Question about Gestetner DSm415pf Digital Imaging Sytem
Error code sc120 - Gestetner DSm415pf Digital Imaging Sytem
Send me link viedo ?how to fix this code?help me
SC 120 Scanner home position error 1
The scanner home position sensor does not detect the off condition during initialization or copying.
If restarting your printer does not fix your printer you need a tech to replace some. Could be a bad sensor or bad BICU board.
Aug 15, 2016 | Ricoh Aficio MP1600L Printer
Where can i buy a replacement basket for my Royal SC120 12 sheet crosscut shredder
you may get one from the manufacturer spares on line
other wise take the top opening measurements of the container and you may get one from you local hardware shop in the plastic container section that will do as a replacement
Sep 01, 2015 | Royal 12 Sheet Cross Cut Shredder SC120
Sc120 error code
Home position sensor for the mirror carriage assembly does sense movement. When the copier is turned on does the mirror assembly move (under the glass)? If it does then clean the home position sensor. If cleaning it does not remedy it then it is a circuit board problem. If the mirror assembly does not move the problem is mechanical or a bad motor or related circuit board.
Nov 06, 2013 | Gestetner DSm645 Digital Imaging System
My royal sc120 shredder will light up but there is no sound will not run. I have cleaned out clogged bits of paper. What could be wrong?
Shredders have a reputation for being very unreliable...they often just quit like that...
You can try also to blow it out with a can of compressed air, but it probably won't help... not much else that you can do...
heatman101
May 27, 2011 | Royal Sc120 Shredder
I have the Royal SC120 model. The shredder does
1 or 2 gears are broken. royal doesn't make many replacement parts for their machines, might try calling royal at 1-800-222-2310. I would recommend replacing unit with a Fellows brand shredder. royal also makes Ativa brand- don't buy it either.
Dec 11, 2009 | Televison & Video
Error function sc120
The following are the possible causes of this error -yes you will need a technician:
• Scanner home position sensor
defective
• Scanner drive motor defective
connector defective
• Scanner drive motor connector
defective
• IOB board defective
Mar 23, 2009 | Ricoh Aficio 2018D All-In-One Laser...
50 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
