temperature setting must be set on "Cleaning" and the oven cooking dial to "Clean"; otherwise the door will not open and forcing will damage the mechanism. Also, before the door will open, the internal temperature must drop to a safe level and a red "cleaning" light must go off, after the temperature drops inside the oven.
Aug 23, 2008 | Jenn-Air Ovens
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
191 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
