Question about Refrigerators
Samsung rs20 fridge free
Fridge not cooling properly. 2and a half years old. Defrosting freezer rectifies this but only for a couple of days.
  • 1 more comment
  • gibblenomo May 28, 2008
    My problem is due to a design fault which Samsung have agreed to rectify. I did not know it but this particular model of fridge-freezer has led to a very public campaign culminating in a "Watchdog" programme about Samsung. The company has agreed to fix all fridge-freezers of this model which malfunction in this way.
  • dtoram Jul 25, 2008
    hI I have the RS20 the freezer part is leaking water and freezing ath e bottom so when you open the door it starts to defrost then getting puddles of water on the floor
  • mrafiq1939 May 08, 2009
    I got a Kalvinator no frost refregerator model knt283gy. On compressor return pipe ice is formed when the compressor is working. Is it harmful for the compressor. It is necessory to reduce gas in this fridge. Thank you . Rafiq
  • 525 Answers
Frost-Free refrigerators have a defrost cycle that they must go through after every several hours of accumulated run time. This is normally done by mechanical means which include a: 1.Defrost timer
2.Terminating thermostat
3.Heating element
Timers are usually 1st to fail. To test the timer you can manually rotate the timer knob to a defrost cycle but then it has to be rotated out manually also. To test the timer, rotate the knob slowly until you hear a distinct click or snap, then stop turning.If the refrigerator is running,(which it should be because it is attempting to cool), it should immediately shut off.
Within a few minutes you should be able be able to hear sizzling noises and/or popping or cracking sounds. If you observe any of these noises, then you have a faulty defrost timer. Allow the heater to remain on for approximately 45 min. to 1 hour, (you may hear water running into you defrost pan under the unit, behind the toe-plate grille), then rotate the knob until the refrigerator comes back on. The unit should then work normally for another few days before you have to repeat the cycle until you replace the timer. If your test is inconclusive, then you will need a technician to do the rest.
Manufacturers locate timers in varying positions depending on design. Usual locations are in:
1. The fresh food compartment, mounted in with or around the cold control,(identifiable by a small knurled knob protruding out of a protective covering). It is usually a small, black, odd-shaped component with the knob on it.
2. Behind the toe plate grille mounted to either side of the frame.
3. On the outside, back wall, inside a rectangular shaped box with the knob protruding through the hole.
If you are unable to locate the timer, then a technician should be contacted for service.
Hope this helps...Let me know if I can be of any more assistance.
Posted on May 25, 2008
  • David Emmel
    David Emmel May 29, 2008
    Thanks for the feedback! I will store this in my memory bank for future reference. You may have just helped hundreds of other consumers fix their problems.
    Illeagle
  • 828 Answers
Your automatic defrost system is malfunctioning. Problem could be in the defrost timer, heaters, or defrost thermostat. I suggest you call the place of purchase and request service. At 2 and a half years the parts will not be covered under warranty.
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
I have a three year old Amana bottom freezer double doors 25 cu ft. The freezer is working fine but the fridge is not cooling at all. I tried defrosting had it unplugged for two days. Tried cleaning the...
There is an evaporator fan locateed inside top of the freezer compartment. It is normally hidden behind a plastic cover. It should be running whenever the Fridge is calling for cooling. Check to see if this fan is running. My suspicion is that it is not running. Replace this and you should be back in business.
You will see the fan assembly at the bottom right corner of the picture.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174550&diagram_id=28601573#d28601573
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 14, 2010 | Samsung Refrigerators
Motor runs, freezer defrosting and fridge won't cool
If you have frozen coil at the back of the freezer section, then the defrost thermostat is usually failing. Allow the fridge to defrost completely overnight. If the fridge restarts cooling immediately after defrost, then the problem was the defrost system. In that case the fridge will stop cooling again in a couple of days, as soon as the evaporator coils restart freezing and the condenser goes under stress with the whole cooling system loosing efficiency.
Nov 25, 2008 | Jenn-Air JCD2389G Side by Side...
Samsung twin cooling fridge/freezer model Rs21dcsv Fridge temp control led display digit flashing and fridge not at right tempreture
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Jul 31, 2008 | Refrigerators
Frig side is not cooling.
Check if there is frost on the back wall of the freezer, if so it is not defrosting. Many GE fridges need a new defrost heater every couple of years. If it's not defrosting, you can get by for a while by unplugging the fridge and leaving the freezer door open for 24 hrs, then plugging back in.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung Fridge Freezer Model RS20
Renee,
There are a few things we need to look at. The likely cause is frosting up of the coils. This will also stop the fan. The best thing to do is to defrost the unit completely. The easiest way to do this is to shut it down and leave the doors open for 24-48 hours. You'll have to mop up a surprising amount of water. Now, why did it happen? Probably humidity due to 'window shopping', not closing the doors/bad/dirty gaskets, leaving liquids in the box which are uncovered. If this doesn't fix it...and you'll know after a week or so, it may be that the unit is low on gas or has a defective defrost timer...but that is getting ahead of ourselves.
Jan 22, 2008 | Refrigerators
Refrigerators Logo
890 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
