Brand new batt atv works fine until i use my winch then not enough juice in batt to start it if i wait 10 min then green light will come on but have to pull start it after that only runs for one mile and then quits then can to that all over again, took that batt out and put it in diff machine had to boost it to get it going after that the batt in that machine was fine. do i need a new charging part for my bike
  • 2 more comments
  • vicki_malcho Sep 29, 2010
    where is the stator located
    is it square box and is the reg little round thing connected to the batt
    how do you test it
    how to you test it
  • 11,896 Answers
Check your stator..this is what charges the battery from the start..then it goes to your reg/rec..this converts it to dc voltage..your stator puts out ac voltage first..then goes to your reg/rec..if either one of these is bad..your battery will never charge.
Posted on Sep 29, 2010
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield Sep 29, 2010
    Yep that's it.
  • Nate Stansfield
  • Position the pipe wrench tightly above the drive belt pulley to prevent the crankshaft from rotating when you unscrew the drive belt pulley.
  • 3
    Fit the proper-sized socket onto the bolt that holds the drive belt pulley to the base of the engine's crankshaft.
  • 4
    Hold the pipe wrench with one hand, and with your other hand unscrew the bolt using the socket wrench.
  • 5
    Pull down on the pulley until it slides off the crankshaft. Slip the drive belt off the pulley.
  • Nate Stansfield
    http://www.dansmc.com/electricaltesting....
    ELECTRICAL TROUBLE SHOOTING
    Will not crank over to start and nothing electrical works. Just installed a new battery. What can cause this problem? It was working fine when parked 3 weeks ago.
    Test the battery with a voltmeter, if good, check connection to battery. Has to have a real good ground.
    Mar 15, 2016 | ATVs
    2006 Mazda Tribute won't start. When I first purchased the car the fairly new-looking battery was reading low, so immediately had it replaced. Only to have the new battery weakening/battery light coming...
    think u hav a bad cable from the alternator to the batt--they wear and gain resistence eating up alternators--its the red cable used to charge batt--some mechaanics just add anothr wire beside the old and it works--hav a honest guy test the old wire
    Nov 03, 2013 | 2006 Mazda Tribute
    Won't crank has new battery
    if the lights come on you'r getting juice from the batt,if they go out when you crank the motor over batt is bad or you have bad batt connections
    Aug 27, 2012 | 2000 GMC Jimmy
    I have a 2011 rzr. the winch worked corretly the first time using it. Now when you push the out switch it goes in. Please help.
    Sometimes the winch cable can become pinched or bind up in the spool. This will make it act like it is going in when the out position is pushed. Try hooking your winch up to a post and turning it to free wheel on the winch, then slowly back the RZR up about 10-20 feet. This should be enough to free up any spots in the cable. Turn the winch back in to operating position, and try pressing the in and out on the switch to see if operation is normal. Otherwise someone may have switched the cables going into the winch, 1 yellow and 1 blue. Let me know if you need any more help, Daniel.
    Oct 10, 2011 | Polaris ATV
    Starter was turning over fine sounded like batt. juice was low now sol. clicks but no juice to starter batt. is new and hot
    If you have a test light, I would put the test light on the starter side of the solenoid, not the battery side. Try starting the atv, if it lights up, solenoid is good and there is an issue with the starter. Start with that, if it's clicking more than likely the starter is getting power but it can't do anything with the power. Sounds like the brushes in the starter are going bad, which can be replaced way cheaper than a starter. Another way to tell if it's the solenoid or starter is to place a jumper (flat blade screwdriver) across the terminals on the solenoid, if the starter cranks your solenoid is bad. Be sure to use an insulated jumper as the steel will get VERY hot. Let me know if this helps and if you need any more help. Good luck, Daniel.
    Aug 14, 2011 | Polaris ATV
    Brand new will not start
    like no juice? if no juice bad batt.. i just baught a new supermoto rode it 0ne day.. came out next morning no power.. nothing... tried to jump to take to dealer no power.... took batt. to dealer picked up new batt. under warrenty... went home power....
    Apr 09, 2011 | Triumph Bonneville T100 Motorcycles
    98' Cav.. Drove it to store, shopped, didnt leave anything running or turned on. Went to car, opened dr...no dome light (thought, hmph, must have burned out -- fix later). Tried to start car... I turned...
    this sound to me like at first I thought it was a fuse, as the problem went on it shifted more toward a weak cell in the battery, if a weak cell sits for a little while the battery will not hold the charge in that cell and that will cause loss of power, "its charge", in tne other cells. you had mentioned you used another battery and it ran great but when the battery was removed, things went wrong. You may check to see if there is water in your battery
    Aug 19, 2010 | 1998 Chevrolet Cavalier
    Dead battery replaced with new one. After a week sitting battery was dead again when trying to start. Any idea most likely culprits?
    you hav a drain somewhere in the wiring or a device is left on--was the new batt charged properly--recharge batt start car then disconnect until u find the reason for drainage
    Jun 13, 2010 | 2003 Mitsubishi Outlander
    Stalling
    Check your batteries, they might be ready to die. Stalling is a sign your are not getting enough power to the scooter and when you do, it runs until they run low again. Kinda like a cell phone batt, ones it dies and you wait awhile you can get it started but only for a couple of minutes before dying again.
    Apr 14, 2009 | Echo 3 TE SL7 3 New Electric Scooter by...
    98 ford mustang stuck in security mode
    sounds like ecm lost signal from key
    Sep 27, 2017 | 1998 Ford Mustang
    Computers & Internet Logo
    21 people viewed this question
    David Payne
    David Payne
