Question about Isomac Giada Espresso Machine
Isomac giada. changing gasket in filter cup holder
2 Suggested Answers
SOURCE: isomac giada gakset change
Yes you can. There's a bit of work involved. The issue is you have to remove the boiler through the top of the machine in order to access the gasket. If you're not careful, you can break one or all 3 lights because of the wires attached and the limited amount of room. I would take pics of everything before you begin. Then remove the 2 screws from the top of the machine. You can see all the wires and the brass boiler. Next remove the 4 cap screws near the brewhead where the portafilter goes. When you do this, you will see the boiler is now loose. I will let you decide how you want to do the rest. Either remove and label all the wires, or remove some of them or whatever you choose. Once you can remove the boiler, you will see that the chrome brewhead cover also comes off revealing gasket. Remove the damaged gasket, and clean the area where it sits. Put on the new gasket and put everything back. That's it. Good luck!
Posted on Apr 27, 2010
How do I remove the shower and the diffuser on an isomac millenium?
Hi
You need to remove the brew head gasket in order to get the screen out. Then you will see everything else. The brew head gasket holds everything in.
Jan 16, 2011 | Isomac Millenium Espresso Machine
Leak around filter
Any leaks aroung the portafilter is usually the brew head gasket. You just need to replace the gasket. The gaskets only last about 1 year so if yours is older that that, it needs to be replaced.
Dec 07, 2010 | Isomac Millenium Espresso Machine
WHERE CAN I OBTAIN ISOMAC SPARES, [GROUP HEAD GASKET]
I think Chris coffee sells most of those parts.
Jun 18, 2010 | Isomac Giada Espresso Machine
I broke the peice that puts water through the coffee basket on a Keurig Elite B40 Coffee Maker where can I buy parts for this?
If you are talking about the K-cup holder that punches the bottom of the k-cups, they usually are not for sale, and you can only find them on ersale sites like Ebay.etc...
you could also go buy a "Keurig My K-Cup Reusable Coffee Filter"
and just use the main grey plastic filter holder... but you will have to puncture the bottom of the k-cups yourself before dropping them into the holder...
You wont need the filter basket or the lid if your using k-cups... just the filter holder...
dont forget to punch a hole in the k-cup first...
May 14, 2010 | Keurig Elite B40 Coffee Maker
Isomac giada gakset change
Apr 16, 2010 | Isomac Giada Espresso Machine
Coffee grounds in cup w/ Keurig 60
I have the answer because it is happening to me now. Moreso with the Timmothy's brand K cups. I did a little forensics on a good brew, and then on two slow with grounds in the final brewed coffee.
The inner filter is placed in the k cup and it is not glued to the top rim. The bag then just sits on the bottom of the k cup as it is passed with the hot pressurized water.
The good cups are glued to the top rim and there is no problem.
To investigate....remove the foil top carefully after the cup cools. Rinse out the grounds, and the filter bag should still be glued to the rim. if you've got a dribbler and one that passes the grounds into the cup...you will find the filter bag had fallen loose from the rim. Manufacturer defect...You bet!!!
I had 8 from a box of Timmothys 25 count pass grounds. Green mountain coffee may once in a while pass grounds, but very rare and maybe three times in the 4,000 k-cups we've used.
Mar 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
I have to hold the filter when making coffee - if I don't the filter holder starts to unwind and then coffee and water spurts everywhere. It has only just started this and I clean it constantly making...
Please check the following:
1. Hooks - the hooks could be worn
2. Gasket - it could be worn or broken.
You need to replace the filter holder or the rubber seal/gasket.
Hope it helps and have a great day!
Jun 16, 2009 | Coffee Makers & Espresso Machines
Coffee grinds on K cup holder
try removing the K-cup holder and inspecting the bottom hole opening. This is where the bottom of the K-cup holder would go through. Sometimes grounds can rest on that edge and fall into the coffee. I hope I could help!
Feb 15, 2009 | Keurig Special Edition B60 Coffee Maker
Pressure problem
Just a thought here...are you using the correct grind of coffee and have you tamped it thoroughly to keep the pressure up through the grounds? There are a number of sites on the web which talk about how to use an espresso maker. I'm sure you'll get the inspiration you need there to learn to do it right.
Jun 01, 2008 | Isomac Giada Espresso Machine
Isomac expresso machine
We have owned an Isomac Millenium for ~2y.
In the first months, we encountered low water to the brew head, although both the steam and hot water wands had decent pressure and flows.
Adjusting our grind, so that the coffee beans were coarser helped immensely--for awhile.
Then the problem gradually reappeared as an extremely slow brew time. Our machine was still relatively new, so we shipped it back to our place of purchase. It came back working just great and interestingly the filter in the resovoir was now filled with the filtering particulate it did not come with.
I am surmising, that however great the engineering is on the Isomac, manufacturing leaves something to be desired. Do not let your warranty expire. Pay the shipping and fix your otherwise great machine.
Nov 05, 2007 | Isomac Millenium Espresso Machine
Coffee Makers & Espresso Machines Logo
250 people viewed this question
Top Isomac Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you an Isomac Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
