Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Dryer stopped working - Frigidaire FEX831CS Top Load Stacked Washer/Dryer
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
If you are having dryer problems and you cannot even get the thing to start, then you might want to start going through this check list of possibilities. There are a number of things that can cause your dryer to not run.
A couple of the most common problems are the thermal fuse has blown or the door switch is not operating properly. On many dryers if the thermal fuse blows, the dryer will not run at all. This fuse can be checked with an ohm meter. It should show continuity if it is okay. If there is no continuity then you need to replace it and also find out what else failed. This is a safety device that usually blows because something else allowed the dryer to get too hot. It is usually located in the back of the dryer, on the blower housing. Some are oval in shape and others are rectangular, usually with two wires attached.
A defective door switch or a bent door switch lever can also cause you to have problems. If the lever is broken or bent it will not activate the switch. If the switch is broken, this also will not allow the dryer to be started.
The push (or turn) to start switch can go bad, but is unlikely. To check this, hold it in or turn it and then check to make sure you have continuity with an ohm meter.
If the dryer starts and then stops when the switch is released check the control board or the ?even heat? control on some model dryers. Some dryers have a belt break switch that can fail or your belt may be way loose or broken.
Check for burn marks or burnt wires at the terminal block on your dryer, poor connections can cause all kinds of problems. Also poor connections can cause fires.
A bad power cord also falls into this same category.
Of course, always check that you have the proper voltage to the outlet that you are plugging into.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Posted on Jun 06, 2011
Yes my dryer just stopped working .. Was working fine then just stopped..
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 28, 2011 | Maytag Dryers
Just stopped working
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
Dryer2_bing.gif Repair ? The dryer will not start
heatman101
May 12, 2010 | Magic Chef CYE4000AWW Electric Dryer
Dryer stop working
Check the breaker for the dryer power. The breaker may have tripped or lost half of the power supply.
Sep 24, 2009 | Dryers
Thermal limiter stops dryer; replaced multiple times. Dryer dead.
I think you are working on the wrong end. Check the fan and inlet ductwork of the dryer, if the air isn't moving properly, it will not move enough to keep the coils and limiters cool and they will fail after working properly a few times.
Sep 03, 2009 | Frigidaire Dryers
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
The dryers drive belt most likely broke. it must be replaced with a new one.
Dec 20, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Maytag Dryer Working Fine Stops Working
Take off the top of the dryer and you will find somewhere near or at the drum a fuse. Try bypassing it first to see if it works. If so, go get one for about $10.00. There may be a wire that has burned off at the connection in the back of the dryer also.
Oct 18, 2008 | Maytag PYE2300AY Electric Dryer
My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
Mar 26, 2007 | Whirlpool GEW9878LW Electric Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
