Question about HP OfficeJet 7310 All-In-One InkJet Printer
Print cartridge in right stall not supported !. was working fine for a long while with the same cartridge. still has ink. took it out, put it back in. is there a known glitch with these things or what? should i spend the money for a new ink cartridge?what do you think?
    Scholar:
  • 78 Answers
There are a number of known glitches with these models. Without having a known good or new cartridge to try, you should remove both of the carts, close the lid, and pull the power cord out of the back. This will reset the printers ram, and force it to reload. Wait 10 minutes, plug back in and power on. When it finishes making noises, insert the carts, black first, and if it clears, you're good. If not, you will need to buy another cart to go any further.
Posted on Sep 29, 2010
  • murrtom99 Jun 23, 2011
    Didn't work for me.
HP PSC 2355 print cartridge not supported?
If this is not a factory new cartridge then that may be the reason it is giving this error.
Apr 17, 2017 | HP PSC 2355 All-In-One InkJet Printer
Dell A920 cartridge stall error.
Hi, I HAD the same problem, but not anymore!! I just opened the top to expose the "inside of the printeri" and checked the long clear band at the rear behind the print head. Make sure that the clear ribbon is NOT TWISTED. There is a small metal bar with a small extended part on the far left interior of the printer. Just make sure that the slot on the clear band is fitted on that extended part. This will put the print head back "on track" This worked for me!!
May 30, 2009 | Dell A920 InkJet Printer
HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
byee
May 09, 2009 | Office Equipment & Supplies
My epson stylus cx3200 is not printing in black but does print colour even though ink levels in both colour and black cartridges are fine
If you are brave I had the same problem. I removed my ink disconnected the data ribbon to the Head. Took off the nozzles. I used a child's med. syringe with the tube. Filled it will rubbing alcohol. placed the tube on the head where the ink cartage attaches and slowly put pressure on the syringe. Be care full it will flush the black ink everywhere. I kept doing this till the black was all flushed out. Put it back together. make sure you put the ribbons back in the right way. Mine works great.
Mar 04, 2009 | Epson Stylus CX3200 All-In-One InkJet...
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Are these genuine HP ink. If not try using Original ink.
If its already the original ink then check the Exp date of the ink and try cleaning the copper contacts of the ink ( not the nozzles ) of the ink and the printer
All the best
Sep 24, 2008 | HP PSC 2410 All-In-One InkJet Printer
Print Cartridge in Right Stall not Supported.
print cartridge colour ink is not workink fix with hp print
May 19, 2008 | HP PhotoSmart C4180 All-in-One Color...
Carriage hits the right inside of printer - will not print
if the lights are flashing along together there is a cariage stall. The ink cartridge craddle is hitting something. Find out what and remove it if doesn't belong there. First of all remove and reinsert both cartridges. One of them may be inserted wrong.
Mar 19, 2008 | Office Equipment & Supplies
Printer cartridge stalled
Have you put in new ink cartridges?
Get the printer to move the carriage away from the side where it normally rests. Look inside there, and beneath the rest area, sometimes there is a little rubber stamp that presses up against the cartridges. It usually is filled with dry ink. Take a wet paper tower (probably several of them) and try to get as much ink as you can up. Also, there is sometimes a little rubber wiper that cleans the printhead as it passes by. Make sure this is clean also.
Now take the cartridges out. Get another clean paper towel, sopping with water. Press the nozzels down against it, but don't wipe. Just dab them, until you're getting some solid lines of ink on the towel.
Then look for the pattern of copper colored dots on the cartridge. Clean this with alcohol, and then look inside the printer where these dots (contacts) would line up inside the carriage. There will be a smilar pattern of dimples. Clean these with alcohol, and let it dry.
If possible, you might want to try to fit a towel damp with water beneath the print carriage (where the paper runs through).  This collects a lot of ink sometimes.  Be careful not to force anything.
Finally, put it all back together and try your print.
Thankyou,
Oct 29, 2007 | HP PSC 1315 All-In-One InkJet Printer
Canon Copier
TRY UNINSTALLING THE DRIVES COMPLETELY  THEN REINSTALLING THEM.........mAKE SURE YOU HAVE THE SAME EXACT CARTRIDGE
Oct 09, 2007 | Canon BJC 8200 InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
717 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
