Question about Samsung Refrigerators
Samsung rs 20 fridge-freezer:- fridge not cooling properly
  • 828 Answers
Problem answer submitted under first of this double post.
Posted on May 25, 2008
Samsung Cool n Cool upright fridge freezer bleeping constantly, both fridge and freezer working OK
Model number? Usually that is warning that something is wrong. Example defrost not working properly thermistors are defective, or door open. Need your model number to give you answers
Appliance 911 Sea Breeze
Oct 01, 2015 | Samsung Refrigerators
How to fix the rs 2555 refrigerator is not cooling, but the freezer is fine
1) Twin Cooling System
·The refrigerator and the freezer have two
evaporators.
Given this independent system, the
freezer and the refrigerator are cooled individually as
required and are, therefore, more efficient. Food
odor from the refrigerator does not affect food in the
freezer due to separate air flow circulation.
The Evaporator unit for the fridge may need servicing.
if you handy with tools you can fix it yourself the manual link is below
http://vdmeulen.net/handleiding/Samsung%20SR-S24%20FTBS/samsung%20rs2555sl%20service%20manual.pdf
Aug 16, 2014 | Refrigerators
I have a RL41WGTB the freezer is working but the fridge will not get below 20 degrees
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 04, 2011 | Samsung Refrigerators
I HAVE A SAMSUNG FRIDGE SIDE BY SIDE .THE FREEZER DOES NOT FREEZE IT SHOWS 19/20 C ..THE COOLING SIDE WORKS FINE..WHAT IS THE PROBLEM
heatman101
Aug 21, 2011 | Samsung RS2630SH Side by Side Refrigerator
My Samsung rs 2556 SH side-by-side fridge is making a loud whirring noise, but when I open the fridge the noise comes to a sputtering stop. It starts again a few seconds after being closed. Noise sounds...
there is a evaporator defrosting problem; ice building-up. the evap fan is mounted right on top of the evap coil. this will get progressively worse; and, the fan will get completely jammed with ice; and stop altogether. your fridge will get warm and the freezer will not cool properly. you should get it looked at asap..
May 18, 2010 | Samsung RS2630WW Side by Side Refrigerator
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling properly
This site has a solution. And it's a well known problem with Samsung's refrigerators. Basically the evaporator behind the panels inside the fridge (not the freezer) is iced up. If you open the panel and let it thaw, it will fix the problem. However in my case, the same old problem comes back in 20 days. I'm trying to find a long lasting solution instead of putting a band-aid on the issue.
Jul 13, 2008 | Samsung RS2534 Side by Side Refrigerator
Freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Apr 01, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Samsung fridge problem
You need to post in the correct section of Fixya, you may then get the answer you seek.
Jan 04, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Refrigerators Logo
355 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
