Question about Texas Instruments TI-15 Explorer Calculator
5/6 as a decimal - Texas Instruments TI-15 Explorer Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
To convert a single result between fraction and decimal, press the FD key. To have all results come out in decimal, press MODE and select . (decimal point) on the first line.
Posted on Sep 29, 2010
Can you round 3,150,000 to 2 decimal places
Huh?
To round off a number to 2 decimal places.... you would have to have a decimal. Your number of 3,150,000 implies 3,150,000.00
There is no rounding in this case. It is simply adding a decimal and two zeros after the decimal.
Semper Fi,
Z
Jun 13, 2017 | Office Equipment & Supplies
FX 82 es scientific calculator. How I get decimal expansion of numbers?
Meaning what, exactly?
If you want a decimal representation of an exact number, press the SD key to switch from exact to approximate (decimal). If you want to expand a decimal number in powers of 10, separate all the digits, multiply every digit by a power of 10 with exponent equal to its position as counted from the decimal mark -1. To the left of the decimal mark, the exponent is positive. To the right of the decimal mark, the exponent is negative. Sum everything
Example
345.678 =3*10^(3-1)+4*10^(2-1)+5*10^(1-1)+6*10(-1)+7*10^(-2)+8*10^(-3)
Jul 21, 2015 | Casio Office Equipment & Supplies
Why won't it let me put decimals in a list in
The decimal mark may be wrong. In the US and Canada the decimal mark is the point. In some European countries (notably FRANCE) the decimal mark is the comma.
Dec 11, 2012 | Office Equipment & Supplies
Fraction to decimal function not working,only reducing decimals not converting them to fractions when using proper 2nd function option
To force the calculator to display a result as a decimal number, try putting a decimal mark at the end of a numerator or denominator. If you are using radicals, put a decimal point at the end. Example: enter square root of 2 as SQRT(2.). Notice the decimal mark at the end of 2.
Jun 13, 2012 | Texas Instruments Ti-30Xs Multiview...
Define algebra:decimal
Decimal is the base-10 notational system for representing real numbers. The expression of a number using the decimal system is called its decimal expansion, examples of which include 1, 13, 2028, 12.1, and 3.14159.
Each of the arabic numerals 0 to 9 is called a decimal digit, and the period placed to the right of the units place in a decimal number is called the decimal point (or, in the case that a comma is instead used for this purpose, the decimal comma).
The decimal is a way of managing numbers that has ten as a starting point, or base. It is sometimes called the base ten or denary numeral system. The word "decimal" is also used instead of the word "period" to point out the dot that is sometimes used separates the positions of the numbers in this system. Almost everyone uses this nowadays and prefers the convenience of it probably because it shows up most often in calculations in nature and has "one" as another starting point for the system. The number one is usually the easiest to work with in calculations.
You may go to the link below for decimal tutorial:
http://www.algebra1help.com/flash/noflash/3.html
Jun 16, 2011 | Computers & Internet
Explain "CUT", "UP", "5/4"
CUT: Values are cut off to the number of decimal places speicified by the current Decimal Place Selector setting
UP: Values are rounded up to the number of decimal places speicified by the current Decimal Place Selector setting
5/4: Values are rounded off (0,1,2,3,4 are cut off; 5,6,7,8,9 are rounded up) to the number of decimal places speicified by the current Decimal Place Selector setting
May 04, 2011 | Corporate Express CEB95005 Calculator
How do I convert decimal to fractions, and fractions to decimal with this unit?
Decimal to fraction: Type in your decimal (i.e. .5) Then press [MATH] > press [ENTER] on [>FRAC] Then press [ENTER] again Example: .5>Frac 1/2 For a fraction to decimal: Simply type in the fraction and press [ENTER] Example: 1/3 .33333333333 (*Note that the decimal value is truncated to fit the screen)
Hope that helps! Have fun calculating!
May 03, 2011 | Texas Instruments TI-84 Plus Calculator
Problem for Casio FX-260 Calculator Changing fractions to decimals
To force a fraction to be displayed as a decimal number put a decimal mark at the end of the numerator OR the denominator. Fraction/decimal result is always decimal.
Nov 12, 2009 | Casio FX-260 Calculator
Cant get answers in decimal format, I would like to set up my casio fx83es so that the answer is in decimal format all the time.
To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
Oct 04, 2009 | Casio fx-300ES Calculator
Texas Instruments TI-15 Explorer Calculator Logo
27 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
