Question about Ariston Technologies AWD121WH
Hi I have a Ariston Aqualtis AQXXL109 front loading washing machine. My problem is trhat the door stays locked, unable to open. I have continued to turn the child lock the key light continues to stay on. my email address is helenlauderdale@yahoo.com Thankyou Helen
SOURCE: ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
Posted on Jun 13, 2008
SOURCE: Cant open door of washing machine
I plugged it out. Left it for 15 minutes. When I went back the door could be opened and it also started to wash.
Posted on Jan 21, 2009
  • 10 Answers
SOURCE: we have the Ariston Margherita front loader
if the machine is full of water pump blocked or broken if machine empty needs new door interlock or pressure switch blocked or broken
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Posted on May 17, 2009
  • 15 Answers
SOURCE: Aqualtis washing machine door locked, need quick release?
yes there is a quick release
the door lock have 3 wires u should connect 2 of them together the first one and the third
but its dangerous if there is kids cause u will b able to open the door while its on
Posted on Jun 05, 2009
MNfisherman
  • 11896 Answers
SOURCE: my ariston washing machine door not locking
I recommend replacing the door latch. It is a fairly common problem. You can get one at repairclinic.com or partselect.com
Posted on Jan 02, 2010
I have an ariston aqualtis AQXXL washing machine and the door will not close. The lock is jammed. I tried to lower the lock manually but it still doesn't open. How do i unlock it?
turn the power off at the mains
take the top off and try to do it from behind
the interlock may have jammed up and youll prob need to fiddle with it a bit
pushing the door in a little will make it easier to move the locking key from behind
then youll need a new door interlock
Mar 02, 2015 | Washing Machines
How do i unlock the door manually it's locked with the washing inside
do you have the manual I found this answer but have no idea if your machine is like the one described .Then opened the door (if locked use yellow tab behind kicked panel to open
Feb 19, 2015 | Hotpoint Aqualtis AQXXL129PM Washer Front...
Hotpoint aqualtis aqgd169s no power wont turn on not even had an error code come up
If the machine is dead, I would check the cable from the main boad leading to the front display on the door. Often the cableharness breaks at the hinge. (one of cables). If that is not the case, eather the main board or display board is dead.
May 26, 2014 | Hotpoint Ariston AW125 Front Load Washer
Door locked,cant open
just get an old door from any ariston..hotpoint or indersit machine make sure it is the same size
Jan 12, 2014 | Ariston Technologies Ariston AWD12 Front...
Constant clicking of door lock
Suggestion: Try a little WD40 spray on the door, not on the machine. Close and open 2 or 3 times while plug is off the wall mains.
Click if helped.
Apr 14, 2013 | Ariston Technologies Ariston AWD12 Front...
Cannot open Wash door
Here is a tip that I wrote about how to get your washing machine door opened...
Washing Machine Door Jammed
heatman101
Jan 24, 2011 | Ariston Technologies Ariston AWD12 Front...
Jun 05, 2009 | Washing Machines
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Closed door
Dear babmat: just now got your question. We are very satisfied with our ARISTON Washing Machine. I trust that that is what you are inquired about? I had the same problem the first time. This locking occurs when one opens or tries to open the washing machine door too soon!!!! It has to be left alone for a few minutes. When I waited and later tried again to open the machine, I did not have a problem.
Just wanted to leave this note for anyone who encountered the same problem. You, yourself, hopefully, might have gotten that answer and the problem fixed in the meantime!?
Greetings, handinovice
Sep 04, 2008 | Ariston Technologies AW129NA 16 Lbs Front...
Ariston Technologies AWD121WH Logo
593 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
