Question about Philips 26MF605T/17 26 in. LCD Television
Televions hi there on my phillips matchline flat tv. somes times the tv just turns itself off. you take the power supply off plug back in its ok. now i noticed a unusual noise from the power black box. im lookoing to get hold off a new power black box. can you help. alec
  • 608 Answers
You are not the only one I can tell you that. I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
Phillips 50pfp55320 Flat screen tv will not turn on
The symptoms described suggest a power supply problem
Feb 22, 2013 | Televison & Video
MY MATCHLINE PHILLIPS TV WONT TURN ON
Ok sir, is the power on light functions?
Jul 10, 2011 | Televison & Video
My Phillips plasma when turned on, turns itself off straight away. Any ideas? All the repair places are closed over the weekend. Now does not turn on at all.
Tries tv unplug,replug tv back about an hour later.By letting tv resetting itself back to the factory setting.Now the tv should be working again.If still have the same problems.The power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to guy a whole refurbish power supply board for the replacement.
Jan 07, 2011 | Philips 42PF9966 42 in. HD-Ready Plasma...
Hi, i have a problem with my lg 32" ld350 tv..it
Hello.
This is a thermo-related issue. It happens when some parts in your TV reach certain temperature and fail creating short so TV shuts down and goes into protection mode.
In your TV the only thing that you can do is to replace Power Supply and hope it would help. Main board generally has nothing to do with temperature. Another probability - LCD panel itself (more likely back light inverter boards that are part of the panel, you can't order them separately).
There is inexpensive way to determine if it is power supply or not. You have to purchase fast-cooling spray that technicians use for diagnostic purposes (you can buy one in electronics components store).
You have remove TV rear cover so you have access to power supply board (the one where power cord goes). Turn on TV and let it run and eventually shut down. After that unplug it from wall outlet and use spray to cool down power supply board. Make sure you don't spray too much or you cooling anything else besides that board!. Let residue evaporate and plug TV back and try to turn it on. If it act OK and stays on for long time again - replace power supply and you should be OK.
Otherwise it is time for new TV. Panel is too expensive to replace.
Regards.
Russ.
Dec 01, 2010 | LG 32LD350 32 in. LCD TV
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
Philips model no 29pt8319/57r
Can you tell me some more then "power supply fault". I need some more information ...
Feb 23, 2010 | Philips Televison & Video
I have a phillips matchline plasma the power light keeps flashing green then starts flashing red is there a problem with the connection between the tv and the master box?? plz help!
According to " Consumer Affairs. com", the problems with seris of Phillips plasmas are innumberable. And they all start with the flashing red light, from 3 - 7 times. Baased on the information you gave, there is something wrong with the TV itself, not your perifrials. I would contact Phillips/ Magnavox to see if they will pay for an authorized sevice center visit, or even ship you a part to solve the problem.
Apr 11, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Tv turns off by itself
Solutions?
Hope this helps
Apr 07, 2009 | JVC LT-32P679 32 in. LCD TV
TV turns itself off then back on
Solutions?
Capacitors are very inexpensive but require some soldering skills to repair.
Hope this helps
Dec 15, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Open Questions:
Philips 26MF605T/17 26 in. LCD Television Logo
188 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
