Question about Hotpoint Washing Machines
Hotpoint WMD940 is leaking onto the floor, is there a filter that can be emptied?
  • 1462 Answers
SOURCE: where is the filter
filter should be checked regularly and is a pain to do on hotpoint. however, blocked filter would not cause leak.
remove small panel at bottom back.
you will see a large diameter hose running from tub to pump.
undo this hose at the tub end and you will find filter inside hose.
carefull, water will come out
Posted on Sep 18, 2008
jyackle5
  • 8197 Answers
SOURCE: Hotpoint Ultima WMD940 F-03
The error code F03 indicates a problem with the pump out of the washer or a failure of the pressure switch that controls the water fill. This is a problem that you should have a technician diagnose and repair.
Good Luck
Please rate FixYa!
Posted on Dec 19, 2008
ginko
  • 19396 Answers
SOURCE: i got a hotpoint wmd940 and on a cycle it bleeps
Hi.
If the door is closed, then the Door Lock micro switch may need replacing.
The switch can be tested by a technician bypassing it or reading impedance to see if micro switch is opening and closing.
Try first disconnecting power for a couple of minutes to reset the control board.
If you need to contact a technician call the number listed on the owners manual.
Regards.
Posted on Dec 17, 2009
iwillfixforu
  • 619 Answers
SOURCE: have just installed my WMD940 Hotpoint washing
Did you remove all of the shipping bolts?
Posted on Jan 31, 2010
  • 6277 Answers
SOURCE: Hi there I have a Hotpoint
Hi Sheena from retired Englishman in SW France @ 21:51 Sun evening (nothing on TV!)
Sorry if this seems a silly question/answer but have you removed the dispenser completely and ensured that it is not blocked anywhere, especially the conditioner/softener drawer area? Normally the pre-wash and wash powders sit in open ended trays to drop straight into the drum but the conditioner does not. It is not allowed out until the right time- it has to be flushed/siphoned out by the water feed. A common problem is that the tube/pipe which is in this tray down which it siphons is blocked- possible by a mix of powder and conditioner. It is easy to accidentally let the powder spill into it when filling.
My advice is to pull the drawer completely out and give it a good clean out, especially the conditioner bit!
Dispensers are removed either by pulling almost all of the way out then 1) pressing down on the lip at the rear to clear or 2) releasing the clip underneath the dispenser or 3) by lifting upwards just as you are pulling it out, whichever is the way for your machine.
Hope this cures the leaking!
Best of luck,
John C
Posted on Feb 06, 2011
My hotpoint ultima dryer has no power to it changed fuse checked plug socket emptied water tank cleaned both filters
power comes in at mains lead goes to the choke /filter from here onto the door interlock switch then onto timer ......hope this helps
Feb 26, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hi my hotpoint washing machine wont stop spinning for some reason any ideas what is wrong
Very likely that the filter is blocked. Because the machine senses there is still water present it carries on spinning but the blocked filter is preventing the machine emptying. Turn off the power at the plug. The filter is usually mounted at the front near to the floor. Unscrew counter clockwise and be prepared for some water to leak out. Clean the filter under a tap, it will probably looked blocked and then re fit. Select a short programme cycle and see if the fault is cured.
Jul 04, 2010 | Washing Machines
I have hotpoint aqurieus WML560 will not drain how do i do this manualy
To get rid of any water still in washer, lay drain outlet hose to floor level, and the water should run out through gravity into a bucket or similar.
Once empty, remove the lower rear pamel of washer.
Remove large black hose on to pump.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Washing Machines
My filter!!
First of all,lay the drain hose down to floor level and let the water run into a bucket or similar, this will empty the washer of water.
the filter is inside the large black hose on bottom of drum.
Undo hose, remove and clean filter
Refit filter and hose.
This should solve your problem.
Good luck.
Jan 03, 2010 | Hotpoint First Edition FEW12 Front Load...
Hotpoint wf220
If ther is no filter at the front of washer, then remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose, also remove hose onto pump, and check for obstruction here and in the pump.
Thanks.
Nov 15, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Ultima WMD940 F-03 showing on display
Good Luck
Please rate FixYa!
Dec 19, 2008 | Hotpoint Washing Machines
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Washing Machines Logo
262 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
