Question about Gaggia Classic Espresso Machine
GAGGIA CLASSIC COFFEE GETTING TOO HOT CREATING LOADS OF STEAM
OUR CLASSIC IS GETTING TOO HOT AND CREATING LOADS OF STEAM AND BITTER TASTING COFFEE. ITWORKED PERFECTLY UP UNTIL A CAPPACCINO WAS MADE, SINCE THEN WE CAN'T GET THE TEMP CORRECT.
ANY SUGGESTIONS?
CLAIRE
  • COFFEECLAIR May 28, 2008
    Many thanks rjorge26, A freind gave us an old unworking machine and we replaced the coffee thermostat. Perfect coffee again!
Dear friend, i do have one exactly the same. The best thing you can do is put water inside the machine and leave it on for hour an hour at least. Try that.
Posted on May 27, 2008
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
No steam coming from frother
If you are getting hot water from the grouphead to make coffee then the nozzle at the end of the steamwand could be blocked, use a paperclip to clear. If the problem is not fixed after cleaning nozzle then machine need to be descaled.
Oct 02, 2011 | Gaggia Classic Espresso Machine
Hi, my 4 year old gaggia classic coffee machine's steamer no longer works. The coffee bit still works fine, but when i twist the knob to let the steam through, nothing happens. Can this be fixed easily?
It could be that the nozzle is blocked, and or the steam valve is blocked. Try descaling machine, if that does not help then you might have to remove steam valve to make sure it is not blocked.
Jul 02, 2010 | Gaggia Classic Espresso Machine
Gaggia Coffee Classic Steam Valve Leaking - No Pressure!!
Yes it can be repaired if you have the parts, you will need the complete steam valve with the o-ring that connects to the boiler check the diagram below.
Aug 21, 2009 | Gaggia Coffee In White, White MDF...
No steam
Is the coffee hot or cold?
If hot then the steam wand is clogged, try inserting a paperclip in the hole(Remove the parnello black plastic covering silver steam wand) at the end of the nozzle.
If cold then the element is not heating, if you remove the top panel on the machine there is a thermostat on the boiler. That might be damaged, some of them are resettable (it will have a red or brown pin in the middle) if it is a resettable one then push in the pin, if not then it will have to be replaced.
May 17, 2009 | Gaggia Classic Espresso Machine
Gaggia classic not producing hot coffee
Two questions; is the water coming out of the head without coffee hot and can you get steam out of the wand?. If yes to both then try running the group with the portafilter in it to warm that up before making a coffee.
Mar 26, 2009 | Gaggia Classic Espresso Machine
Where do I locate the fuse for the steam nozzle of the Gaggia Classic? - the coffee brews but no steam will come out to froth up -I was advised it was probably the fuse -all othe rparts have been cleaned
If the coffee brews hot then the problem is a blockage on the steam valve nozzle or line. Try removing steam wand and opening valve to see if it works, if it does the problem is in the wand that has been removed. Dismantle parnello and using a paperclip clear out the hole in the end of the steam wand.
Jan 14, 2009 | Gaggia Classic Espresso Machine
Airlock in new machine
I have a similar problem, I think. I get water through the steam thing, but not through the brew head. Not sure what to do either.
Oct 07, 2008 | Gaggia Classic Espresso Machine
Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
Feb 03, 2008 | Gaggia Classic Espresso Machine
Gaggia Classic Espresso Machine Logo
150 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
