Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Compaq 3.0 something, something
I am a small time technician, and was given a Compaq 3.0 machine to install Xp as i was moving it around "i had already clicked shut down". when i placed it on a stable position, i tried to start it up, it started giving me long beep codes and i dunno what to do.I opened the machine and tried sniffing around in near the M/Board and i think i smelt sth ad burn what's the best next thing i can do??
  • biggyning May 26, 2008
    Kg...397.Thanks for your input am going to try that and see what will happen..i'lll be sure to tell you what will happen.....But what would have caused this? is it me moving it around while on?, But remember the long beep codes were continous not one long beep code(do still think its the same problem??)
    Thanks again.
    Biggyning
Kgjsm397: Hi again, i went back to the machine, and the crazy thing is that it had no problem, infact i just powered it and it booted with no problems.....could it be that i had pressed the keyboard or even a key on the keyboard was stuck??? i just dunno i was quite supriseed.thanks though
Posted on Jun 04, 2008
  • 105 Answers
The long beep is sign of RAM is unserviceable or not fitted properly (Solution is remove the RAM clean the contact area and fit back again it failed replace with serviceable one)
RAM might have shorted. Check the MB for any physical damage if no follow above step.
disconnect the all cable connecting to drives like cd, hdd, fdd etc. then you can solve.
Posted on May 25, 2008
I have encountered a problem while installing Windows XP over Windows 7 on my laptop Compaq CQ62-410-US
Most likely you will have problem trying to install windows XP in a windows 7. It is better to use a virtual machine on your windos 7 instead. Windows XP mode will not work on a Home edition of Windows 7. you can download the Virtual machine in this link: http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=4580
Once you have downloaded and install this run it. then install the XP on this mode by -run the virtual machine -go through the setup -insert the installation disk -wait for the installation is complete
Then every time you will run the virtual machine it will go to the XP that you installed.
hope this helps
Jun 27, 2011 | HEWLETT-PACKARD HP Compaq Presario...
I have been given a Compaq Presario 5000 PC Desktop but it has password that we don't know . It did not come with any type of cds. I need to wipe it clean but how do I restore the windows xp home edition?
Well, here's the bad news. 1) Windows XP is not supported any more by Microsoft. (2) You need the original CD's that previously installed XP on your computer. If you can't get them from the previous owner, then you'll have to try and find some original CD's and reinstall XP on your machine, from scratch. (3) If your computer has what it needs, an option is to install Windows 7 on your computer - it depends how old your computer is and if it has the necessary hardware.
Oct 04, 2010 | Compaq Presario 5000 PC Desktop
Cannot upgrade TC1000 to XP SP3 no error codes given, win upd not working also tried standalone upgr no luck
I'm not sure what your abbreviations mean but the only time I've had a problem with SP3 was down to a poor internet connection and lack of virtual memory on an old machine.
I was able to reset the virtual memory by using the Help files on the PC.
To over come the poor internet connection, I downloaded SP3 and saved it to a USB flash drive.
That way I was able to install having stopped all running processes.
May 11, 2010 | Compaq tc4400 Tablet PC
Problem installing Windows XP on Compaq C 740 TU with Vista
To install Windows XP, it is complicated. You need to have the drivers for your Compaq Presario available on another PC so you can copy as needed. I'd suggest going to the Compaq (now HP) site to see if drivers are available. Good luck !
Jun 10, 2009 | Compaq Presario 700 470024-192 Notebook
Xp drivers for compaq-presario-cq60-104tu-laptop
i have compaq presario cq60 104tu laptop and no driver for xp
Jan 10, 2009 | Computers & Internet
2020 rotary hook continuous one direction pfaff tiptronic 2020
You are absolutely correct - your machine doesn't come apart much because it is an electronic machine. There really are very few moving parts in modern sewing machines - and the electronics are better left to a technician who's been specifically trained.
It sounds as if your machine is no longer in time (needle rubbing the plate as it goes around if I'm understanding correctly). While not really a "major" repair, unfortunately with computerized/electronic machines, retiming your machine is something better left to an authorized Pfaff technician.
If the needle struck metal as you were stitching/basting, there may also be a rough spot/burr on the hook that your technician will be able to smooth off as well.
Hope this helps get you back up and running soon.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Nov 23, 2008 | PfaFF Tiptronic 2030
Windows xp installer problem
Jack,
Do you know what it's trying to install? The status bar at the top of the browser should be prompting you with the name of the package.
Are you sure it's the browser and not windows trying to install something? Run Windows update and be sure everything is current. You may have to run & reboot a few times before your machine is up to date.
Jul 18, 2008 | Compaq Presario 5000 PC Desktop
Bad Harddrive
please check your cables and try with new one.check the bios setting
Apr 04, 2008 | HP Compaq Business Notebook NX9010
Compaq presario powers on but dont boot
RE INSTALL YOUR OS (LINUX OR WINDOWS OR VISTA ETC)
Nov 24, 2007 | Compaq Presario 700 470024-192 Notebook
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
27 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
