Blank screen when i switch on my hp laptop ,connected to external monitore no display . but there is sound of fan and hardrive.please tell me how to fix this ,i think it should be something about video card
  • 115 Answers
Please check the Num lock on/off or not if its on/off then check the VGA and Power cable of external Monitor properly connected or not.
Posted on Sep 29, 2010
How to enable secondary display adapter fujitsu laptop
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
May 18, 2012 | Fujitsu LifeBook Computers & Internet
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
My hp dv4-1435dx screen is blank.It was on then it froze and then went blank. I have tried to fix it by removing the battery and replacing it a number of times. It comes on when started and plays the...
This could be due to presence of static charges on the notebook or hardware malfunction of the video card or defective LCD display screen of the notebook. To resolve the issue, perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check if the display works fine or not. Incase, if the issue persists, then the video card or LCD screen must have gone bad, and to isolate the same, please connect an external monitor to the notebook and check for the display on it. You can follow the steps below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your notebook is under HP warranty, then contact HP to get the notebook repaired for free of cost.
Jun 01, 2010 | HP Pavilion dv4000 Notebook
Blank screen,pwr sup appears to ok, fans runs, pwr light on
The issue seems to be due to defective video card on the notebook. Connect and external monitor to the PC and check if it works fine or not. You can follow the steps listed below to connect an external monitor.
If your PC is under warranty, contact HP to get available options to get the notebook repaired under warranty.
May 26, 2010 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
Baterry went off. i have charged it but the screen wont come on though i hear the fan. i have to remove the battrey to put it off. have tried an external monitor and it says computer on sleep mode. press...
Perhaps a result of the auto display off. press any key to activate the screen again.
If using the LCD screen, make sure the priority is not set on an external monitor. To do this, press the Fn function key combination to set the display priority.
if you use an external monitor:
1. Check whether the monitor is switched on
2. Check if the power cable is properly connected
3. Check if the cable menguhungkan external monitor and the notebook is connected correctly.
4. Try to set the constrast and brightness on the external monitor
Nov 01, 2009 | Toshiba Satellite A355D-S6921 Laptops
Dell Inspiron E1705 does not show any picture
First of all, check that the laptop is set to output video to the LCD. There should be a function key which will determine whether it is outputting video to the built-in LCD, the external monitor, or both. That should be holding down your "FN" key and hitting "F8." If it is on CRT ONLY, it should switch within 1-2 keypresses.
Secondly, take a good bright flashlight and shine it directly at the LCD panel from about 1-2 inches away. If you can actually see the graphics on the screen faintly in the background, your backlight is not turning on. The backlight is literally a bulb which lights up the screen, and they can burn out. It is repairable, and shouldn't cost more than $150.00 from a reputable repair shop.
Sep 01, 2009 | Dell Inspiron E1705 Notebook
Black screen battery charged new ac cord turns on fan is on nothing on screen wont go on to hard disk i guess
Your LCD screen is probably bad.. Can you see anything? It may be very very very dim. If it is very dim(use a flashlite to see if anything comes up), if you can see something but is very very dim then it is the backlight to your LCD screen and you need a new screen
Try connecting your PC to an external monitor.. then try getting it to work..
If it works on an external monitor then it is your LCD screen.
If it fails, then it is your video card or motherboard.
Sep 01, 2009 | Toshiba Satellite A135-S2276 Notebook
Lost screen
you need to find out if your screen is bad. does it sounds like it booting up and you hear the sound when windows boots up? you can also try connecting your laptop to an external monitor. if you see a display on your monitor, then you screen on the notebook will need to be replaced, if you dont see a display on the external monitor, then you have most likely a bad mainboard , you might have a bad ram module too. but most likely the main board
thank you
Apr 19, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
