Question about Dishwashers
Dishwaher washing in cold water
Hi metroi, I do have hot water in the rest of the house, do you have any more suggestions why the dishwasher is still washing cold? Thanks LexieB
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
Are you sure it is hooked up to the hot water line? if it is, then make sure the valve is in the open position.
Posted on Aug 23, 2008
My dishwasher has always washed in cold water never had any hot water why is that
Probably because it is hooked up wrong...
The water feeding it should be hot water... meaning it should be hooked into you hot water piping, not the cold water...
The dishwasher will keep hot water hot but it is not powerful enough to heat the cold water up...
Jul 16, 2011 | Servis 23 in. M4306 Free-standing...
Dishwasher issues
You should always turn the hot water faucet at the kitchen sink first before starting dishwasher. If you don't your entire wash is cold water. This will also cause the water temp mode to take forever to heat the water to the 140 that is factory set. Hope this helps.
Feb 02, 2010 | Dishwashers
My dishwasher is not cleaning the dishes.when the dishwasher is done there is still stuff on my dishes. if you cancel the cycle the water in the dishwasher is cold
If the machine used to work fine then I'd suggest running the hot water in your sink before starting a cycle to ensure the water entering your dishwaher is hot. If you then are getting hot water and still dirty dishes try reposting for a a solution. When re-posting, include your make and model for a better answer.
Can I take the bottom part of the dishwaher apart
Mkae sure you are running kitchen hot water faucet before starting dish washer. If not you are getting mostly a cold water wash thru out the cycle. Also make sure the jet dry dispenser is full. Always use the liquid jet dry as the small cubes you can get do not work nearly as well.
Jan 31, 2010 | Kenmore 15762 Dishwasher
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
No hot water, plates cold and dirty and wet
If you've installed it recently make sure the hot water tap was plumbed in and not the cold water tap, check the hot water tap temp in the house to make sure it's getting warm, there also should be a heating element located inside of the dishwaher that heats up to help the dishes dry at the end of the wash cycle, which is controled by a thermostat. If the heating element or the thermostat are bad your dishes won't dry.
Mar 25, 2009 | Miele 24 in. G638 Plus Free-standing...
Hot water for dishwasher
Hi thanks for the question. before you start your dishwasher turn on the hot water tap at sinc let the water get hot . then start the dishwasher it will be hot enough for the rest of the cycle. thanks the appliance doc
Oct 06, 2008 | Dishwashers
Dishwasher not heating water
British machines are Cold water fed, and the machines heat the water themselves. American Machines are hot water fed.
Nov 05, 2007 | Dishwashers
No hot water when washing dishes
sounds like it was hooked up to a coldwater line instead of a hot and your heating element in the dishwasher went bad from overload or your pc board went bad but i would check to see if it is hooked up to hot water line first..
Jun 29, 2007 | Kenmore 16483 Built-in Dishwasher
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
