Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Failed to receive broadcast E202 Sharp Aquos Dolby Digital Energy Star 42 inch HGTV Television
  • 20 more comments
  • Donna Ryan Sep 29, 2010
    Does it not get a signal of any sort? NO What about from DVDs, do you have a DVD player attached, does that work? YES and NO Does not work just fine with regular TV signal? I accidentally hit JUST ONE button (don't remember which one, but this happens all the time!
    It says "Failed to receive Broadcast E202...
    Cable box...and I tried to navigate and it just brings up a box in the upper right hand corner that says: Cable Digital 79.5 and the cable box just has two dashes in it for channel 32 like this - -
    Are you still there?
    You Who ...I am missing Oprah!!
    Let me try that...brb
    Nothing...still the same.
    The channel that came up was 975 so I navigated to 369 (Oprah) and it just sat there doing nothing....with the same error E202...and the cable box says: 369
    The channel that came up was 975 so I navigated to 369 (Oprah) and it just sat there doing nothing....with the same error E202...and the cable box says: 369 Hide Comments
    Solution 1posted 31 minutes ago
    micromatikal
    Rank: Wiz
    Rating: 81.03%, 387 votes
    What do you mean exactly when you say "failed to receive broadcast"? Does it not get a signal of any sort? What about from DVDs, do you have a DVD player attached, does that work? Did it used to work just fine with regular TV signal?
    Thanks, let me know more and I can definitely help!
    Tim
    Add a comment for micromatikalReport abuse Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
    •micromatikal•22 minutes ago
    Oh I missed the E202 part, ok that usually means it just tuned to a channel that it doesn't know how to receive. Try navigating to another channel manually, input channel 32 for example, does it attempt to go to that channel? Are you using a cable box / satellite box or plugged directly into the wall?
    Thanks
    Tim
    Reply
    Comment:
    •micromatikal•10 minutes ago
    Yes I am still here, the reply isn't instant. You need to either navigate to a new channel with your cable box remote, if it will not let you and just stays at that -- screen you will need to just RESET your cable box. The easiest way to do that is to just unplug the cable box from the power source, then replug it in. This should get it back to a recognized channel, currently it is stuck on that .5 channel, and that is the problem. Just reset your cable box and you should be able to get all your channels back.
    Tim Reply
    Comment:
    •micromatikal•5 seconds ago
    After resetting your cable box it still shows the channel as --? ANd you can't change channels or manually input a channel? Reply
    Comment: Thank You!Was the solution helpful?Show your appreciation by commenting on Failed to receive broadcast E202 Sharp:
    I don't want to Accept this solution
    •Continue working with this Expert by posting more comments - Reply to micromatikal
    •No, I want to work with a new Expert - Ask Another Expert
    X
    Are you sure you want to withdraw your problem?You should only withdraw your problem if no Expert is giving you a satisfactory solution for this problem, and you would like to post another problem. If you want to continue working on this problem with another Expert, Go Back, and pick the Ask Another Expert option. back
    Need additional assistance?
    •Get Answers from our Top Flat Panel Television Expert
    •Find the Top Flat Panel Television Repairers in your area
    ...sorry about that.
    brb
    nothing ...just sits there...like the buttons are frozen or something
    nothing, it just sits there, acting like the buttons are frozen, but they are not, because I was able to use them to get to channel 369
    oh great...I am not sure where that is!
    I found it, and hit input and it is acting frozen too!
    did you get the last comment that I found it and IT is acting frozen too!
    Ok, I got to the input page by turning off and turn back on...how do you navigate down and what input do I put it on?
    Never mind, I got it....thanks
    we are done....thank you
  • Anonymous Mar 30, 2014
    I need a remote control for a 32 inch Emerson Energy Star television set 2011
  • Anonymous Mar 31, 2014
    Sharp aquos LC-60LE832U running off rooftop anntenna reads failed to receive broadcast sE202
    President:
  • 2,777 Answers
Tim
Posted on Sep 29, 2010
  • 3 more comments
  • Tim Grayson
    Tim Grayson Sep 29, 2010
    Thanks
    Tim
  • Tim Grayson
    Tim
  • Tim Grayson
  • Tim Grayson
    It sounds like you are on the wrong input on your TV, try hitting the INPUT or SOURCE button (it will have one or the other) on the TV remote... it should take you back to the TV input eventually, go through the inputs until you see TV...
    Tim
  • Tim Grayson
    Make sure you use the actual TV remote, the remote that came with the Sharp TV, and are hitting INPUT or SOURCE.
    Thanks
    Tim
How do I set a reminder for a program on sharp aquos lc266 42 television ?
I have a Sony TV but if yours is a digital tv this should work . Go into the guide and select the program you want to be reminded of then a option should be available to remind you
Oct 10, 2014 | Sharp Lc42d65u 42 Inch Full Hd 1080p Aquos...
Sharp aquos instructions
That means the channel is active but but there is a problem with the delivery by the broadcaster, not a defective TV.
Dec 28, 2013 | Televison & Video
Failed to received broadcast E202. what's wrong?
It means that the tv doesn't gets the correct signal from the cable or the antenna - check them.
Oct 07, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I dont want to use cable. I plugged a rabbit antenna and i get the message "Failed to receive broadcast (E202)
you need a antenna with digital capabilities.you can generally find them cheap and make sure tv is set on antenna instead of cable.
Jun 28, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Error Code E202, no picture, Sharp Aquos LC-45GD1E
Ur tv is not getting a broadcast signal,or ur tv cable or free air signal not getting from air antena,cables or dishes signals,or strong enough comming through.Get a better antena,like a digital antena,or a roof antena for better free air signal,cables or telicoms signals check ur boxes,push the power button OFF/ON to reboot it,to get signal back.
Apr 05, 2010 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
May 22, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Dec 03, 2008 | Sharp Aqous LC-26D5U Television
37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
Aug 13, 2008 | Sharp Aqous LC-26D5U Television
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
10,425 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
