Question about SkyGolf SkyCaddie Handheld GPS Unit
SG5 indicates low battery after 11 holes of golf and turns completely off around the 15th hole. I fully charge the battery before every play and the green light indicates as such.
    Master:
  • 473 Answers
Issue with your Power Supply... Or Battery Need to be replace .
Posted on Sep 29, 2010
MY Yamaha golf cart is fully charged, I play 18 holes and the charger meter drops to about 50% and then the green light turns to yellow, Whats up with that??? Dave
Does the cart move? If you still have good battery power then I would the battery meter. Otherwise you might have a low or bad battery. Need to check each battery under load.
May 22, 2017 | Golf
Patterson elec golf cart . fully charged with new batteries After 8 holes power indicator flashes but cart still has power to complete 18 holes.Why does it flash
Did you use the correct amp hour high quality batteries or just the cheapest, this is a battery voltage issue having to do with amp hour rating of the new batteries.
Nov 30, 2016 | Golf
My golf buddy platinum screen is blank. Battery fully charged,screen only comes on when the charger is plugged in.
Could be a defective battery falsely indicating it is completely charged.
Nov 10, 2016 | GPS
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
I have a golf buddy that lose it charge after about 11 holes can I replace the batteries?
I also had the same problem of the battery not lasting a whole round. I found out that if the unit was left for any length of time after it had been fully charged, it would start to discharge even though it was turned off. I now make sure that if I'm playing golf the next day I will put it back on charge overnight.
this has worked successfully for the last 5 months approx
i also looked to find a replacement battery but without success
hope this helps
Feb 22, 2015 | GolfBuddy Golf Buddy VOICE GPS
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
My SG4 I fully charge it and when I am playing after 3or4 holes shows low battery. After a while it shuts down. I then restart it and it shows almost a full charge and I then have no problems.nThis is...
the battery is failing, that is what they do when they are at the end of there useful life, it will show fully charged but drain down very quickly
Jul 29, 2010 | SkyGolf GPS
Sky Caddie SG5 will NOT turn on
Hi David
I know this is some time after you posted your question. I had the same problem with mine and was ready to throw it in the bin.
Searced the net and someone had posted that they bumped into a Skygolf rep who suggested lifting the charging flap and blowing into the hole.
I thought he's having a laugh, but guess what it worked.
Good luck if you've not already fixed it.
Mark
May 03, 2010 | SkyCaddie SG 3.5 Handheld GPS Receiver
Installed new battery and still shows low battery after 2 holes and 24 hours of charging
if all cables on battery are clean and tight, then most likely it is the alternator putting out a low charge. test the alternator it should be at least 14 or a little more when running. 12.5 to 13 when off. if alternator is ok, then check all wiring from alternator to battery, and make sure the battery ground is ok!! best of luck carl,
Dec 04, 2009 | SkyGolf SkyCaddie SG5 Car GPS Receiver
SkyGolf SkyCaddie Handheld GPS Unit Logo
481 people viewed this question
Top SkyGolf GPS Experts
Steve
Steve
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
