Question about Bausch and Lomb Bausch&Lomb Master Tripod
My Bausch & Lomb Professional Tripod 3 way Oil Fluid Pan Head Tilt Tension Knob is broken and the quick release plate is missing. Do you have parts for this unit?
    Master:
  • 473 Answers
Take off Ring Sitting Nob .... issue with tentionner Ring holder crack or base crake.. need to be change... Cause exessive force on the handle
Posted on Sep 29, 2010
783001 tripod manual
Most tripods do not come with manuals. Never have, so I doubt you'll find one. Try taking it to a camera repair shop and they can tell you how to use it or if it needs some parts.
Jan 04, 2012 | Bushnell Advanced 78-4030 Tripod
Unable to locate product code, sku #, or part # on bausch & Lomb tripod; trying to locate camera mounting plate for same. This is my first professional tripod not sure about measurements... Roughly...
Generally sold as a non-repairable assembly, same as most other tripods.
Same applies to loose 'spare parts'.
Many tripods are simply 'rebranded' to whatever name appears on them.
In terms of time and trouble trying to find a loose quick release plate, it might be quicker and cheaper to replace the entire unit.
Welcome to the disposable age.
Jun 11, 2011 | Bausch and Lomb Bausch&Lomb Master Tripod
We have a Bausch & Lomb telescope mounted on a tripod; it is 60" tall on tripod; tube is approx. 50", it is inscribed Bausch & Lomb Since 1853 & 2769. Is this a Harbormaster and can we get...
This is considered a toy telescope. Sorry. No manuals exist and you will not get any support at all on this brand.
Sorry. Next time you need to buy a real telescope. Something like this:
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=08942
Oct 25, 2010 | Bausch and Lomb Optics
Need a quick release plate for Bausch and Lomb Prof. Tripod
You probably will not find parts for this telescope. However you may find what you need by visiting a local well stocked hardware store.
May 25, 2010 | Bausch and Lomb Discoverer 78-1600...
Vivitar tripod release plate
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen.
Apr 26, 2010 | Vivitar VPT 2457 57" Tripod with 3 Way...
I have a Manfrotto 3265 tripod head. The quick
You can get the quick release lever seperately. Check the website for the part needed.
http://bogentripodparts.com/parts/head3265.htm
Hope this helps,
Andrew
Feb 17, 2010 | Bogen Communication Bogen Manfrotto 3265...
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
Bogen Manfrotto 3047 head
Dear spiderinkart,
To get the camera to secure properly to the release plate make sure that the bolt is screwed entirely into the camera bottom and then there should be a larger knob that rotates around the bolt that tightens down to the camera body. What I do to get a really tight fit is point the arrow on the bottom of the release plate labeled lens (that arrow when properly mounted should be pointed towards the front of the lens) to a 45 degree angle to the left of the lens, then I snug down the knob, and then I grab the release plate and turn it until the lens arrow is aligned with the front of the lens. As far as quick releaseing the camera from the legs when secured on the release plate you should be able to pull the lever away from the head and it should simply release the camera with the plate attached.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Mar 16, 2008 | Bogen Communication Bogen Manfrotto 3047...
3030G pan tilt head
The little brass arm is supposed to be a safety switch. In one position the release lever bumps into the brass are and will not turn so the quick release willnot come off. In the other position the brass arm is away from the lever so it swings freely and the quick release plate will come off. With the brass arm open the quick release lever shoulde lock open until you push the quick releae in place. If none of this seem to work on your head, you may be missing parts. Try www.bogentripodparts.com
Feb 19, 2008 | Bogen Communication Bogen Manfrotto 3030G...
Pan control not fluid when tension increased
Sounds like you might have gotten some dirt trapped under there. You might try to loosen it and blow it clean.
Apr 16, 2007 | Sunpak Video Pro M Tripod
Bausch and Lomb Bausch&Lomb Master Tripod Logo
1,005 people viewed this question
Top Bausch and Lomb Photography Experts
Tony
Are you a Bausch and Lomb Photography Expert? Answer questions, earn points and help others
